  1. Aug 1, 2017 at 6:22 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    If you have power to everything else, start with your starter
  2. Aug 1, 2017 at 6:24 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    Just try smacking it with a hammer ? Do you do that while cranking it or can it just be done prior too ?
  3. Aug 1, 2017 at 6:25 PM
    Penten
    Peter
    Iowa
    Will do thanks , yeah all my gauges light up and everything , this is post frame swap so it very well could be a harness I suppose
  4. Aug 1, 2017 at 6:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Either, but I've found it works best with a helper.
  5. Aug 1, 2017 at 6:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    could be a grounding problem too.
  6. Aug 1, 2017 at 6:35 PM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Are the spark plugs in the 5vz pretty easy to change without breaking or stripping anything out?
  7. Aug 1, 2017 at 6:52 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    I also did the same and they turned out great. Mine were done about 6 months ago and still look great.IMAG0003.jpg
  8. Aug 1, 2017 at 6:56 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Yeah but you'll need a few extensions for the driver side
  9. Aug 1, 2017 at 7:46 PM
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    Caught a stellar Colorado sunset last night
  10. Aug 1, 2017 at 7:59 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Do you find that your swingout spindle and latch block your taillights? I'm thinking about changing my latch to the 4xinnovations setup, seems like it will block the light quite a bit though.
  11. Aug 1, 2017 at 8:01 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Yea. Synergy makes some awesome products, but this Winter I'll be cutting off my currently swingout and building dual swingouts with some stuff from Relentless Fabrication. Also going to add some side protection.
  12. Aug 1, 2017 at 8:59 PM
    Okiyota
    Okiyota Well-Known Member
    Breckenridge, CO
    2001 Dbl Cab
    2.5" Icon ext travel coilovers, Icon uniball UCA's, OME Dakar's, Icon 2" rear shocks, 285/70/17 Maxxis RZR MT's, 17" SCS Copper Ray 10's, Shrockworks front bumper, CBI rear high clearance bumper, Bash Fab sliders, Shrockworks full skid plate set, rear frame plated, All Pro u-bolt flip kit, Wheeler's Super Bumps, VisionX LED's...
    Thanks! Not exactly sure on how big the gap is "supposed" to be and I imagine it could vary based on how much weight you have on the rear and whether or not you have frame plates etc, as that could change the amount of flex you get back there. My plan is to leave somewhere around 1/4" (no less) and see how it does, I'll go carefully twist it up really good and watch it to see if its enough, if not I'll add more.
    I did not reinforce the rear bedsides, it is a little less rigid but I don't think its enough to worry about?
    Well since you asked for better pics of the rig...
    I got some more done today and got it out of the garage!! Installed new front rotors and pads (just oem replacements), got a new rear brake line made and installed to fit around the new lower shock mount on the driver side, flushed the remaining brake fluid out of the system and refilled/bled them, they feel great now! Also got the ebrake properly adjusted so it actually works like its supposed to. The PO had it so loose and so much slack in it that it wouldn't engage the rear shoes at all when you pulled the handle, pulls nice and solid now and locks the rear wheels great. I then spent a bit getting everything that I've installed front to rear properly buttoned up and torqued preparing for its first drive!
    Also called and setup an alignment for tomorrow afternoon. I know I'll have to redo it once i get the front bumper/winch/skidplates/etc on and have to readjust the front coilovers for proper ride height but I've got family coming into town this weekend and want have it driving while there here.
    I decided to wait on the skid plates install until very last so that i can get underneath and keep an eye on things for a week or two without having to drop them and reinstall them.
    First time out of the garage with the most recent work done...
    We then took it for a drive to check for any noises, vibrations, weirdness etc which there were none, it drove just fine! While we were out I decided to go ahead and pick up the front bumper from the UPS freight facility instead of waiting for it to get delivered since the only come up to my area once a week...
    Took a few more pics while it was sitting in the driveway before I unloaded the bumper...
    One of the front bumper off the pallet. I have to weld in some light mounts and "sleeves" on the backside of the fog light cutouts, then it will get dropped off at powder coat. Cant wait to see it on the truck!!
  13. Aug 1, 2017 at 9:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn, i thought my copper ray10s looked good with the green. Killer with the red.
    Also...that bumper looks to missing frame mounting points...or is it just me?
  14. Aug 1, 2017 at 9:33 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Finally finished rebuilding & revaulving my racerunners 2.5s. Now to find time to install them...
  15. Aug 1, 2017 at 9:43 PM
    BlackPearl
    Alex
    Toyota Tacoma TRD
    That's awesome. Looks really good. I'm thinking of doing the same with mine.
    You should do a build thread or a upload some progress of the build to help out new-bees like me lol :D
  16. Aug 1, 2017 at 9:49 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Okay, so I picked up my glass from Mcneil Racing on my lunch break today and pulled apart the front end when I got home from work and started in on the driver side fender...
    What a pain in the ass.
    A lot more involved than I had originally anticipated. I knew it wasn't exactly plugNplay but shit. After some sanding, trimming, and drilling spot welds I got it lined up and mounted. (Except for the light) I'll be back at it again Thursday for round 2. Here's where I left off tonight...
  17. Aug 1, 2017 at 10:35 PM
    Tacofart
    Tacofart Well-Known Member
    Brennan
    San Diego
    04 3.4 4x4 Dual cases/ Lockers
    My buddy just bought an SAS with dual cases. Got a great deal on it cause the rear diff grenaded, so we pulled the axle shafts and 3rd member to find the pinion was toast, but ring gear unscathed. Also traded him my old icons (d.r.) for his brand new kings plus a little cash. A win win situation for both us haha.
  18. Aug 1, 2017 at 11:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i spy a wildernest....
    Love those things.
    Reh5108 and Tacofart like this.
  19. Aug 2, 2017 at 4:39 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    What springs are you running? Your shackle angle looks similar to mine and I have lift shackles. I'm still waiting to see if my leafs will settle enough where I can leave them in or not.
    ChadsPride likes this.
  20. Aug 2, 2017 at 5:11 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
