  1. Oct 22, 2017 at 11:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    BFG lists the recommended wheel width as 7-8'' wide.
    Shouldn't have a problem.
    Id be more concered about the offset of those wheels and rubbing. What are 3rd gen wheel specs?? Similar to 2nd gen?
  2. Oct 22, 2017 at 11:04 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I heard there would be rubbing at full lock but I'm not sure. I was planning on running wheel spacers, eventually. Let me see if I can find offset info.
    I'm running no lift on the stock 1998 PreRunner suspension. Original truck's tire were P275/75/R15 before I replaced them with P235/75/R15 (big mistake, those tires ugly af) so P265/75 ratio is fine.
  3. Oct 22, 2017 at 11:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well depending on the tire you could rub the frame at full lock but also the UCA.
  4. Oct 22, 2017 at 11:11 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I've seen people run the stock 3rd gen off-road tire/wheel setup (Goodyear Wrangler Adventure w Kevlar, 265/70/16) on the 1st gens with no rubbing - what I'm concerned about is the '75' aspect ratio of the tire instead of the '70' of the stock 3rd gen tires.
  5. Oct 22, 2017 at 11:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well that means they are taller.
    According to BFG its 1.1'' taller and .2'' narrower.
    So you will likely need to do some trimming to the pinch weld area. But not much. Not as much as a 33 anyways.
  6. Oct 22, 2017 at 11:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Shit... really wanted to avoid trimming. Would this be avoided with the wheel spacers or do I need a lift?
  7. Oct 22, 2017 at 11:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..if you do any offroading or just bash the mall hard. You'll rub without trimming no matter what.
    But a lift will help if you just crawl the mall from rubbing all the time.
    Mainly due to you being on old stock suspension you'll probably rub. Just getting new coils that aren't a "lift" would help likely.
    I'm more of the mindset to make it clear at full stuff but that's up to you
    jubei and BartMaster1234[QUOTED] like this.
  8. Oct 22, 2017 at 11:20 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Set of 5100's set up a little. They should clear with spacers.
  9. Oct 22, 2017 at 11:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'm planning on adding a lift eventually, probably within the next couple months. Right now I just need to buy new tires for my rims since I need to fit the Tundra brakes under them. I just want to make sure for now I can drive with the 16x7J wheels and the BFG 265/75-17 tires with no problem.
  10. Oct 22, 2017 at 11:26 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    According to eBay's internal wheel fitment guide, the P265/75-16 won't fit but the P265/70-16 will. This is if you plug in a 2017 TRD Off-Road.
  11. Oct 22, 2017 at 11:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    They will fit. But you'll have to do minor trimming I think. Nothing that bad. Small bit of plastic and a few wacky with a hammer.
  12. Oct 22, 2017 at 11:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Just as long as I don't have to take the angle grinder out trimming the plastic is no problem for me. Thanks!
    Dalandser likes this.
  13. Oct 23, 2017 at 12:03 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That's what a dremel's for ;) Plus the difference in sizes is 1" different in diameter, so 1/2" in radius which shouldn't be a big deal until you're at full lock.
    Edit: Just saw @Blackdawg already mentioned this.
    Just saw this. I was like dang I thought I have problems. I didn't know what life could be like when you have real money lol.
    https://www.tacomaworld.com/threads/urgent-buying-a-used-2017-pro.516325/#post-16307512
  14. Oct 23, 2017 at 4:14 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Thanks guys
  15. Oct 23, 2017 at 5:49 AM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Spent hours using every sticker remover all were worthless. Used paint thinner and in 45 min it was done and buffed out.
    Old decal new company logo.
    It was extra nice to use the bat cave.
  16. Oct 23, 2017 at 6:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Guess you're going to have to start paying for hot sauce lol.
    jubei, Croth51, devinzz1 and 2 others like this.
  17. Oct 23, 2017 at 6:59 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    One of the few factory badass diesel Tacos right there. Looks good Brian.
  18. Oct 23, 2017 at 7:31 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    How much fluid film did you use? I just got my truck a few months ago, and the frame is in great shape, no rust, and I wanna keep it that way. Planning on doing fluid film asap.
  19. Oct 23, 2017 at 11:25 AM
    tony2018
    tony2018 Well-Known Member
    Just make sure you get rid of any dirt and debri down there, pressure washer, some simple green and some brushes will help.
    MagicMexican[QUOTED] likes this.
  20. Oct 23, 2017 at 11:25 AM
    tony2018
    I'm done with whatever maintenance I could do before inspection. Next will be alarm install and that should be it for now. FOR NOW.
