  1. Aug 2, 2017 at 6:39 PM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Going to be ordering new suspension in a couple days, want a new lift up front with rear shocks and I'm curious as to what I should go with or if I should go with the Toytec coilovers.
    ChadsPride likes this.
  2. Aug 2, 2017 at 6:43 PM
    SwampDeer
    SwampDeer Active Member
    99 Tacoma 4x4
    3 inch lift.
    Synthetic oil change and changed gear oil in the manual transmission.
  3. Aug 2, 2017 at 7:01 PM
    TacomTyler
    Tyler
    Georgia
    2000 sr5 tacoma
    Pretty easy to change the gear oil in the trans? Need to do mine
  4. Aug 2, 2017 at 7:10 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    go with ADS
    Silver02Taco and Kittenmittens4U like this.
  5. Aug 2, 2017 at 7:12 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    So, you chose something different? ;)
  6. Aug 2, 2017 at 7:20 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Was catching up on @SeekingZero's build and decided to check torques on my LBJs.
    Added torque stripe for easy visual checking if those bastards start to migrate...
  7. Aug 2, 2017 at 7:50 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Well, I kind of need to get the guts to get them first. Havnt even called my tire shop to see if they can get them...not sure what I'm waiting on
  8. Aug 2, 2017 at 8:02 PM
    Phessor
    Phessor Well-Known Member
    It's starting to come together...
    Now just need to find the time to put it on!
  9. Aug 2, 2017 at 8:07 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's basically just an assist spring to help with opening and closing right at the hinge point. Kind of reminds me of the coiled spring to lift up a hood. I think a strut would be better at controlling it. I'm just not really familiar with the geometry you would need for a strut. Do they work well going full 180? It would probably need to be external too
    I definitely agree with that. I've toyed with the idea of trying to bring them back and having them right in that price range. I think they are the cleanest looking of the flip open topper tents when closed. The flip package and habitat look more like pop up campers.
  10. Aug 2, 2017 at 8:19 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    Really want that whine box :drool:... someday...
    Go with CVJ axles?
  11. Aug 2, 2017 at 8:29 PM
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    Well my 15 year old window motor finally took a crap today. Luckily @nzbrock had a spare one! Thanks again man!
  12. Aug 2, 2017 at 8:32 PM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Where does one even purchase ADS shocks for a first gen? My Google-fu has turned up nothing, I'm on the fence between Kings or Fox and really want to price out some ADS coilovers as well.
  13. Aug 2, 2017 at 9:12 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I bought mine from Matthew at MCM Fab out of Nevada. But I live in Tucson so I was able to pick them up from the shop which is here locally.
  14. Aug 2, 2017 at 9:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  15. Aug 2, 2017 at 9:13 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Oh hands down its the best looking topper camper thing. I really like em.
    Interesting. Would love to see yours someday. I think they are cool.
    @M C M fab sells them. DSM too.
  16. Aug 2, 2017 at 9:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    This guy will hook you up.
  17. Aug 2, 2017 at 9:36 PM
    Kittenmittens4U
    Sam
    Denver, CO
    Thanks guys! I don't know how I missed those on DSM's site, and I'll have to email MCM about availability.
  18. Aug 2, 2017 at 10:15 PM
    ShakeTaco
    ShakeTaco Member
    Las Vegas
    04 Tacoma TRD 4X4 3.4L
    K&N intake, Airade Tbody spacer, King Shocks w/ Remote Resi, Front King Coilovers, 285/75/16 BFG KM3, American Racing Victor Teflon coated wheels, Hawk LTS pads, Hawk Sector 27 rotors
    Broke a rear shock
  19. Aug 3, 2017 at 12:17 AM
    SeekingZero
    SeekingZero Well-Known Member
    Ben
    Sierra Mountains, CA
    01 Xtracab 4x4 SR5 TRD Supercharged
    Another option that I did for this last trip was to buy new thick lock washers. That way I can help prevent them from backing out and I can look at the lock washer and see if its not flat. Marking them is a good idea, but hard to see when I'm wheeling hard through the mountains.
    jubei[QUOTED] likes this.
  20. Aug 3, 2017 at 3:37 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I don't think a wildernest could survive the abuse you put Frank through. Granted you aren't hucking frank yet, but I can't see any fiberglass top lasting to long on an LT truck. Wildernest belongs on Igor. :p
    Yeah I noticed that this weekend that it was harder to check my marks after wheeling, but it was nothing a paper towel couldn't fix.
    jubei and ChadsPride like this.
