  1. May 7, 2017 at 10:52 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Shiny, I have a NOS set of OEM cams and they aren't even that shiny. I'm gonna paint em red because racetruck
  2. May 7, 2017 at 12:50 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    This is kickass.
    Kittenmittens4U likes this.
  3. May 7, 2017 at 1:13 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Come on bro. I get down with my lines
    jjsul likes this.
  4. May 7, 2017 at 5:37 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I got my valve cover gasket all buttoned up today. fingers crossed for tight seals :fingerscrossed:
    First time i've opened up an engine at all, so my buddy and I had a good time busting our cherries. Pretty smooth process TBH.
  5. May 7, 2017 at 5:39 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
  6. May 7, 2017 at 6:31 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    After several weekends of sketching, measuring, cutting cussing and painting my bed drawers/sleeping platform is finally done. I have plans in cad if anyone is interested. For DC bed only.
  7. May 7, 2017 at 7:31 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Bruhhhhh
  8. May 7, 2017 at 7:36 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Is that bedliner?
  9. May 7, 2017 at 8:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    close to 3/16s i believe...why?
    TacoVio[QUOTED] likes this.
  10. May 7, 2017 at 9:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Took off the canopy. Washed her. And took some driveway poser shots.
  11. May 7, 2017 at 9:16 PM
    Speedytech7
    Nice I only took steps backwards today and broke my CB wiring and mount. Then furiously ripped it off the truck
  12. May 7, 2017 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm sure there's a good story behind this. :popcorn:
    SnowroxKT likes this.
  13. May 7, 2017 at 9:20 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
  14. May 7, 2017 at 9:21 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    :popcorn:
  15. May 7, 2017 at 9:43 PM
    TacoVio
    Kolton
    CO/WY
    Welded rear shock mounts. Wanted to know how high I needed to crank the welder to burn those bitches in with no worries of breakage. Got a pretty good bead on them and the axle so I think it worked. Thanks for your response :thumbsup:
  16. May 7, 2017 at 9:43 PM
    Speedytech7
    I set up a new cb for a buddy and then I went to retest my swr afterward and it was too high for my liking so I thought I'd make a couple ground straps but that didn't help. Played with the mount a bit and the connector sheered off. So I got pissed and ripped the antenna off and pulled the whole cable out from the cab. So now I'm going to mount it off my ditch bracket and use a 2ft antenna. After I buy new gear.
  17. May 7, 2017 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah. Yeah wouldn't worry about that. Unless your welding on the very outside where the seals are, then may wanna replace those.
  18. May 7, 2017 at 9:46 PM
    TacoVio
    Kolton
    CO/WY
    FWIW I had a 2 foot on my ditch light bracket and could not get it to tune for shit. Ground strap and all. Switched to a 3 foot and I have a nearly a perfect set with low end at almost 1.5 and top end at like 1.6 or 1.7.
  19. May 7, 2017 at 9:48 PM
    Speedytech7
    Hmm I'll see about a 3' then, I know the 2' works well for @m3bassman
  20. May 7, 2017 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats not very good...
    i get 1.2 on a 5'.
