  1. May 13, 2017 at 11:19 PM
    nvwiggins
    nvwiggins Well-Known Member
    David
    Elko
    96 Tacoma, 85 T4R
    Tepui Kuenam Sky RTT.
    I would, they were like $340 on Amazon. I think being able to see is worth the investment
  2. May 14, 2017 at 6:09 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Diff install withs some local guys, and Craig from Toywerx came by and personally installed a new grill he hooked me up with for my birthday. :cool:
    Before:
    After:
    It's so damn nice.
    Barely got any pics, we were cranking through shit. Got the rear in and everything torqued, same for the front diff. Just need to torque all the front end components.
  3. May 14, 2017 at 7:31 AM
    Madjik_Man
    Colorado Front Range
    I need to do my plugs and also touch up my sliders and bumpers and stuff.
    m3bassman[QUOTED] likes this.
  4. May 14, 2017 at 9:55 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Differential Skid plate new for free since dealer lost it last service day so I returned to get them install and state inspection 25 dollars
    Speedytech7 likes this.
  5. May 14, 2017 at 10:38 AM
    2002Tacoma4x4
    C K
    Remove gas tank Skid Plate
    Step 1 is 4 bolts , 2 up front 2 at mid rear
    Front has 3 but Do Not touch one in the middle, tks TW post i learned.
    Step 2 clean up a lot of flanky rust with spatula and thiner then awesome degreaser , also clean tank, not flakes or signs of rust just dirt and excess of grase from the drivetrain zerks
    Step 3, apply the Rust Converter Eastwood brand, is a milky fluid ONly apply with the rust exist.
    Step 4 gotta wait 72 hours to let it dry the rust converter, work to be continue next weekend.
    sente3, BYJOSHCOOK, jubei and 2 others like this.
  6. May 14, 2017 at 12:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I should do this, I'm pretty sure mine is filled with earth.
  7. May 14, 2017 at 2:23 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    changed cv axle. snapped one of lbj bolts. i actually took these out not even 2 years ago and thoroughly coated in antiseize yet they were rusted in like crazy. no matter how much rust protection i put on this 2 times a year the damn things rusts like crazy.
  8. May 14, 2017 at 2:28 PM
    Speedytech7
    Weird, I changed mine two years prior to this last time and used red loctite and no anti size and they all were a bit loose. Are you using the flanged bolts or the normal with washers?
  9. May 14, 2017 at 2:40 PM
    devinzz1
    devin
    2023 aclb trd or mt
    flanged. they came with my oem lbjs.
  10. May 14, 2017 at 3:03 PM
    devinzz1
    devin
    2023 aclb trd or mt
    jobs already done. i was expecting them to come out nicely since putting anti seize on em. and yes im using old scrap bolts on my lbj for the time being. will replace them when i can.
  11. May 14, 2017 at 3:04 PM
    Speedytech7
    If you have time to wait or remember beforehand PB Blaster or Kroil are the shit. If you are forgetful and doing it last minute 50/50 Acetone and Automatic Transmission Fluid. If you're me, you don't use any of those because your out of them and you don't actually need it 90% of the time (shitty climates notwithstanding)
    MtRSQ likes this.
  12. May 14, 2017 at 3:18 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Sunny, about 73°, a few clouds in the sky; sounds like a good time to give the ol' girl a proper bath.
    So glad I bought that little Ryobi pressure sprayer with soap dispenser. Along with some good drying towels and a shamois, I managed to wash two cars (RAV4 and an Acura RDX) this morning in an hour. Truck took about 45 minutes.
    BYJOSHCOOK and 2002Tacoma4x4 like this.
  13. May 14, 2017 at 3:21 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I miss living in Sac :(
    2BeersPlease[QUOTED] likes this.
  14. May 14, 2017 at 3:24 PM
    2BeersPlease
    This time of year, the weather is perfect. There's even a nice cool breeze.
    View from my backyard right now. Days like this I wish I had a hammock.
  15. May 14, 2017 at 3:29 PM
    Itchyfeet
    Hoping by this time next year to be back in Sac/Chico or Redding.
  16. May 14, 2017 at 3:35 PM
    Ak4T777
    Ak4T777 Well-Known Member
    Kevin
    2003 Tacoma crew cab
    OME lift 3" lift 1.5" lift shackles Aftermarket bumpers 1" body lift
    The white harness that has the wire you want to cut is connected to this black box. Its under the dash on the gas pedal side. Its closer to the center console. The black box is clearly labled unless your sticker has weathered.
  17. May 14, 2017 at 4:43 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    you accidently hit the push pin, it is centered and not pushing out on one side or another. (forward, reverse)
    think of it as a neutral position
  18. May 14, 2017 at 4:58 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The dial that changes the shaft direction from forward to reverse right? That's what I thought. I pushed it side to side and tried again but it would only spin for a few seconds intermittently and just blow air afterwards. I'm uploading another vid it'll be a minute.
  19. May 14, 2017 at 5:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah true. I have offroad lights though so..yeah.
  20. May 14, 2017 at 7:20 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Hey thanks man!! Killer truck btw! Maybe one day I'll be in the cool 1st gen club.
    Ak4T777[QUOTED] likes this.
