  1. Nov 10, 2017 at 4:07 AM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Fairly certain that 2001-2004 all came with 16" inch wheels.
  2. Nov 10, 2017 at 4:09 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    My 02 4x4 TRD came with 15’s
  3. Nov 10, 2017 at 5:56 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    My '02 4x4 SR5 came stock with 16" Steelies
  4. Nov 10, 2017 at 6:25 AM
    tony2018
    tony2018 Well-Known Member
    What kind of housing? Plastic or metal? Just the 70w doesn't peel the mirror finish off or melt it.
  5. Nov 10, 2017 at 7:38 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    My '02 4x4 TRD came with 16s. If you have the v6 and the e-locker 3rd your diff ratio is 4.10:1 with a diff code of B03A. This combination came with 265/70r16s from the factory.
    SwampYota likes this.
  6. Nov 10, 2017 at 7:40 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Not enough reason...
    :brianr:
  7. Nov 10, 2017 at 8:22 AM
    CHMM
    CHMM GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    Thanks. How do I tell if I have the B03A? Here is a photo of what’s inside the door. Does yours have something else? Mine is not a TRD because no rear locker. 6B753BB6-DF82-40DC-83EC-140A38EAB32A.jpg
  8. Nov 10, 2017 at 8:24 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    lower right corner
    lucky13don likes this.
  9. Nov 10, 2017 at 8:25 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yours came with 15s originally. And has 4.10 gears.
  10. Nov 10, 2017 at 8:40 AM
    CHMM
    CHMM GTO
    Gabe
    It's got the BO3A and the A
    Cool. Does the inside of your door say 16s? or 15s like mine. Because mine is sayin B03A and calling out 225 75 15 tires
  11. Nov 10, 2017 at 8:44 AM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    How are the puppies doing? Must be fat by now :D
    ^^^ :thumbsup:
    Blackdawg speaks from experience, and is 100% right. The newer mc has better performance than 90's. :cheers: good luck with it!
    Man, what an improvement! :woot:, only you'll know what's under there.
    :popcorn: ...you've taken it to a new level! Impressive rig :hattip:
    malburg114[QUOTED] likes this.
  12. Nov 10, 2017 at 8:46 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Pretty sure this is not true. All trucks from 2001 and newer came with 16s. If they had a 4.10 gears, they came with 31s (265/70r16s).
  13. Nov 10, 2017 at 8:47 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sticker says 15s :notsure: there is a guy on the last page that said his came with 15s stock and is a 2002.
  14. Nov 10, 2017 at 8:50 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Mine has basically the identical info on it. The weights and tire sizes listed were for the base truck. The stickers do not have any info on them about what the TRD package adds.
  15. Nov 10, 2017 at 8:50 AM
    Bulldogs129
    Malcolm
    Mississippi
    Moved the deer stand last night...
  16. Nov 10, 2017 at 8:51 AM
    Digiratus
    Roaming the PNW
    The RedHead
    My truck did not come from Toyota with 225/75r15s but my sticker reads the same as his.
  17. Nov 10, 2017 at 8:52 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    freakin toyota...
  18. Nov 10, 2017 at 8:55 AM
    CHMM
    CHMM GTO
    Gabe
    Hmm. I only ask because I have 265 75 16s that rub. Now I was taking the truck home going 75. my buddy with a 2016 Tundra said I was going about 82-85. LOL. Just trying to figure this out.
  19. Nov 10, 2017 at 8:56 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Definitely aren’t small.
    Seagull233, A Mo Cat, 04yota and 11 others like this.
  20. Nov 10, 2017 at 8:56 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    After updating to the Kenwood D710G and Mobilinkd for APRS, I ran into some crazy RFI gremlins. Originally I thought it was my aftermarket JOYING head unit, but that turned out to not be the case. Ultimately I figured out what it was and got it fixed though!
    UncleShrek likes this.
