  1. Aug 26, 2017 at 7:44 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    nagorb[QUOTED] likes this.
  2. Aug 26, 2017 at 8:08 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Don't think so.
  3. Aug 26, 2017 at 8:20 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    32 brah
  4. Aug 26, 2017 at 8:22 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I was damn close
    Man I am good !
    Fernando[QUOTED] likes this.
  5. Aug 26, 2017 at 9:33 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
  6. Aug 26, 2017 at 9:35 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Fuck you old man geezer! 31 and 3 weeks brah!
  7. Aug 26, 2017 at 9:41 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I went wheelin at MIOBI with the Tall Corn guys. It was a great time. Learned a few things that I need to change on my truck and meet a bunch of new people. I may post some pics tomorrow but for now I'm calling it a night...
  8. Aug 26, 2017 at 9:46 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I'm currently running 315/75/16 MTRs. The 7069's have a 4" BS in the 16" flavor, I have 1" spacers in the front but I used to have 255/85 KM2s on those wheels with no spacers and they fit just fine. What size tires are you planning on running?
  9. Aug 26, 2017 at 10:45 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Just did 300,000 mile service
    -cleaned engine bay (filthy from leaking valve covers and dusty roads)
    -timing belt kit: water pump, idler pulleys, plugs, wires, drive belts, pcv valve, thermostat, fuel filter
    -all new vacuum hoses
    -new coolant hoses: radiator, oil cooler, IAC, heater
    -coil pack boots
    -crank and cam seals
    -valve cover and plug tube gaskets
    -checked valves, amazingly all still within spec!
    -coolant bypass pipe
    -intake and plenum gaskets
    -coolant flush, back flush radiator and engine block
    -oil change
    -Redline Mt-90 in the transmission and t-case
    -Redline 75-90 in the diffs
    Kicked my ass, took about 20 hours, but feels like a new truck.
    When I get some time I plan to do a compression test
  10. Aug 26, 2017 at 10:46 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Out and bout today lookin for elk
  11. Aug 26, 2017 at 11:59 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'm currently running hancook 295/75-16s and stock wheels with 1.25 spacers. Why I really want new wheels is to get rid of the spacers.
  12. Aug 27, 2017 at 7:08 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Take apart you shifter and look at the shifter bushing and that whole assembly. There might be some debris in it.
    Crock112[QUOTED] likes this.
  13. Aug 27, 2017 at 8:18 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    It's unfortunate that all OEM wheels have such high backspacing, as they are far stronger than most aftermarket wheels (and you already paid for them). Replacing forged wheels with vacuum cast aluminum or stamped steel wheels is kinda silly when you think about it. I'm of the opinion that a quality wheel spacer, installed properly and checked regularly, is not a probable failure mode and adds no additional load to wheels bearings, etc. compared to a wheel with the same net backspacing.
  14. Aug 27, 2017 at 9:46 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    High water mark from last night on the rear tire.
    kamaaina1 and SwampYota like this.
  15. Aug 27, 2017 at 9:55 AM
    TrailRider2002
    TrailRider2002 Well-Known Member
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    -3in old man emu suspension lift with 882 coils, nitro chargers and rear add a leaf -1in Daystar Body lift -295/75 BFG KO2'S -flowmaster dual 40s
    Here's how it's going to sit for a while since college started
  16. Aug 27, 2017 at 11:24 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Love that front bumper, so clean and simple...brand?
    Good luck with school.
  17. Aug 27, 2017 at 11:33 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    My reason for wanting to ditch the spacers is they're a pain to take off, plus obviously looks.
  18. Aug 27, 2017 at 1:19 PM
    TrailRider2002
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    Thanks man it was a custom one a local guy did I traded him my tool box for it
  19. Aug 27, 2017 at 3:08 PM
    BlackBeauty04
    BlackBeauty04 Well-Known Member
    Justin
    Lynchburg, VA.
    2004 SR5 / 2018 TRD PRO
    Finally got around to rotating the tires.
  20. Aug 27, 2017 at 4:12 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Played with some Plastidip today...
