  1. Sep 26, 2017 at 7:12 AM
    tony2018
    tony2018 Well-Known Member
    Mine broke because I was trying to reset the hydraulic tension. Was new.
    Bulldogs129[QUOTED] likes this.
  2. Sep 26, 2017 at 7:13 AM
    tony2018
    Turns out the belts the correct one, good thing the part number is on the belt itself.
    Bulldogs129 likes this.
  3. Sep 26, 2017 at 8:25 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Just let me know! :hattip:
  4. Sep 26, 2017 at 8:54 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I would suggest an alignment. Why not.
    Also, he shouldnt need a press
  5. Sep 26, 2017 at 8:57 AM
    gunny1005
    gunny1005 Well-Known Member
    Phoenix
    TENSIONER 13540-62021 $39.22
    ILDER TENSIONER 13505-62070 $114.44
    T-BELT 13568-YZZ03 $40.93
    Does that hoes run to a metal pipe?? if so 17343-62090 $9.89
    shows to have it all in stock
  6. Sep 26, 2017 at 9:02 AM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    I misspoke, by press I meant puller, like a tie rod end puller. Mine were a bitch to get off the LCA, I used a Tie rod end puller and Ball joint separator at the same time. and I never got an alignment and it drives fine, Im just speaking from personal experience though.
  7. Sep 26, 2017 at 9:14 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    That's what I'm counting on if I can ever finish my sliders.
    MC770[QUOTED] likes this.
  8. Sep 26, 2017 at 10:05 AM
    tony2018
    So I confirmed that I do have the correct timing belt, and I got impatient and went to the local stealership for the ilder tension and hydraulic tension, RAPED.
    For the vacuum hose it does connect to a metal pipe under the runners. Can you paypal me the quote for the igniter connecter and the hose?
  9. Sep 26, 2017 at 10:05 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    What was the outcome of the stripped drain plug?
  10. Sep 26, 2017 at 10:13 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I have those plugs
    Edit: looks like gunny took care of you.
  11. Sep 26, 2017 at 10:44 AM
    gunny1005
    Phoenix
    Sure can, what was your email address again?
  12. Sep 26, 2017 at 10:50 AM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Just ended up ordering a whole new pan and drain plug from Toyota. Not the cheapest way to do it, but I wanted it done right and didn't want to risk any leaks.
  13. Sep 26, 2017 at 10:55 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Thinking about tryin to do a thing...
    UncleShrek and jjsul like this.
  14. Sep 26, 2017 at 10:56 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Do a thing
  15. Sep 26, 2017 at 10:57 AM
    JKO1998
    Utah
    But I gotta cut it....
  16. Sep 26, 2017 at 11:03 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Does anyone know the angle of the auto tranny flange. I'm getting vibes and need to check my angle of my tranny and pinion angle. Any info would be helpful. Thanks.
  17. Sep 26, 2017 at 11:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You using a single piece DS? Shouldn't matter much with a two piece, I slammed mine up another .75in and no vibes but I could see that messing with it if it was a solid DS.
  18. Sep 26, 2017 at 11:18 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Let us know how this thing goes and how hard this thing is....I want to do this thing as well. Sometimes things do not go well for me!:facepalm::frusty:
    ClevSix likes this.
  19. Sep 26, 2017 at 11:19 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah Double DS. But I still don't have factory mounting points on the truck. When I installed the 3.4 and 4x4 converstion I never check angles. I went off measurements off another first gen. Now that the new mounts are broken in I want to double check my angles to make sure that isn't causing the vibes.
  20. Sep 26, 2017 at 11:44 AM
    RedManRocket
    Red
    2002 Double Cab LT
    I believe
