  1. Oct 31, 2017 at 1:22 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks like a 4Runner rear link too which is strange they have less accounts of failed frames.
  2. Oct 31, 2017 at 1:27 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Rust doesn't discriminate.
    Stm82 likes this.
  3. Oct 31, 2017 at 1:32 PM
    jcasteel
    jcasteel Well-Known Member
    Savannah, GA
    2003 Double Cab V6 PreRunner TRD
    Not all done in one day but since I purchased the 2003 a couple of weeks ago.
    Timing Belt, Water Pump, Thermostat, Tensioner, Upper Bearing, Lower Bearing, CamShaft Seal, CrankShaft Seals,
    Fan Belts (3), Spark Plugs, Plug Wires, Valve Cover Gaskets, CamShaft Cups, half moons,
    Drain and refill Rear Differential Gear Oil (75W-90),
    Drain and refill Crankcase Oil (5W-30) and Filter,
    Air Filter,
    Drain and refill AntiFreeze (Xerex Asian),
    Install backup camera,
    New rearview mirror with backup camera display,
    Drain and refill ATF (Toyota T-IV),
    Speedbleeders,
    Drain and refill Brake fluid with Dot 4,
    Install Alpine ILX-107,
    clean, clean, clean,
    New Husky floor liners front and rear,
    polished the Toyota emblem on the top of the plenum to a mirror shine
    Got her all back together and buttoned up. Purrs like a kitten. Runs like a Swiss top, then I
    found a crack in the Left Valve cover that is letting some oil drip out. I have some valve covers
    headed my way. Might do a little polish or paint them however I don't think it will improve the looks
    of the engine enough. So I might leave them as is.
    Whew, now I'll drive her for a little while until I decide what is next.
    Oh, I also deleted the clock because, well I couldn't see it anyway.
    UncleShrek, jubei and rngr like this.
  4. Oct 31, 2017 at 1:34 PM
    Dan8906
    Daniel
    Concord, California
    :worthless:
    UncleShrek likes this.
  5. Oct 31, 2017 at 1:37 PM
    jcasteel
    Savannah, GA
    Agreed but I have a 13 year old and it is halloween. I'm gonna do a write up on the rearview camera install. The Alpine was mostly plug and play with a lot of soldering. I promise I'll get something up and I took pictures.
  6. Oct 31, 2017 at 1:47 PM
    Speedytech7
    True but they were better coated and had fully boxed frames
  7. Oct 31, 2017 at 1:47 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I don't have hard evidence between my correlations but something seems to be going on.
    If I go off a curb there is a clunk in the back passenger axle area it sounds like. Braking then seems to be less firm. Also when I pull the emergency brake, it clicks more times than usual.
    So I then do the reverse, pull emergency brake a few times to get it adjusted and then all seems to go back to normal.
    I changed the brakes and axle seals a few weeks ago. I am pretty positive I replaced the drum brake components right. Does it sounds like something inside the drum brake could be causing this?
    More information is I did my OME lift a few months back and did not get extended brake lines, would this be causing it or nah?
    Pic for attention
  8. Oct 31, 2017 at 2:04 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Not wanting bad mpg when I go to 265/70/16
    So been lazy with my 225/70/16
    But in all this rain probably should change tires eh?
  9. Oct 31, 2017 at 2:24 PM
    jcasteel
    Savannah, GA
    Pics.
    Alpine ILX-107. Wireless Carplay. I get in the car and my iPhone connects wirelessly through the headunit's wifi.
    Rearview mirror with display.
    Tailgate picture. I cleaned up the zinc primer around the camera orifice. The writeup will get a picture as it is now. Also, while I was considering places to mount the camera I had the rearview mirror near me so that I could look at results hence the rearview mirror held over the tailgate.
  10. Oct 31, 2017 at 2:41 PM
    Dan8906
    Daniel
    Concord, California
    why not put the rear video to the headunit?
  11. Oct 31, 2017 at 2:52 PM
    jcasteel
    Savannah, GA
    I'll explain in the writeup but my current car has it in the dash and I get disoriented looking at the rearview mirror, side mirrors, and down at the dash display. I loose my peripheral vision when I look down and the Tacoma's radio sits even lower in the dash than what is in my current car. In short, the rearview mirror and my peripheral vision give me the best overall rear view and looking down at the dash breaks that view.
  12. Oct 31, 2017 at 2:52 PM
    Danno1985
    Danno1985 Well-Known Member
    Milwaukee
    2003 Prerunner TRD Off-Road (RIP)
    Winter shoes mounted. Firestone Winterforce LT, 235/85r16 pizza cutters. These things sure seem insanely heavy but according to Firestone's specs are actually slightly lighter at 42lbs than the D-rated 31X10.5X15 Destination A/Ts I have. Go figure. I had them on my 4runner last winter and they rocked.
    Next up I think the nerf bars are going to go.
    93310EFA-BCDB-4C38-A4FB-30C05DCC2995.jpg C1688D43-F801-4B6F-A2DB-C4C65BA534E8.jpg
  13. Oct 31, 2017 at 2:57 PM
    Stm82
    Stm82 BRAAAPPP!!!
    Mb. Canada
    95.5 2.7 5 speed 4x4 reg cab
    33x12.5x15 Nitto Trail Grapplers on M/T 15×8 3.25" Bs 3" Toytech front Mystery add a leaf back with random shocks Bush whacker cutout flares (extra firewall smash) Side dump exhaust Washer fluid relocate 91 (or so) bucket seats and console Twin stick transfer case Toyota elocker
    96 4runner of a friend of mine. I guess I have a new project in my future. You also have to remember this is Canada... salted roads are terrible.
  14. Oct 31, 2017 at 3:04 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    No they're not. They are both receiving about the same amount of power at all times, yes, but the one will less resistance is the one that actually puts the power to the ground.
    Hell yeah, man. And that scene is gold.
    2BeersPlease likes this.
  15. Oct 31, 2017 at 3:46 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    yes they are.
    one with more traction is putting same amount of power to ground as the one with the least will allow.
  16. Oct 31, 2017 at 3:51 PM
    tony2018
    tony2018 Well-Known Member
    Def curious to know how you mounted that rear camera.
  17. Oct 31, 2017 at 3:59 PM
    sente3
    sente3 -
    North Jersey
    You're right. I was misunderstanding how the power limitation functions.
  18. Oct 31, 2017 at 4:01 PM
    Speedytech7
    Pass it over... I don't think either realizes they're saying the same thing but different....
    fiziks likes this.
  19. Oct 31, 2017 at 4:02 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I know you are but what am I.......
  20. Oct 31, 2017 at 5:23 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone know of a paint that actually matches the 99 tacoma brown... I’ve tried matching it but apparently they look different inside...
