  1. May 12, 2017 at 8:27 PM
    TacomaCox
    TacomaCox GO BUCKEYES!!!
    Craig
    Locust Grove, Ga
    2002 Black Tacoma TRD Prerunner dbcb
    17 Inch rims and Drilled and Slotted rotors, LED headlight bulbs.
    Yea you figure though our stock bulbs do it. And if you have somebody coming at you with silverstars they may also to an extent make it hard for you to see. Nobody knew about projectors they just want to see better at night.
  2. May 12, 2017 at 8:34 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Ready for those treacherous creek crossings.
    rngr and BYJOSHCOOK like this.
  3. May 12, 2017 at 9:51 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Quite a bit more than my bulbs
  4. May 13, 2017 at 6:05 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Are you in nor cal?
    Well, lets play sir!
    We will be out at PC today. No crazy creek crossing. But alot of cool obstacles
    2BeersPlease[QUOTED] likes this.
  5. May 13, 2017 at 6:08 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Utah, but close
  6. May 13, 2017 at 6:09 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So i was going to order the speed gear assembly and the dealer is saying i still have to have my rig calibrated? This part alone will not correct my issue os what they said
    @Digiratus
  7. May 13, 2017 at 6:15 AM
    2BeersPlease
    Been wanting to get out there, but I want to tackle this project first. It's today's priority on the to-do list.
    Taking it in on Tuesday for an alignment, and to check my work.
  8. May 13, 2017 at 7:37 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Damn. No invite! :(
    Would have loved to help out
    cruiserguy likes this.
  9. May 13, 2017 at 7:44 AM
    Rayzer8
    Rayzer8 New Member
    1998 Toyota Tacoma, SR5, extra cab, V6, 4x4
    TRD Supercharger, 4" Procomp suspension lift, Borla exhaust, 32 KO2
    Just bought Doug Thorley headers silver ceramic for my 98 V6 tacoma for $318! Can't wait to have them installed.
    Jaysjammin likes this.
  10. May 13, 2017 at 8:02 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Thank you so much
    Install was easy ? I will order today
    Tired of driving by candle
    TacomaCox[QUOTED] likes this.
  11. May 13, 2017 at 8:31 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Ome coilovers don't change any geometry from stock do they? They have the same extended length right?
    Just trying to figure out if it's my lift that was causing the itr to bottom or if those itrs would bottom out on a stock set up.
  12. May 13, 2017 at 8:34 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    If I remember right from when I did mine, They are about an inch longer overall, so you have a little more droop with them.
    My aftermarket rack bottomed out too, the new OEM unit does not.
    Reh5108[QUOTED] likes this.
  13. May 13, 2017 at 9:11 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    whered you get for that price? i need a set to replace my leaky stockers.
  14. May 13, 2017 at 9:34 AM
    TacomaCox
    Craig
    Locust Grove, Ga
    Super easy man, there is an adapter you put on first like your normal candle bulb. Lol put the dust cover on, cut the shroud off first, then twist and lock the bulb. It is a little tight between the battery but it will fit and the plug is a direct plugin. Easy man like 10min tops.
    PROseur[QUOTED] likes this.
  15. May 13, 2017 at 9:36 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Question for the ARB compressor. Do I turn it off after the lockers are engaged or does it need to be on the whole time.
  16. May 13, 2017 at 9:53 AM
    Reh5108
    Idaho
    Keep it on. If you have any sort of leak it will kick back on to maintain the pressure and shut off when it's supposed to. It basically shuts itself off automatically with the pressure switch
    Fernando[QUOTED] likes this.
  17. May 13, 2017 at 9:57 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ha. Sounds like they want to sell you something else.
    On mine, all I did was replace the 30 tooth gear assembly with a 33 tooth. It is not perfect but it is way closer than it was. And it has less error that the truck came with from the factory. All stock (gears and tires) there was a 5% error from the factory. Was reading 70 where the GPS said 66. This is pretty typical actually. After regearing and with 33s and the 33 tooth speedo gear the speedo reads 72 and the GPS says I'm actually going 70. The is less than a 3% error. Better than it was from the factory.
    Leave it on as long as you want the locker engaged. It should cycle on its own. On to pressurize the little tank and off as long as the pressure maintains at 90 psi. If the pressure drops, it'll come back on if the switch is still on. When you are done with the obstacle switch it off.
  18. May 13, 2017 at 10:07 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I love TW. Thanks guys
    jubei, cruiserguy and Reh5108 like this.
  19. May 13, 2017 at 11:44 AM
    Jaysjammin
    Jaysjammin Well-Known Member
    Jay
    Upstate SC
    '98 SR5 5-speed 4x4 3.4L, 07 FJ Auto 4x4, 97 Locked 80
    What kind of UCA's are those? I really like the Total Chaos, but they're currently outside of my build budget.
  20. May 13, 2017 at 11:45 AM
    devinzz1
    devin
    2023 aclb trd or mt
    spc
