  1. Jun 21, 2017 at 8:06 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Ordered parts for the key lamp mod today.
    It will be my first attempt at fucking around with wiring. Will post aftermath of the carnage.
    Speedytech7 likes this.
  2. Jun 21, 2017 at 8:25 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Post them up here
    https://www.tacomaworld.com/threads...-nsfw-gore-ignore-the-kitty-thumbnail.396595/
  3. Jun 21, 2017 at 8:28 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  4. Jun 21, 2017 at 8:43 PM
    SwampYota
    Jon
    Floor mats
    Glad you made it out mostly unscathed.
    Edit: Nevermind, went and looked at the pictures. At least you got a day off work.:eek:
  5. Jun 21, 2017 at 8:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That is call the block height..well..sorta.
    Thats the maximum amount the coil can be compressed. Not really a max measurement for preload. But if you preloaded them so much that the coils touched each other at full stuff, you've got a problem.
    Your spring's block height is 7.02''
  6. Jun 21, 2017 at 9:03 PM
    cmj
    cmj Well-Known Member
    Tucson
    98 Tacoma 4x4
    Thanks.
    Where did you find that spec??
  7. Jun 21, 2017 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I ran that setup back in the day. Had a lot of weight too. Plate bumper with winch, full budbuilt skids, sliders, v6, yada, yada, yada. Those coils were not up to the task in the long run. Kept having to add more and more pre-load just to maintain height.
    I am now running 14", 3.0, 700# Kings which handle the weight just fine.
    BYJOSHCOOK, Speedytech7 and m3bassman like this.
  8. Jun 21, 2017 at 10:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Jun 22, 2017 at 6:12 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    These are the older coilovers correct? Just from looking at the pictures, they appear to have more shock body than the newer ones. Which will make it appear to have more preload, when in fact it is the same. You should measure the actual length of the coil at ride height and compare it to someone with the same coil on a newer SAW. I have the newer ones and can take a measurement, but my truck definitely weighs less than yours up front.
  10. Jun 22, 2017 at 10:52 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Installed that synthetic line. Pretty easy. Good thing I did, my old line was frayed. Sliced my damn beer gut removing the old line. Ouch
    Silver02Taco likes this.
  11. Jun 22, 2017 at 12:27 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    "Hub to fender" measurements are really only relevant for "before and after" or "over time" comparisons on the same truck.
    For your reference the pictured shocks below are the 1st pair sold of 7/8" shafted Taco SAW's. I ran them for 8 or 9 years with a 75 lb bumper with winch, steel rope, steel roller fairlead and 3/16" skids. Ride height was maintained at a hair over 2". They required 2 or 3 "corrections" of preload to compensate for initial settling/sag in the first few years then seemed to stabilize.
    Today they sit "as removed" as spares with the coils measuring a preloaded length of 12.5" pass and 12.25" driver. I have no idea what the free length is today (post settling). They are the "standard" Eibach (SAW red or Eibach silver) 14" 650 lb coils. SAW would sell them with other coils only on request. Within a few years a few folks were ordering them with 700 lb coils and "Tundra valving".
    Also of note, the upper poly bushing was known to crumble under the top nut/washer. This was not easily seen (on the truck) and would have the effect of reducing preload, frequently mistaken as coil sag.
    I have long forgotten the shock oil weight but someplace like https://www.kartek.com/ will know and sell it.
    As I understand it the shafts and the upper poly bushing are no longer available.
    jubei and jjsul like this.
  12. Jun 22, 2017 at 2:24 PM
    JKO1998
    Utah
    Went for a drive, forgot to take my hitch out, felt like I was almost stuck.
    Made it though
  13. Jun 22, 2017 at 2:27 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Went to flush my cooling system today and discovered that there was only water in it :eek: :eek: :eek: To say I was surprised would be an understatement!
    Now it's flushed and filled with Toyota Pink. I am amazed that this truck just drove all the way from 115 degree AZ and A/C on without a hiccup...
    ToxicTwin likes this.
  14. Jun 22, 2017 at 3:19 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Had my timing belt, water pump, thermostat, idler pulley, tensioner, cam seals, and drive belts, as well as oil changed yesterday. $700 total. All the parts that came off looked in great shape for 188k. Not sure if previous owner did it or not before. but couldn't find any indication that they were changed at 90k.
    Ready_already and 2002Tacoma4x4 like this.
  15. Jun 22, 2017 at 3:21 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    That's a mighty blue sky!
    2002Tacoma4x4 likes this.
  16. Jun 22, 2017 at 3:26 PM
    JKO1998
    Utah
    I turned the color up ha
    Captain Magma[QUOTED] likes this.
  17. Jun 22, 2017 at 6:24 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Bastard! I've been looking for some leather ones!
  18. Jun 22, 2017 at 6:27 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    What panel is that?
  19. Jun 22, 2017 at 6:39 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    SwampYota and Acerwin like this.
  20. Jun 22, 2017 at 6:46 PM
    cmj
    Tucson
    98 Tacoma 4x4
    started welding...
