  1. Sep 14, 2017 at 8:01 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    FTFY ;)
    Robmonster117[QUOTED] likes this.
  2. Sep 14, 2017 at 8:08 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Tag me in your post ill try and pull up some pictures this weekend to help you out as best I can. its not overly complicated, not easy, but very doable. 1st thing is to start looking for anyone about to or currently doing a SAS and snag the crossmember.
    jubei likes this.
  3. Sep 14, 2017 at 8:36 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :wave:
    How's things, Rob?!
  4. Sep 14, 2017 at 8:49 AM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Doin alright man! Schools keepin me busy and keeping me from my truck unfortnately. But Ill keep gathering more parts till I find a day to work on it.
    Hows things over there?
    jubei[QUOTED] likes this.
  5. Sep 14, 2017 at 9:03 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x1,000,000,000,000,000,000
  6. Sep 14, 2017 at 9:52 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    66.75''
    Dalandser[QUOTED] likes this.
  7. Sep 14, 2017 at 9:53 AM
    Taco-bender
    Taco-bender Well-Known Member
    Tucson AZ
    2010 Tundra 4x4
    Thanks Robmonster, I'll tag you in my other thread.
    Calling today on some trucks being parted out. Hopefully that'll work out. If not, I'll be hitting on a buddy that builds long travel buggies to get a couple cross members fab'd up.
  8. Sep 14, 2017 at 10:41 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Does anyone know if the seat cushions from a 3rd gen 4Runner can be disconnected and swapped from side to side? I.e. Put the passenger seat cushion on the driver side.
    Looking at a set on CL that are in very good shape aside from a tear on the driver bolster. Wouldn't be an issue if I could swap it to the passenger side.
    Installed some led turn signals/hazards
  9. Sep 14, 2017 at 10:46 AM
    mataco4wd
    mataco4wd Well-Known Member
    994wd
    Finally got my 33s on after all this hurricane crazyness!
  10. Sep 14, 2017 at 10:56 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    More pics or a build of this beaut is needed!! :drool:
    TacoVio likes this.
  11. Sep 14, 2017 at 10:58 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Clean looking rig!:thumbsup:
    Think you might make it out to the New Smyrna South East beach meet and greet?
  12. Sep 14, 2017 at 11:00 AM
    mataco4wd
    994wd
    Wish I could, Work a lot and mostly on weekends. Depends on if I happen to have those days off.
  13. Sep 14, 2017 at 11:01 AM
    Key-Rei
    Key
    Florida
    24th of this month! Come on!
  14. Sep 14, 2017 at 11:08 AM
    mataco4wd
    994wd
    Jaysjammin, jjsul, jubei and 7 others like this.
  15. Sep 14, 2017 at 11:34 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Can you even flat tow the Tacoma? I heard most Toyotas can't be flat towed for some reason.
  16. Sep 14, 2017 at 11:40 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Anything can be flat towed if you take the driveshafts off ;)
    From what I've read on RV forums, manual transmissions seem to do fine with flat towing.
  17. Sep 14, 2017 at 12:43 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    You can not flat tow a tacoma unless you disconnected the drive shaft. I know the older ones with manual hubs you can tow with a tow dolly backwards with the hubs unlocked
  18. Sep 14, 2017 at 1:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Truck passed emissions, gonna get plate for it now.
    Deathbysnusnu, jjsul, Teke and 16 others like this.
  19. Sep 14, 2017 at 1:52 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    What is WMS? :anonymous:
  20. Sep 14, 2017 at 1:58 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Wheel mounting surface. Basically the length of the axle without wheels on it.
    Yetimetchkangmi likes this.
