  1. Oct 30, 2017 at 9:58 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’m getting a used set of Lcas and replacing the bushings and stuff, I don’t know what brand yet... Whiteline didn’t have anything on their website..
  2. Oct 30, 2017 at 10:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When it comes time to replace my LCA bushings, I don't think I will mess around with swapping out the bushings. I think a new OEM LCA is the way to go.
    FWIW, there are no aftermarket stock length LCAs for 1st gens. The only replacement arms out there (besides OEM) are for long travel setups.
  3. Oct 30, 2017 at 10:05 PM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    jjsul and Speedytech7 like this.
  4. Oct 30, 2017 at 10:09 PM
    Kittenmittens4U
    Sam
    Denver, CO
    Negative on that there are a bunch of stock length LCA's out there, Moog, Dorman, Mevotec to name a few.
  5. Oct 30, 2017 at 10:10 PM
    kmcmahon5
    kmcmahon5 Well-Known Member
    B.C.
    1996 Tacoma, 1989 pickup
    Thats what I was looking for! Stock length. I wonder which brand to go with
  6. Oct 30, 2017 at 10:14 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I think he meant upgraded LCA's, as in fabricated/boxed/tubular arms that are stronger than stock.
    jubei, turbodb and stumbles like this.
  7. Oct 30, 2017 at 10:15 PM
    Kittenmittens4U
    Sam
    Denver, CO
    Toyota duh :D when I did my front end I just couldn't pull the trigger on an aftermarket brand after spending so much on Oem lbjs,and tre's. I actually got lucky and found a Amazon warehouse deal on an oem lca with bushings for like 55 bucks, it's only the right side but my drivers side bushings are okay for now but I'm always looking.
  8. Oct 30, 2017 at 10:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This VVV No reason to cheap out on moog crap.
    I guess I should have been clearer. :cheers:
  9. Oct 30, 2017 at 10:17 PM
    Kittenmittens4U
    Sam
    Denver, CO
    I'm not too sure about that considering the wording used "The only replacement arms out there (besides OEM) are for long travel setups."
    EDIT sorry @Digiratus I posted a second too late, but yes I get what you meant your wording just made it seem like oem or long travel were literally the only option.
    Digiratus likes this.
  10. Oct 30, 2017 at 10:36 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I have an annoyed noise coming from my front end! It's driving me nuts. I've greased the UCA and added tri flow to my uniball that didn't fix it. I usually happens as I'm coming to a stop and I let off the brake. I'm wondering if maybe my coils are squeaking from the extra weight of the winch I just added two weeks ago? I tried to upload a video but it isn't working unfortunately.
  11. Oct 30, 2017 at 10:38 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Get under there while a friend shakes the truck, usually can pinpoint a big issue that way. I can tell you with aftermarket custom stuff comes little unwanted noises, my truck makes lots of them... sorta comes with the territory.
  12. Oct 30, 2017 at 10:42 PM
    Dan8906
    Daniel
    Concord, California
    My least favorite of thing with aftermarket stuff.
  13. Oct 30, 2017 at 10:46 PM
    JKO1998
    Utah
  14. Oct 30, 2017 at 10:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Is the bottom CO mount rubber or is it a heim? Looks like you have Icon COs. Put a little tri-flow on the lower heim joint to see if the noise goes away.
    Adude likes this.
  15. Oct 30, 2017 at 10:53 PM
    Dan8906
    Daniel
    Concord, California
    It's a heim.
    I'll definitely give it a shot.
  16. Oct 30, 2017 at 10:58 PM
    Kittenmittens4U
    Sam
    Denver, CO
    I'm not sure of the best place to order them, I ended going a different route for now. I do know for a fact though that those bushings will fit perfectly due to many hours of researching and helping a buddy put some in his 3rd gen 4runner (same LCA except for sway bar mounts or lack there of)
  17. Oct 30, 2017 at 11:05 PM
    Thurman Merman
    Thurman Merman Well-Known Member
    Denver, CO
    I do a lot of highway driving into the mountains in snowy conditions. Body roll sounds scary and possibly lethal.
  18. Oct 30, 2017 at 11:13 PM
    Speedytech7
    If you have stock suspension I wouldn't even consider removing it. But with aftermarket stiffer suspension, that bar is just trash and makes the ride rougher.
    Silver02Taco and Kittenmittens4U like this.
  19. Oct 30, 2017 at 11:15 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
  20. Oct 30, 2017 at 11:34 PM
    Thurman Merman
    Denver, CO
    I have stock right now but planning to add nitros and 881s soon. I already have the coils, just need to buy the shocks.
