  1. Nov 20, 2017 at 10:21 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    too much for sure. They would be so heavy!
    Stm82 likes this.
  2. Nov 20, 2017 at 11:21 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Down south Motorsports
    jtanner21[QUOTED] likes this.
  3. Nov 20, 2017 at 11:23 AM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
  4. Nov 20, 2017 at 11:24 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Like just another layer? Why not just gusset it? This is the way I did my t-case skid with 1"x1" 3/16 angle but same could be applied to the other skids:
    Had the whole weight of the truck on it in Moab and still holding up great.
  5. Nov 20, 2017 at 11:33 AM
    jtanner21
  6. Nov 20, 2017 at 11:37 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Micah, tell him you're on TW. Might get a discount :notsure:
  7. Nov 20, 2017 at 11:51 AM
    jtanner21
    Just ordered them , should be here tomorrow thanks brotha Micah was a cool dude
  8. Nov 20, 2017 at 11:58 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Your welcome
  9. Nov 20, 2017 at 12:16 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Alright so around late june I had my actuator fail on a trail, electronic not vacuum, wasn't doing anything crazy. Maybe a bit too fast on the rocky trails? not sure. Fixed it in september, put a new(used) actuator in with a 1 year warranty. The nipple on the new actuator was broken but we had a trip planned for the day I installed it so I did a trail repair with a toothpick plugging the breather so water wouldn't get in. Worked great the whole day, no issues.
    I forgot about the toothpick thing and last weekend we went wheeling in aoaa and while I was in 4L the front tires weren't spinning. Front DS was spinning, solenoid was clicking on the passenger side, but I think the actuator wasn't engaging. This happened right after I came down on a rock kinda hard on my rear axle. I pulled the toothpick out, there was a little bit of pressure that came out, but still wasn't engaging. tried banging on the actuator thinking the thing was just stuck, nothing did any good. Took us half an hour to get me pointed the right direction so I could get off the trail, went home defeated.
    Is it possible for the collar of the actuator to slip out? I know second gens have this issue where the contacts need to be soldered, Im gonna tear apart the old actuator and see if something is wrong inside. Anyone know how to bench test it?
  10. Nov 20, 2017 at 12:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah a flat plate is not an efficient way to keep the skid from bending. I've never understood why most fab shops make them like that. You need stiffeners like shown above - easiest way is to use 1"x1" angle with the corner pointing up. Add gussets or bracing to any bends/corners in the skid. Should be able to make it much stiffer without a lot of extra weight.
  11. Nov 20, 2017 at 12:56 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :muscleflexing:
    thanks man
    jjsul likes this.
  12. Nov 20, 2017 at 1:24 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    to the people interested in changing the body mounts. just got back from first drive and theres quite a big improvement with the poly mounts. the noises are gone and the truck has a more solid feel. sharp bumps aren't felt as much. the old mounts were seperating so it was hitting metal on metal. This was a 2 full day job as all 12 body mount bolts snapped into the frame.
    TacoSauce04 and SwampYota like this.
  13. Nov 20, 2017 at 1:27 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    What else did you need to change with the 1" BL? Steering/shifter extensions? Coolant lines?
  14. Nov 20, 2017 at 1:33 PM
    devinzz1
    devin
    2023 aclb trd or mt
    kit came with the steering extension. i loosened and slid the gas fill up a little and its long enough for 1".
    i could have done alot faster if i wasn't screwing around trying to get the bolts out and just cut them off to begin with.
    nothing else needed to be touched. the rubber wheel well gaurds still fit with redrilled holes.
    drr[QUOTED] likes this.
  15. Nov 20, 2017 at 1:34 PM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    That's not what I wanted to hear. Although, you probably have a lot of rust, don't you?
  16. Nov 20, 2017 at 1:37 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    what size bolts are those? My brother is doing this too, taking his sweet ass time (trucks been sitting in the driveway for months anyway waiting to get the trans back in :rolleyes:)
  17. Nov 20, 2017 at 1:38 PM
    devinzz1
    devin
    2023 aclb trd or mt
    the rear most mounts were fairly rusty yea. after snapping the tops off i welded nuts on the bottom and they backed out.
    i cut all of the passenger side off and didnt even try with a wrench.
  18. Nov 20, 2017 at 1:38 PM
    devinzz1
    devin
    2023 aclb trd or mt
    which ones?
  19. Nov 20, 2017 at 1:59 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    the body mount bolts
  20. Nov 20, 2017 at 3:07 PM
    Madjik_Man
    Colorado Front Range
    That's an impressive picture :oops:
