  1. Sep 3, 2017 at 4:23 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Measured both x cab and standard cab doors.
    Both measure 45 3/8" at their widest point.
    Dalandser likes this.
  2. Sep 3, 2017 at 4:44 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Thank you man. I was going off of the second gen doors that change size from one cab size to another. Man Toyota kept it simple on the first gens.
    koditten[QUOTED] likes this.
  3. Sep 3, 2017 at 4:58 AM
    koditten
    Kirk
    Central Michigan
    Does a 96 actually have anti lock brakes?
  4. Sep 3, 2017 at 7:00 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    I don't think so. That I know of.
  5. Sep 3, 2017 at 7:45 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    My 95 does not
  6. Sep 3, 2017 at 7:58 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    all years including 95.5 had option of abs. mine has it.
  7. Sep 3, 2017 at 9:11 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Its a Suzuki
  8. Sep 3, 2017 at 9:27 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Okay how should I go, about my problem?
  9. Sep 3, 2017 at 9:32 AM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    https://www.obd-codes.com/p0500
    A good first step to do as a vehicle owner or DIYer is to search for technical service bulletins (TSBs) for your particular vehicle make/model/engine/year. If a known TSB exists (as is the case for some Toyota vehicles), following the instructions in a bulletin can help you save time and money in diagnosing and repairing your issue.
    Next, visually inspect all wiring and connectors that lead to the speed sensor. Look closely for any chafing, bare wires, broken wires, melted, or otherwise damaged areas. Repair as required. The location of the sensor depends on your vehicle. The sensor could be on the rear axle, transmission, or perhaps the wheel hub (brake) assembly.
    If the wiring and connectors are OK, then check the voltage at the speed sensor. Again, the exact procedure will depend on your make and model of vehicle.
    If everything looks OK, replace the sensor.
  10. Sep 3, 2017 at 9:37 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Thank you!
  11. Sep 3, 2017 at 1:07 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Finally installed replacement bug deflector from EGR. Noticed after I opened they sent me the HD version instead of the clear smoked color deflector.
    Dalandser and SwampYota like this.
  12. Sep 3, 2017 at 1:12 PM
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    Gave er a wax job
  13. Sep 3, 2017 at 1:42 PM
    Americandad
    Americandad Active Member
    Scott
    Marquette MI
    99 Tacoma under construction
    Got a bunch of welding done today, it's going to be stronger than new guaranteed and should last a long time. Might even park it in the winter, it's a third vehicle for us so we don't need to drive it all year.
    Now off to camp, drink some beer, light the sauna and take a swim. :cheers:
  14. Sep 3, 2017 at 1:50 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    thats a damn fine job there. Might be undertaking the same thing if work will sell me the 98 plow truck they have.... frames rotted through, 46k on her though
    opteron, Dalandser and Speedytech7 like this.
  15. Sep 3, 2017 at 1:52 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Feel like a cyborg popping out suspension components. I am not a huge muscle bound dude so this shit gives me a run for my money...
    Those UCA bolts are no joke... Also found out the PO of the grey truck replaced the LCA bushings with energy ones so IDK if I wanna go through with swapping to whiteline since the hard/stupid job of burning the old bushings out was already done.
  16. Sep 3, 2017 at 1:56 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Finally got around to rebuilding and mounting this winch i picked up, Xp 9.5.
    Now Im figuring out where to mount my electronics. Im trying to avoid unecessary long power cables but also dont want to cut my grille to bitz.
  17. Sep 3, 2017 at 1:57 PM
    Speedytech7
    Mount to your inner fender it's fine to have your power be that long and it'll save your solenoid box
  18. Sep 3, 2017 at 2:06 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Up near the booster you think? Id like to save the other side by the cruise control for a compressor. Im playing around and seeing what works
  19. Sep 3, 2017 at 2:12 PM
    Speedytech7
    Nah, that's a bit too far, I had mine right behind the air box and it was great
  20. Sep 3, 2017 at 2:39 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    bumper painting
