  1. Nov 21, 2017 at 8:55 PM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Might be the LBJ's since they are original.
    So I didn't have this issue before putting the skid plate on.
    Would the axle wrap be cause by adding the weight of the skid and having the springs not be the not the correct spring weight (they are 881 OME)
  2. Nov 21, 2017 at 8:59 PM
    Jaysjammin
    Jaysjammin Well-Known Member
    Jay
    Upstate SC
    '98 SR5 5-speed 4x4 3.4L, 07 FJ Auto 4x4, 97 Locked 80
    How many miles are on it? Gotta be vigilant with these trucks. Does it pull to that side at all?
  3. Nov 21, 2017 at 9:06 PM
    bayareayota
    Bay Area
    Prinsu 32" K02 OME
    How many miles on what?
    The truck has 155k
    The suspension has 5k top
    I don't hear it at highway speeds. It's really only a low speed/braking to a stop/accelerating from a stop
  4. Nov 21, 2017 at 10:44 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    1st gen skid from RCI? Didnt know they made them. Sweet
  5. Nov 21, 2017 at 10:53 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Same here, good to have another option
  6. Nov 21, 2017 at 10:54 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I would jack it up and see if you have play in the lbjs
  7. Nov 22, 2017 at 4:13 AM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    They do, although they say 96-02 4runner on their website RCI confirmed that the front skid and transmission skid would fit first gens.
  8. Nov 22, 2017 at 6:21 AM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Bad ass bro
    Ice Horse[QUOTED] likes this.
  9. Nov 22, 2017 at 6:23 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Who dat!
  10. Nov 22, 2017 at 6:35 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    :boink::boink::boink::boink:
  11. Nov 22, 2017 at 6:48 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Lol my bad sorry bra
  12. Nov 22, 2017 at 7:46 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    So been researching my butt off about front brakes and rotors. Don't have the time and money for tundra brake swap (much less the need to do so) just want an upgrade. Before pulling the trigger - I think I have decided on Brembo blanks and akebono ceramics. Read about them and think it is a good combination! Thoughts?
    Also truck is throwing codes p0171 - system too lean and p0141 - 02 sensor #2. I am going to buy a new Denso 02 sensor (heard not so great things from Bosch) and see if that helps both codes. 02 sensor has probably never been replaced? Don't know about PO but truck is at 180K so might as well replace for my 90k maintenance
  13. Nov 22, 2017 at 7:49 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    I have brembo and akebono on mine
    Very pleased with it
    WildLand[QUOTED] likes this.
  14. Nov 22, 2017 at 7:50 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Perfect, good to know!
  15. Nov 22, 2017 at 7:51 AM
    PROseur
    Pussy
    I had to do a master cylinder on mine at 195k miles
  16. Nov 22, 2017 at 7:53 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    blahh, how was that?
  17. Nov 22, 2017 at 7:56 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So why no tundra brakes? It barely costs more at all and takes almost the same time. Only thing you add is bleeding the brakes. And it'll be a way way better upgrade than just rotors and pads
  18. Nov 22, 2017 at 7:59 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Man, I thought I had my mind set! Will they fit with my 2013 taco steelies? They are 16 inches so should right?
  19. Nov 22, 2017 at 8:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No they won't. Wrong offset as found out recently by @turbodb 2nd gen wheels are sucked almost an inch in more than 1st gen wheels. So you'd rub the caliper with those wheels.
    Mind made up then haha
    turbodb likes this.
  20. Nov 22, 2017 at 8:04 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Do they fit the second gen 17" sport wheels? I also have 1.25" backspacers.
