  1. Sep 27, 2017 at 10:46 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Put a cow in it
  2. Sep 27, 2017 at 10:50 AM
    tony2018
    tony2018 Well-Known Member
    Waiting for the dealership to call me and tell me parts are in, I guess I missed the cutoff and so parts are probably arriving tomorrow.
  3. Sep 27, 2017 at 10:51 AM
    tony2018
    What happen?
  4. Sep 27, 2017 at 10:52 AM
    JKO1998
    Utah
    I shot it
    Teke and blue_goose like this.
  5. Sep 27, 2017 at 10:53 AM
    tony2018
    I guess steak for the week.
    JKO1998[QUOTED] likes this.
  6. Sep 27, 2017 at 11:12 AM
    Americandad
    Americandad Active Member
    Scott
    Marquette MI
    99 Tacoma under construction
    Got a coat of paint on(Sherwin Williams Dura Plate) and the rear springs on so I could spray them too. Front has two coats now and I'll hit the rest tomorrow for a second coat. She'll be a roller soon.
  7. Sep 27, 2017 at 11:17 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You should replace your UCA's and weld in some UCA gussets since you have nothing in the way
  8. Sep 27, 2017 at 11:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    And box or plate your frame.
    Lux and mechanicjon like this.
  9. Sep 27, 2017 at 12:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Coil bucket gussets have been a huge pain in the dick. I wouldn't bother unless you really, really think you need them.
  10. Sep 27, 2017 at 12:09 PM
    Americandad
    Scott
    Marquette MI
    Not necessary on this one, it's going to be the wifes truck.
    I had the whole frame sandblasted and then boxed the piss out it from the front cab mounts back. Also used safe-t-caps for the front leaf spring mount sections.
  11. Sep 27, 2017 at 12:24 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Oh gotcha, I was just saying because he could get a bead on the back half
  12. Sep 27, 2017 at 12:41 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    So the 16" stock steel wheel with with a 1.25" spacer will fit with the tundra calipers? Going to be doing the calipers/rotors soon and a run a stock steelie with a 285/75/16 as a spare
    Mine were also a pain. I think I welded mine a hair tight and they squeek like no other. Had to even grind down the inside of the gusset to get the uca to go in with the new TC bushings
    mechanicjon[QUOTED] likes this.
  13. Sep 27, 2017 at 1:58 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yes, the stock spare will fit with 1" or larger spacers with 13WL calipers.
  14. Sep 27, 2017 at 2:39 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    And fajita back straps.
    TacoVio, tony2018[QUOTED] and JKO1998 like this.
  15. Sep 27, 2017 at 3:08 PM
    Madjik_Man
    Colorado Front Range
    Well that collection screams "you're single" but the pink bike suggests otherwise.
    That my friend is a most impressive pile of parts I've seen in awhile. The Cadillac mistletoe is a nice touch.
  16. Sep 27, 2017 at 3:10 PM
    Madjik_Man
    Getting that shat all back together was awful for me.
    The only thing I can suggest is tears. Once those were on the verge, I was finally able to push and twist the right way.
    And the worst part about it is the fact it made no difference in my shift feeling or the amount of dancing my stick shift does in 5th gear (yeah baby)
    Crock112[QUOTED] and jjsul like this.
  17. Sep 27, 2017 at 4:31 PM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Put a pair of gloves on, push the thing down all the way then while its down use a large flat blade screw driver to pull/swivel it in to its detent. Getting it to turn while holding it down is the only hard part, so use something that you can actually grab a hold of to help turn it.
  18. Sep 27, 2017 at 5:16 PM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Made some mounts and test fitted the bar today :bananadance:
    herbertgerg, jubei, Dalandser and 6 others like this.
  19. Sep 27, 2017 at 5:30 PM
    JKO1998
    Utah
    Don't know if the link works, or have any details or knowledge of this kind of shit at all. I just saw 3.4 and thought it was nifty.
  20. Sep 27, 2017 at 5:39 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    that's sexy!
