  1. Aug 11, 2017 at 3:19 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Reaaaalllyyyyy cheap. Everything all in all should be costing around $1,500.
    That's why I drove to the next state over. Here in California, the average price (I did averaging for 10 Toyota scrappers and general junkyards) and the average cost was $600 for an A340F without the transfer case. This junkyard in Nevada only charged me $250 Plus a $15 core charge for the transmission.
    I bought my complete transmission, transfer case, front Differential, shifter assembly, trim, and 4WD mudflaps from them for a little under $1,000.
    The other stuff like the driveshafts, and knuckle/manual hub assemblies is what consist of the other $400-500 and I have them lined up through the great people here on this forum.
    Do your research, you will find a deal. I saved almost $2,000+ buying parts from a junkyard with the lowest prices instead of buying in my state. Nevada also has a really low sales tax versus California with the 10% sales tax.
    What I did was have a spreadsheet with 5-10 different junkyards, online sources, etc and found the cheapest prices that I could. I then narrowed it down to the junkyard who had all the items I needed at the cheapest price, which narrowed it down to a yard in Reno. If I went to the Toyota specialized truck dismantler in Sacramento, I would've paid well over $3,500 for this stuff with all the core charges and tax. Just do your research and you'll do fine.
    SwampYota and Area51Runner like this.
  2. Aug 11, 2017 at 4:32 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That won't help any, only at ride height and if it clears now it'll clear better with all of that. Best way to trim is take out the shock and jack up the LCA until its at full bump and then turn side to side and clear it that way. It's what I had to do for mine and it clears just about everything, hopefully a new alignment can help it out on the driver side.
    nagorb likes this.
  3. Aug 11, 2017 at 4:45 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    This truth is why I am sad that the reason I swapped mine out was because of this, and not some rebuildable reason. I still have these lying around, but tbh I don't really trust them.
    jjsul likes this.
  4. Aug 11, 2017 at 6:37 AM
    Okiyota
    Okiyota Well-Known Member
    Breckenridge, CO
    2001 Dbl Cab
    2.5" Icon ext travel coilovers, Icon uniball UCA's, OME Dakar's, Icon 2" rear shocks, 285/70/17 Maxxis RZR MT's, 17" SCS Copper Ray 10's, Shrockworks front bumper, CBI rear high clearance bumper, Bash Fab sliders, Shrockworks full skid plate set, rear frame plated, All Pro u-bolt flip kit, Wheeler's Super Bumps, VisionX LED's...
    Yep, thats the plan, get the front bumper and winch and everything else on so i can set the coilovers where i want them for ride height, then take it to full bump and find out where it rubs lock to lock and cut it all away. Not sure what you were referring to when you said "that wont help any, only at ride height..." What wont help?
  5. Aug 11, 2017 at 6:46 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I thought you were going to wait until you get that extra weight up front, but setting the ride height won't affect any of the rubbing right now if it doesn't rub (unless stuffed). If you full bump it now and cut it'll clear perfectly fine when you get the bumper. So in a sense it won't matter if you wait for the bumper or do it now, full bump is the "worst" rubbing you'll get regardless of extra weight
    jubei likes this.
  6. Aug 11, 2017 at 6:54 AM
    Okiyota
    Breckenridge, CO
    2001 Dbl Cab
    Right on, now I'm see what you were saying, we were on the same page.
    But yes, everything clears at ride height now, (although my ride height will probably change once it gets the winch and bumper, hence needing to readjust the coilovers) and making room for everything at full bump will for sure allow it to clear at ride height!
    jubei and BYJOSHCOOK[QUOTED] like this.
  7. Aug 11, 2017 at 7:04 AM
    HoldTheMayo
    HoldTheMayo Active Member
    Does anyone know of a write up on putting led lights in the bed?
    I'm looking to removed the liner, prep the led install (drill any holes), get a spray in bed liner and then install them.
  8. Aug 11, 2017 at 7:12 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yup same page now! :thumbsup:
    But yeah that added weight will need the right height changed. Just take before and after measurements and you'll be set
  9. Aug 11, 2017 at 7:56 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    I love my clutch. Lce is an awe some company. Their bearing they supply are oe, I verified that when I got them. Only complaint I have with my dual compunder clutch from them is the noise when cold... squeaks. But a wise man once told me: race car parts make race car noises. Live with it.
    The heavier fly wheel makes bogging the engine when crawing so easy... does slow the truck down tho, wont gain rpm as fast
    jubei likes this.
  10. Aug 11, 2017 at 8:01 AM
    tony2018
    tony2018 Well-Known Member
    Took a look at some of the oil pan bolts, rust building up. Damn..gotta take care of that.
  11. Aug 11, 2017 at 8:10 AM
    kamaaina1
    kamaaina1 Well-Known Member
    Sean
    Vancouver, WA
    2004 TRD Tacoma x-cab
    My 04" temp gauge is right around that level since new. Always thought it was a bit high, but that's a normal reading level.
    ROlla-Xrs[QUOTED] and Sicyota04 like this.
  12. Aug 11, 2017 at 8:52 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Same here.
    ROlla-Xrs likes this.
  13. Aug 11, 2017 at 9:19 AM
    jp199
    jp199 Well-Known Member
    JP
    Bend, OR
    08 Access Cab TRD off road
    Icon progressive 3 leaf, Fox 2.5 RR coilovers, camburg uca, Fox 2.0 RR w/ LSC
    Mob Armor! Best stuff out there and its my buddy's company
    Omicron6 and gray223 like this.
  14. Aug 11, 2017 at 9:26 AM
    HoldTheMayo
  15. Aug 11, 2017 at 10:18 AM
    tony2018
    I guess I'm in the same boat. I thought it was odd too because of where my gauge needle is on my civic. Good to know.
  16. Aug 11, 2017 at 10:22 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Return to the Oregon Backcountry Discovery Route
    Back in May, we'd attempted to run the northern 40% of the Oregon Backcountry Discovery Route, from Seneca to the Washington border. A day in, we chose a more reasonable goal: Seneca to Unity. And at day three, we called it quits - less than 50 miles from our start point.
    So you can imagine that we were excited for a second chance. Redemption as it were.
    I'll be posting the story and pics a day at a time - a lot happened, and there are some 300 pics to get uploaded and worked in to the story. Enjoy!
    jjsul, Prayn4surf, jubei and 8 others like this.
  17. Aug 11, 2017 at 10:25 AM
    tony2018
    NEVER GIVE UP!!
  18. Aug 11, 2017 at 10:32 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    famous last words? :boink: :anonymous: :)
    Jaysjammin likes this.
  19. Aug 11, 2017 at 10:45 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Armed with Toyota's greatest generation of Tacoma, a chainsaw, and family; you should be able to fjord any swift river with confidence....
  20. Aug 11, 2017 at 12:49 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    How do you secure your toolbox now that you have glass bedsides? Also where'd you find that hood?
    Dalandser likes this.
