  1. Nov 14, 2017 at 10:30 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    vinyl blinds (think thats what there called. like the curtain type deal that goes in front of a window. I used a strip under my rack to prevent direct contact.
    Lux[QUOTED] likes this.
  2. Nov 14, 2017 at 10:32 AM
    devinzz1
    devin
    2023 aclb trd or mt
    how do you like em. I ordered 3 that should be here this week.
  3. Nov 14, 2017 at 12:22 PM
    tony2018
    tony2018 Well-Known Member
    What speaker adapters did you guys use for your 1st gens?
  4. Nov 14, 2017 at 12:32 PM
    devinzz1
    devin
    2023 aclb trd or mt
    plywood+jigsaw+15minutes
    or you can find molded plastic ones on eBay
  5. Nov 14, 2017 at 12:33 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Learned that my UBJs are about toast and now deciding if I should just replace the UBJ's or upgrade the UCAs in the process... Hmm... so many options... (current UCAs are Light Racing)
    Bulldogs129 likes this.
  6. Nov 14, 2017 at 12:51 PM
    ClevSix
    IL/IA
    Having grease-able uppers was a consideration but the replacement UBJs for the LC uppers are grease-able and I can get them for about $75-80. Any new UCA would run a lot more and I'm not sure it would be worth it.
  7. Nov 14, 2017 at 12:51 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    I like them a lot so far. Construction seems decent. Came with clear and diffused protective covers. Haven't really been able to put them to the test on dark mountain roads, but I think they'll throw plenty of light. I think they look a lot better than the light bar too.
  8. Nov 14, 2017 at 1:08 PM
    devinzz1
    devin
    2023 aclb trd or mt
    i much prefer round lights myself. my hella 500s have degraded over the years with 55watt hids in them.
  9. Nov 14, 2017 at 1:33 PM
    tony2018
    I thought about making the cuts myself. Did the math on plywood/mdf, abs/hdpe and the adapter plates will have to work. Not alot of options because the factory adapter has the speaker at a slight angle. This last speaker adapter I bought is suppose to be specifically for the 1st gen tacomas so I'll how that goes. If not than I'll go abs/hdpe
    Like so
    https://www.youtube.com/watch?v=Ol-dM0dUjqU
  10. Nov 14, 2017 at 1:55 PM
    mountain mike
    mountain mike Woodsbum
    the backwoods...
    2003 DCSB 4x4
    just what I need to do what I want
    Ok guys, need your expertise.
    My wife's 02 prerunner needs new coils, struts, and rear shocks (124k). She does not want it lifted. NAPA, KYB, or maybe if I can talk her into it OME880's with nitrochargers.
    What say you?
    Also need a fuel filter and diff fluid for hers and my 03 4x4, what are your suggestions. Mostly dd, I wheel mine but mostly FS roads for camping, snow wheeling etc, nothing extreme.
    Thanks in advance,
  11. Nov 14, 2017 at 2:01 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  12. Nov 14, 2017 at 2:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Plus you can show that inner fender who's boss with the grease nipple.
    Reh5108 likes this.
  13. Nov 14, 2017 at 2:18 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    That's where sits
  14. Nov 14, 2017 at 2:36 PM
    mountain mike
    the backwoods...
    2003 DCSB 4x4
    Thanks for your response, I guess I was hoping for suggestions with some meat to back it up. Why would you choose it, advantages/disadvantages, cost/benefit etc
    If I was to use synthetic, do I need to flush the diff beforehand? Why is synthetic better?
    I have run with standard for 112k, yes I have changed it, just trying to do more work myself and be better informed. Thanks. Mike
  15. Nov 14, 2017 at 2:45 PM
    Speedytech7
    Personally I would stick with regular old dino oil in the diffs, it is recommended for things that rarely reach temps high enough to boil the water content out of them. Many of the popular synthetic oils are hygroscopic meaning they absorb water content from the air (not a lot mind you) but that is why popular diff builders advise against it for long term. Dino oil is cheap and changed at regualar intervals (like 30k for diffs, performs great). Synth oils are great for just about everything else on the truck though.
    Suspension on TW almost always has a cult following behind it on TW, find the cult (thread) and you find the info you're looking for. That said he probably offered up OME as a solid choice because when sold as a complete set it tends to ride satisfactorily and be low maintenance (better than from the factory without being stock), it also has lots of choices for controlling lift height (if any) and load carrying. Any questions specifically?
  16. Nov 14, 2017 at 2:49 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I didn't think that on synthetic diff oil. Well I'm changing it soon then
  17. Nov 14, 2017 at 2:52 PM
    Speedytech7
    I wouldn't sweat it too much, just nice for peace of mind. One of those rare times when synth should have a shorter change interval.
    Adude likes this.
  18. Nov 14, 2017 at 2:55 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Yea, true. But who wants that thought at the back of there mind that there diff has water in it and potentially rusting.
  19. Nov 14, 2017 at 2:59 PM
    mountain mike
    the backwoods...
    2003 DCSB 4x4
    If I went with NAPA or KYB is there a downside, poor performance, short life? I can get NAPA with coils already assembled and rear shocks for $400 no shipping. OME is $700 plus shipping and $ 40 for my mechanic to assemble. Both will require an alignment after install. She only drives it 3 days a week.
  20. Nov 14, 2017 at 2:59 PM
    Gigawatts
    Gigawatts Well-Known Member
    SRunner
    I put a new battery in mine. 6 years on the old one I thought was pretty good.
    Jerry311SD likes this.
