  1. Nov 26, 2017 at 5:33 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Its that anti seize crap. Also changed the wires. Maybe its in my head, but the throttle feels nicer
  2. Nov 26, 2017 at 5:51 PM
    TacomTyler
    TacomTyler Well-Known Member
    Tyler
    Georgia
    2000 sr5 tacoma
    Anyone know if you can run these on top of 5100’s with stock control arms
  3. Nov 26, 2017 at 5:52 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Hey I just realized your local. Famous Stars and Stripes army surplus. Same parking lot as Harbor Freight on Main St. in El Cajon.
    djcharlee likes this.
  4. Nov 26, 2017 at 5:54 PM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    Sounds good. Where do you buy from...online or tire store?
    Right now we’re running 265/70R16 with 1.5” spacers, which tire sizes will fit?
  5. Nov 26, 2017 at 5:56 PM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Not sure but I think wheelersoffroad has a better deal for some.
  6. Nov 26, 2017 at 6:13 PM
    Long_Travel_2002
    Long_Travel_2002 Well-Known Member
    ivan
    memphis
    2002 tacoma LSA swap prerunner
    built supercharged LS, T56, Linked, caged.
    spent about 2.5 hours washing and cleaning the truck from yesterdays shenanigans :D :oldglory:
    jubei, Prayn4surf, LukeCC and 9 others like this.
  7. Nov 26, 2017 at 6:31 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Is that a heat pressure washer?
  8. Nov 26, 2017 at 6:37 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I'm running 10mm spacers on top of my 5100s and 881s
  9. Nov 26, 2017 at 6:38 PM
    Long_Travel_2002
    ivan
    memphis
    just a regular ole pressure washer
  10. Nov 26, 2017 at 6:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I wouldn't.
    Plus 5100s can lift the truck if you just precompress the coils
  11. Nov 26, 2017 at 6:40 PM
    HSmith_11
    Hunter
    Madison, Va
    Do you have hub to fender measurements?
  12. Nov 26, 2017 at 6:44 PM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Can you swap these on a currently installed rack ?
  13. Nov 26, 2017 at 6:47 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Replaced the inner tie rods. I think they were about done. While I was under there, replaced Outer tie rods, and installed an Energy Suspension bushing kit on the rack. (glad I did, the original center bushing on the rack was about 40% gone)
    SwampYota likes this.
  14. Nov 26, 2017 at 7:11 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I did
  15. Nov 26, 2017 at 7:14 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Both front sides are about 24"
  16. Nov 26, 2017 at 7:21 PM
    bayareayota
    Bay Area
    Prinsu 32" K02 OME
    What's the process ? May ask my shop to do it
  17. Nov 26, 2017 at 7:30 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I just did it. It's pretty straight forward. You'll have to remove the sway bar to give yourself enough room to pull the rack back and pound out the bushing on the driver's side that runs horizontal.
    I did it while I was replacing the tie rod ends (which probably made it easier to move the rack where I needed it) but I have seen it done with the tie rods attached.
  18. Nov 26, 2017 at 7:32 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    UssMoGn, jubei, Navelfunk and 5 others like this.
  19. Nov 26, 2017 at 8:06 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    turbodb[QUOTED] likes this.
  20. Nov 26, 2017 at 8:09 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I just got back on here today. I used a breather for a Camry. Part number is 90930-03136
