  1. Aug 18, 2017 at 1:45 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Got it. So silicone is an option for the other hoses - what is the benefit? Longer lasting?
  2. Aug 18, 2017 at 1:48 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Does the hose end in the core support right there? What is that filter on the engine - it looks bigger than a stock one although I haven't taken mine out of the box yet - too busy with other stuff atm.
    Edit: On my computer now and it looks like a regular size filter. :)
    tcBob likes this.
  3. Aug 18, 2017 at 2:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Retains it's elasticity well and can be routed easily. Plus it comes in different colors
    Dalandser[QUOTED] likes this.
  4. Aug 18, 2017 at 3:02 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Sorry for asking here!
    Does anyone have their antenna assembly that they are not using? My antenna broke inside the mast and I don't want to pay for a new one if I can find a used one here. Thanks guys.
  5. Aug 18, 2017 at 3:30 PM
    Speedytech7
    I have one off my rolled truck if you want it. The antenna is bent but the holder is good.
    quetzal[QUOTED] and Dalandser like this.
  6. Aug 18, 2017 at 5:38 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Ok, I need some diagnosing. It's not the taco, it's the GF's 2003 dodge B2500 camper van. We are experiencing traffic related overheating issues. On the highway, or moving at a constant rate all is fine. Stop and go traffic and the temp gage rapidly climbs to the high end. After a couple minutes at speed, it rapidly plunges down to normal. On the temp gage, slightly under vertical, it's around 200, high is about 250.
    When 1st noticed and we pulled over the coolant overflow tank was very low, it has since been filled. Oil was maybe a half quart low. Coolant and oil additions are not helping.
    We parked for an hour, drove highway for 10 minutes, exited and after 5 minutes looking for parking, it was back up again.
    To me, this sounds like poor coolant circulation at low speed or idle. Is this the water pump?
    EDIT: solved, low coolant. DOH!
  7. Aug 18, 2017 at 6:17 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    check and make sure your radiator fan is working right, classic sign of that. Water pump usually would cause temp to rise under acceleration because its not able to keep up flow with the load.
    Jaysjammin likes this.
  8. Aug 18, 2017 at 6:42 PM
    KeptOnChooglin
    Phil
    Houston, TX
    Its even simpler, radiator low, I thought it would draw from overflow. FAIL.
    so simple, doh!
    Dalandser likes this.
  9. Aug 18, 2017 at 6:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Keep an eye on that - that coolant is going somewhere unfortunately.
  10. Aug 18, 2017 at 7:10 PM
    tony2018
    tony2018 Well-Known Member
    umm where does it go inside?
  11. Aug 18, 2017 at 7:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Painted my trans tunnel
  12. Aug 18, 2017 at 7:31 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah just ends deeper in the fender, essentially where the windshield drains to.
    See above. Just a more protected place to get the air intake from.
    jubei and Dalandser[QUOTED] like this.
  13. Aug 18, 2017 at 7:45 PM
    tony2018
    Hmm....might as well feed it inside to get cooler air. huehuehue....
  14. Aug 18, 2017 at 7:49 PM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
  15. Aug 18, 2017 at 7:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nice looking dog.
    jubei likes this.
  16. Aug 18, 2017 at 7:54 PM
    taco71742
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    I appreciate it bud!
  17. Aug 18, 2017 at 8:11 PM
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    Nice
  18. Aug 18, 2017 at 8:22 PM
    Speedytech7
    Looks nice, i didn't clean there on mine, it was in pretty decent shape I think.
  19. Aug 18, 2017 at 9:00 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I just wire wheeled it and wiped it down with acetone. Figured I'd get'r cleaner under there while I could reach it. There was an arc of oil clumps above the first driveshaft u joint. Wire wheel took care of that quick like and the rest just had salt and dirt residue from 10 years of off-roading trips without washing the underside.
    Rustoleum Professional Spray paint is the bomb for this. Tall cans of really durable paint that spray upside down until almost empty for $5 at wally's world and $6 at HD.
    jjsul and boostedka like this.
  20. Aug 18, 2017 at 9:16 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think you're onto something here - crank the ac and put it right in front of the vent!
