  1. Jul 25, 2017 at 5:56 PM
    UncleShrek
    UncleShrek Well-Known Member
    Houston, Texas
    2016 SR5 V6 Auto
    TRD Pro mats, LED low beam bulbs OEM side steps, LED interior bulbs, Meso chrome delete, American tonneau cover, Replica TRD grill w/red letters, debadged, 30% Tint on door windows, 70% on windshield
    Truck was in the air 10 minutes, tops
    I like the look, I need a whole suspension redone. The bushings are non-existent
  2. Jul 25, 2017 at 6:03 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Basically a SPDT (single pole double throw) switch takes 2 12v+ sources and outputs only 1. The simplest ones will only have 3 terminals (2 input and 1 output). This completely isolates the reverse signal from your constant power signal so you are never feeding power into the reverse circuit.
    I bookmarked this from another forum a long time ago:
    http://losdos.dyndns.org:8080/public/tacoma/tacoma-backup-lights-wiring2_sm.jpg
    ChadsPride likes this.
  3. Jul 25, 2017 at 6:47 PM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    Looking at this diagram, I'm 100% planning on using an OTRATTW switch as thats what all the others are. Do you happen to know if you are able to use one of those for this application?
  4. Jul 25, 2017 at 7:12 PM
    nzbrock
    Noah
    San Marcos, TX
    It just has to be a double throw switch, I know they make a lot of different switches. Sometimes they call these "on-off-on" or 3 position switches.
    kamaaina1 likes this.
  5. Jul 25, 2017 at 7:15 PM
    TuckGraham
    Tg
    Montana
    Great a million thanks for this info! I really appreciate it!
  6. Jul 26, 2017 at 3:49 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Watched my ScanGauge this morning on the interstate to finally see what the temperature was at.
    In town running 45-60 mph it ran between 193-198F. On the interstate between 60-75 mph it ran between 195-202F, peaking at 204F sitting at a stop light on the off ramp.
    No A.C. running, no load in the truck, 72F outside temp.
    I went searching on Tacoma World and I see people posting temps anywhere between 180-202F so mine's running at the high end. I'm a little concerned what will happen if I ever pull my boat (another project) if that's where I'm running on a good day.
    Thermostat and water pump were changed in December at Toyota so I should have their brand new fluid and I changed my fan clutch in April. I guess I need to dig deeper and see what the exact temperature range should be for the 5VZFE.
  7. Jul 26, 2017 at 5:41 AM
    TACO MASTER
    TACO MASTER Well-Known Member
    Maroon 1996 Tacoma SR5 V6 4X4
    OME front and rear suspension, ABR deluxe bull bar, Black FJ 17 inch SEMA wheel with treadwright 265/70/R17 E, Bushwacker fender flares, Stock rear bumper, Eagle 4 wheel camper.
    Well the rig is still getting the frame issues taken care of. It had a good look over and the bad is gone. Welding in new C channel frame splice and then plating it up on both left n right side of the frame.
    ChadsPride, SwampYota and BYJOSHCOOK like this.
  8. Jul 26, 2017 at 5:56 AM
    SwampYota
    Jon
    Floor mats
    Thanks for the recommendation!
  9. Jul 26, 2017 at 5:57 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Mine runs around 200F. New tstat, radiator and I flushed the system recently. I tow my landscaping equipment every week with no overheating issues.
  10. Jul 26, 2017 at 6:04 AM
    SwampYota
    Jon
    Floor mats
    200F with or without a trailer with landscaping equipment?
  11. Jul 26, 2017 at 6:25 AM
    kamaaina1
    kamaaina1 Well-Known Member
    Sean
    Vancouver, WA
    2004 TRD Tacoma x-cab
    X2 Just had one installed this week. Activated in reverse, Off, and manual On. DPDT all the way!! Call Jim at OTRATTW. Big help!
  12. Jul 26, 2017 at 8:36 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Americandad, Dalandser, Teke and 2 others like this.
  13. Jul 26, 2017 at 10:27 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Both. I am going to do my timing belt here within the next month the water pump will be done then as well to hopefully get the temps down a bit. Next on the cooling list is a trans-cooler.
    SwampYota[QUOTED] and ChadsPride like this.
  14. Jul 26, 2017 at 11:02 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    SwampYota and ChadsPride like this.
  15. Jul 26, 2017 at 3:36 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Just make sure its not momentary, that means it only stays on while you have it pushed down
  16. Jul 26, 2017 at 3:47 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Removed the running boards I bought the truck with. Looks much better now.
  17. Jul 26, 2017 at 7:07 PM
    Cjg0804
    Cjg0804 New Member
    Connor
    1998 tacoma white
  18. Jul 26, 2017 at 7:23 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Checkin the cameras and on camp.
  19. Jul 26, 2017 at 7:24 PM
    DailyDriverFresno99
    DailyDriverFresno99 Active Member
    99 SR5 V6 4WD
    2.5" OME lift. Sweet Decals. Dashboard Hula Girl.
    After putting on the OME lift and new KO2's in the last two weeks, today was alignment day. It WAS alignment day... until the alignment guy called to say the front right bearing that was JUST installed a couple months ago wasn't as it should be. So today, nothing interesting happened to the Taco today, other than making another appointment with the shop to have them re-do the wheel bearing...:annoyed:
    Someone beer me....
  20. Jul 26, 2017 at 9:26 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    :cheers:
    sucks when that crap happens... give them hell and have them kick back some cash. Not cool at all.
    Dalandser and ChadsPride like this.
