  1. May 28, 2017 at 1:51 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Picked up some bling for the taco from @Thaitoy today. 32 inch AUXBEAM light bar. With Bluetooth control. Very nice product. Quality connectors and wires.
    cruiserguy and BartMaster1234 like this.
  2. May 28, 2017 at 2:05 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Do what Tyler said, and if it is the motor, I have one if you need it.
  3. May 28, 2017 at 4:16 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Swapped my speedo gear for a 33 tooth with my pup.
  4. May 28, 2017 at 4:49 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Puppers :yay:
    jubei likes this.
  5. May 28, 2017 at 5:26 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Installed new lower ball joints. Easier than I thought it would be.
    mechanicjon, cruiserguy and jjsul like this.
  6. May 28, 2017 at 6:41 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    Struggled to find a 75w-90 gear oil that was not synthetic or syn blend or has additives for limited slip. I need to order this stuff for when my tru trac install goes down later this month. I'm half tempted to buy the Toyota shit, but ho-lee-fuk is it expensive. I tried Wal Mart and nothing
  7. May 28, 2017 at 7:10 PM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    I bought mine at Autozone: http://www.autozone.com/greases-and...formance-gear-oil-sae-75w-90-1-qt-/373222_0_0 I had to go to two different places to buy enough of them because I was doing both diffs and the transfer case at the same time.
  8. May 28, 2017 at 7:46 PM
    bradkaren
    bradkaren coffee lover
    Pacific Wonderland
    2001 Silver Tacoma SR5 4WD V6 AT
    Finally finished installing my Wet Okole seat covers. Feeling good... check one more thing off the list...
  9. May 28, 2017 at 7:51 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Shitty pic but it's late... Icons, lr uca, tie rods, LBJs, CVS, bushings, stabilizer links and alignment cams installed... Rides so amazing. Tire shopping mañana. And moar pics of course...
  10. May 28, 2017 at 9:34 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Has anybody with Dakar leafs started getting bad axle wrap after putting 15 to 20k on them?
  11. May 28, 2017 at 9:42 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I haven't tried that quite yet. Probably should so I can narrow it down. I'm just assuming it's the motor
    I haven't put it back together yet, so hopefully it's something minor. Which would help a ton!
    I may take you up on that offer
    RedManRocket[QUOTED] likes this.
  12. May 28, 2017 at 10:47 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    A few years back my driver side window wouldn't roll up, when I pulled the switch nothing happened, no sound etc. My initial thought was bad motor, but pulled the switch and cleaned the contacts, I haven't had a problem since.
  13. May 29, 2017 at 12:08 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Kinda hope that's the issue. I'll put everything back together later today
    DoubleC likes this.
  14. May 29, 2017 at 4:46 AM
    taco57
    taco57 Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    Those are nice! How much? Is that a grey interior, hard to tell on my screen. Does the color match up nice? The fit seems to be excellent.
  15. May 29, 2017 at 7:29 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Question.
    Has anyone had good luck with HF floor jacks? I have one I bought (from pep boys I think) a while ago. It was fine for my cars, but was a total fail for the PreRunner.
    I ended up needing to use the stock bottle jack.
    So I was thinking of getting this one 3 Ton, 19 3/4 inch lift.
    malburg114 likes this.
  16. May 29, 2017 at 7:37 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yeah mine did the same I just replaced the switch assembly. I took apart the old one just to look and all the contacts were corroded/smoky looking. The switch comes out easy without taking the door apart just lift the front piece of the plastic bezel that surrounds it towards the front of the truck then slide it forward. then you can disconnect the wire plug and take apart the switch.
    I did get the window to go up previous to the switch replacement by hitting the door;) It was about to rain and I hoped the window motor wasnt the issue but I got the window up in time.
  17. May 29, 2017 at 9:59 AM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Don't forget the put when you do the test drive or it will look like national lampoons family vacation
    retroboy1989 likes this.
  18. May 29, 2017 at 10:07 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    They work great, I've had mine for a few years and no problems.
    jjsul likes this.
  19. May 29, 2017 at 10:08 AM
    eon_blue
    Azusa, CA
    Got the URD 7th Injector kit installed :burnrubber:
    04yota, cruiserguy, jjsul and 4 others like this.
  20. May 29, 2017 at 10:36 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    I've had the same one for about 6-7 years - NO problems But beware it's a HEAVY S.O.B. if you have to carry it !!
    nagorb[QUOTED] likes this.
