  1. Sep 30, 2017 at 11:04 PM
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    My front end is up about 2.5 over stock where it is now. I plan to swap the coils for 650# or maybe even 700# when I do the front end bumper/winch down the road. I'm looking to go to 3-3.5 over stock up front which should sit darn close to level once the rear is loaded.
    jtanner21 likes this.
  2. Sep 30, 2017 at 11:12 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Nice ! Yea I recently added a front bumper which might've bumped me down a half inch. I'm running 550lb Springs though I have a set of 650s I might swap but I believe the 550s I have are an inch longer...at least that's what the guy I bought Them from said... don't know how that plays out with lift
  3. Sep 30, 2017 at 11:13 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Adude, BYJOSHCOOK, taco71742 and 4 others like this.
  4. Sep 30, 2017 at 11:15 PM
    jtanner21
    Nice rig man! What's your front setup ?
  5. Sep 30, 2017 at 11:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have zero idea what speedo gear I need, my truck came with 3.58s but now I have 4.10 and I am running 265/75/16s but I am not sticking with those for much longer. As I understand it, they aren't too expensive to swap out so I'd like to get one for the current setup and then later I'll need one for 5.29 and 34s or 35s (haven't found the tires I want yet)
    jubei likes this.
  6. Sep 30, 2017 at 11:45 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I figured out halfway through Montana that my speedo is 1 mph off at 72 mph, with 4.56's and 315's.
  7. Sep 30, 2017 at 11:47 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Will you post pics when you install the TC kit? I want to see if there's room to hack it up to fit 12" shocks.
    jtanner21[QUOTED] likes this.
  8. Sep 30, 2017 at 11:48 PM
    jtanner21
    Yea for sure man! I'm also curious tbh... was bummed they limit you to a 2.0 10" but we will see once installed. Ideally would've wanted a 2.5
    drr[QUOTED] likes this.
  9. Sep 30, 2017 at 11:49 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Thanks. I'm hoping it can extend further up into the wheel well, not sure how tight it will be in there.
  10. Oct 1, 2017 at 5:49 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Scrap metal and some frustration with a cheap welder. No but seriously, it was real easy. Just cut up some cardboard to mock up what you want then transfer it over to metal. I used 1/8" bar for the long piece which is kinda flimsy but bolting the box to it stiffened it up.
  11. Oct 1, 2017 at 8:13 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Sluggo got a set of full skids yesterday, thanks to Konsta!!
    She's Moab ready now, time to run Pritchett!
    (Konstas the one taking the pics btw)
  12. Oct 1, 2017 at 9:20 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Pritchett is gonna be interesting! U got balls man!
  13. Oct 1, 2017 at 9:41 AM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Use this equation to figure out what size you need: Old wheel diameter x old Speedo gear teeth, divide by new wheel diameter = teeth on new gear (each tooth accounts for about a 3% change).
    Speed sensor gear part numbers:
    AT
    30 tooth 33403-39365 3.4/2.7
    32t 33403-39425
    33t 33403-39415
    MT
    28t 33403-39585
    30t 33403-39365
    31t 33403-39345
    32t 33403-39425
    33t 33403-39415
  14. Oct 1, 2017 at 9:41 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Dude these sas'd bastards have a gauntlet of shit in store for me. Were doing basically all of the hardest trails excluding bfe.
    Pritchett and begin the rocks backwards, the pickle, rusty nail...like I don't think I have enough spare cvs for all this. I'm not Silas!
    Only doing this because Sluggo gets trailered down
  15. Oct 1, 2017 at 9:48 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Scored an OEM 1998 Tow Hitch for my truck 10 minutes away from me for $70. First time I've bought something for this truck that isn't 4-5 hours away.
    I don't see many 1st gen OEM hitches anymore.
    01x4, BYJOSHCOOK, herbertgerg and 3 others like this.
  16. Oct 1, 2017 at 10:00 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Nice, I'm on the hunt for one myself..how's the horns coming?
  17. Oct 1, 2017 at 10:06 AM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Questions please.
    Is there a difference between wheelers eibach T1 coil and the Toltec eibach coils ?
    I have no added weight to the front of my truck, and do not plan on adding any, what I would prefer is a 550 lb spring. Can't find that information.
    Can I add these springs to my adjustable Bilstein's that I have installed already with the stock spring set on the middle perch ?
    What is the best way to go with the rear ? Add a leaf and new shocks ? Full leafs and shocks ?
    Not wanting to spend a bunch of $$. If I did, I would get some total chaos arms and kings up front, dealers and kings in the rear.
    Truck is a 2003 prerunner with 265 tires.
    About to get a new Sprinter van and want to do a few things to the taco since I decided to keep it.
    Thanks in advance.
    herbertgerg and FLBAdrian like this.
  18. Oct 1, 2017 at 10:19 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Horn fabrication is done. Just need to finish up documentation and some wiring today and box everything up.
    nzbrock and lucky13don[QUOTED] like this.
  19. Oct 1, 2017 at 11:40 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    So guys, got a running rich in bank 1 code and abs short circuting code a min ago.
    What couod it be
  20. Oct 1, 2017 at 11:50 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    What were to code numbers?
