  1. Jun 9, 2017 at 1:07 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I was trying to keep the 03 hood and grill. So that's a no?
  2. Jun 9, 2017 at 1:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Not going to fit.
    With that said, fenders and hoods are very reasonably priced. Shop around and you could find all 3 for less than $300.
  3. Jun 9, 2017 at 3:11 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    My 00 fenders fit my 01-04 conversion perfect. All I changed was hood, grill, headlights and kept my same fenders.
    I think it depends if it's prerunner/4x4 or if it's base
  4. Jun 9, 2017 at 3:50 PM
    1997tacomav6
    Denver
    You can always rasise it to just below the body line 1/2", nice clean look with SS tip,
    Silver02Taco likes this.
  5. Jun 9, 2017 at 5:30 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Any of you guys ever remove an alarm system?
    I replaced my turn signal relay today, and this is what my dash vomited out at me.
    Pro quality install, for sure.
    Speedytech7 likes this.
  6. Jun 9, 2017 at 5:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks like the installer went to the Jerry-Rigg university of automotive knowledge.
    I'd get an OEM wiring diagram and match colors.
  7. Jun 9, 2017 at 5:47 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    i want a remote start in the t4r, but i'm scared that local installers will do this.
  8. Jun 9, 2017 at 5:54 PM
    94jdmeg6civic
    94jdmeg6civic Well-Known Member
    David
    Orlando,Florida
    2001 Tacoma dbl cab long travel
    What bumper is this ?
  9. Jun 9, 2017 at 5:57 PM
    jubei
    NoCo
    Stuff. Also things.
    Yep, at some point I just need to treat it like cancer surgery and slowly cut it out of the harness. Thankfully, the alarm wiring is pretty obvious due to the sweet clamp-on-wire connections.
    Yeah, I think I'd rather tackle a stereo, alarm or any other electrical job myself after seeing this.
    Deathbysnusnu likes this.
  10. Jun 9, 2017 at 6:12 PM
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    I started taking the head off my 3rz to put a new head gasket in.It is so long since I've been on here I can't even figure out how to post pictures.
  11. Jun 9, 2017 at 6:15 PM
    muddedtaco
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    IMG_0996.jpg I found out how too now, I haven't drove this truck in over a year, I hope it's the gasket and not the head. I'm going to put my header on I've had for a couple of years...I hope
    SwampYota likes this.
  12. Jun 9, 2017 at 6:28 PM
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    Any of you guys uninstalled a k&n and went to a stock intake set up? I'm having trouble removing this adapter piece that goes from my maf into the k&n filter. It has to come off but I don't wanna yard on it and break the maf. It's the piece on the right in the photo
  13. Jun 9, 2017 at 6:46 PM
    jubei
    NoCo
    Stuff. Also things.
    Anyone here disabled the DRLs on a 2002? Is it a pain in the balls?
  14. Jun 9, 2017 at 6:52 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
  15. Jun 9, 2017 at 6:53 PM
    Speedytech7
    Pretty sure it's just a single wire
    jubei[QUOTED] likes this.
  16. Jun 9, 2017 at 6:56 PM
    jubei
    NoCo
    Stuff. Also things.
    Thanks, fellas!
    Was the relay behind the driver side knee panel, @stumbles?
  17. Jun 9, 2017 at 7:16 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    theres a big ridge on that side of maf so its on tight but you should be able to work it off. its just slipped on there.
    Jebediah[QUOTED] likes this.
  18. Jun 9, 2017 at 7:27 PM
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    Well getting ready for tomorrow mornings LBJ and outer tie rod replacement. Should be fun....(lord have mercy on my sciatic nerve)
    w:ll:s and SwampYota like this.
  19. Jun 9, 2017 at 7:28 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Today I washed, clay barred and waxed it. Took off the janky front mud flaps and added a sticker.
  20. Jun 9, 2017 at 7:45 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thats super easy
