  1. Nov 9, 2017 at 11:10 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    such a shit design..
    Be nice you could make a fabbed spindle like the 2nd gens work.
  2. Nov 9, 2017 at 11:18 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Not really sure. I had two fall out on my way to RT. Found some 8.8s to get me to RT and picked up some oem bolts from someone there. I didn't lift the truck up to install the 4 new bolts. Just did them one at a time and torqued them. I think it was a day or two later I heard dust shield rubbing the rotor again and this time two of the bolts had sheared in the spindle. My best guess the second time was that because the truck was still on the ground the torque was inaccurate
  3. Nov 9, 2017 at 11:20 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That sucks.
    I need a new spindle from my last encounter. One is still sheered inside it. And im pretty sure most the threads got stripped out on one when the bolt ripped out.
  4. Nov 9, 2017 at 11:39 AM
    Reh5108
    Idaho
    A new spindle is cheaper than what I paid to get those two bolts extracted from the 4x4 shop in Moab. I think they welded nuts to them and backed them out.
  5. Nov 9, 2017 at 11:40 AM
    Reh5108
    Idaho
    I wonder if there is enough material to upsize the holes a size to fit slightly larger bolts
  6. Nov 9, 2017 at 11:48 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I don't have the time to build a jig for test stretching bolts, but I'd like to see how much force it takes to yield a couple thou of stretch. Would be easy for a bolt to back out if the friction on the bottom of the head was alleviated. If they stretch too easily that would key to an undersize bolt (which I think is at least a contributing factor)
    BTW they have a 14mm head not a 14mm thread
  7. Nov 9, 2017 at 11:55 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This is why I enjoy the first gen section, so much thought going into a potential issue on first gens. Engineering and math's being applied. It's wonderful. Not like some other sections... hurr durr how do I crawl control.
  8. Nov 9, 2017 at 11:56 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    They are probably fine for stock level of unsprung weight and no other external forces brought on by a lift. I would also think that the addition of greater side force applied during crawling over rocks and such contribute.
    Speedytech7 and stumbles like this.
  9. Nov 9, 2017 at 12:10 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Can I fit 35's on zero lift? Asking for a friend :cookiemonster:
    JeffB, A Mo Cat and Deathbysnusnu like this.
  10. Nov 9, 2017 at 12:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Agreed.
    that im not sure about. The outer ones probaby yes. The inner ones. Doubt it. There isn't much there to begin with. Might be able to go up slightly but not much.
  11. Nov 9, 2017 at 12:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yas.
    Just cut everything.
    I mean...EVERYTHING
  12. Nov 9, 2017 at 12:17 PM
    Speedytech7
    My tires and your tires are barely bigger than stock and not super heavy. I'm thinking more for the people that push their trucks hard.
  13. Nov 9, 2017 at 12:21 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    How many of the LT guys have had the bolts shear (all 4) I would assume are rougher than most on them
  14. Nov 9, 2017 at 12:22 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Agreed, the design of the joint is what leads to failure, not the fastener selection. Constant cyclic fatigue in tension and shear are what cause the bolts to fail, not a single instance of loading.
    For what it's worth, the bolts are M10x1.25, with a minor thread diameter of ~0.33", and are grade 10.9 (136000 psi yield). Nominal tensile strength is 0.083 in^2*136000=11300 lbs, or 45000 for the whole LBJ. You'd have to drop your truck off the top of a building to generate that kind of load.
    Edit: I'm an idiot.
  15. Nov 9, 2017 at 12:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, it contributes to the issue with bolts.
    The ball joint popping out of the socket is 'normal' wear and tear because of the design. When this failure occurs it is because of poor maintenance. The joint was pushed beyond it life span. Unfortunately, because of its design, it is almost impossible to get any warning or to determine if the joint has failed. This makes it prudent to treat them like the timing belt. It has been X number miles, therefor its time to change them.
    For me X = ~90K miles.
    jubei, TheSaint and drr like this.
  16. Nov 9, 2017 at 12:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :wave:
    I'm doing mine every 50k on Frank haha
    m3bassman likes this.
  17. Nov 9, 2017 at 12:28 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Do you mean Frank is forcing you to do them every 50k, usually on a trail? :rolleyes:
  18. Nov 9, 2017 at 12:29 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    im at 66K on my truck, so your saying I should start considering replacing them?
  19. Nov 9, 2017 at 12:30 PM
    Speedytech7
    Probably way overkill for you
  20. Nov 9, 2017 at 12:32 PM
    Dan8906
    Daniel
    Concord, California
    Yeah I was going to do it at 90K with my timing belt. Want to do tie-rods as well. Figured that way if they are still have way decent, i can throw them in my recovery gear box for the trail just in case.
