  1. Aug 16, 2017 at 8:58 PM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Guilty of that, it's one of the first things I did to my truck, that and the airaid. Both were a giant waste of time and money although I do like the sound of the airaid. I can't even get my deckplate to screw on, it's probably warped or something and once I get around to pulling the box and getting it on its staying on!20170806_195628.jpg
    Speedytech7[QUOTED] likes this.
  2. Aug 16, 2017 at 9:03 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I had to pull my entire dash out and replace most of the body harness. I guess the 95 4 cyl body harness has the same ecu plug as the 96 V6, but pinned completely differently. You've been warned.
  3. Aug 16, 2017 at 9:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You guys were right of course.
    Remebered to crawl under it today. Both hard lines come forward on the passenger side and at the front of the oil pan they split to go to either side, then a rubber hose goes to the radiator (if you are stock) and the aftermarket trans cooler in my case.
    So, the return line goes to nearly the back end of the trans. The hot/fluid out port is the front one of the two ports.
  4. Aug 16, 2017 at 9:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's exactly what I was both afraid of and expecting haha. I have been checking my colors and pinout diagrams religiously, my newest plan is use all of the wiring from my original truck because at this point there is no reason not to and it would save zero time to repin manually.
    Dalandser likes this.
  5. Aug 16, 2017 at 9:16 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Wheel bearings seized today after dropping off my kid at school. Fackkkk. Hopefully shes done tomorrow. I have plans to use her this weekend
  6. Aug 16, 2017 at 9:16 PM
    Speedytech7
    Like couldn't move, or became so hard and noisy to move you decided to stop?
  7. Aug 16, 2017 at 9:18 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Can't say I've heard of wheel bearings seizing! If they were that bad they had to be noisy as hell.
  8. Aug 16, 2017 at 9:25 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    So i took my kid to school and he goes "dad, we shouldnt go camping this weekend because the truck sounds horrible". I figured it would go away...lol.
    Limped to my buddies shop after seeing hella smoke. Turns out both bearings and one of my rotors are fuxked. pads got ruined too. Luckily @bayareataco and @Robmonster117 hooked me up with a setup on brakes. Good to go tomorrow.
    Wheelin pics this weekend ;)
    Silver02Taco and jubei like this.
  9. Aug 16, 2017 at 9:27 PM
    Digiratus
    Roaming the PNW
    The RedHead
    wut??
    Speedytech7 likes this.
  10. Aug 16, 2017 at 9:29 PM
    Speedytech7
    :confused:
  11. Aug 16, 2017 at 9:30 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  12. Aug 16, 2017 at 9:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I couldn't figure out what @Fernando was trying to say. :notsure:
    And @Madjik_Man is going to have a field day with this. VVVVVVV
    jubei, fiziks, SwampYota and 3 others like this.
  13. Aug 16, 2017 at 9:35 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    My phone is being stupid. Op udated
  14. Aug 16, 2017 at 9:36 PM
    Speedytech7
    Everything I force out of my mouth can be used as a double entendre.
    jubei and Digiratus[QUOTED] like this.
  15. Aug 16, 2017 at 9:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah thats who i was pointing at :p
    Digiratus[QUOTED] likes this.
  16. Aug 16, 2017 at 9:36 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Could still move but hella smoking...lol
  17. Aug 16, 2017 at 9:37 PM
    Speedytech7
    That's not a stopping sign, just a heads up that you need 100% more lube.
    jubei, Dalandser and Digiratus like this.
  18. Aug 16, 2017 at 9:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    wow.
    Your fronts??
    Never heard of that. My rear one literally exploded though. But never smoked.
    [​IMG]ImpromptU-Ah-31.jpg by Monte Nickles Photos, on Flickr
    Never found the missing balls from the bearing..
    Silver02Taco and Dalandser like this.
  19. Aug 16, 2017 at 9:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Uh....WOW!
    Yeah, if the tire was dragging, that might cause a little smoke. :rolleyes:
  20. Aug 16, 2017 at 9:39 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thats what she said....
    Jk...where at? In the bearings? ?
