  1. Dec 17, 2017 at 3:20 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Sunday afternoon... putting everything back together... pull the parts out of the boxes (that were correctly marked with R and L part numbers) to find this...
    You want to hear me screaming profanities? Because this is how you get me to scream profanities.
    BYJOSHCOOK, jubei, SwampYota and 4 others like this.
  2. Dec 17, 2017 at 3:53 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Happen to me with tie rods ends.
  3. Dec 17, 2017 at 4:25 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Anyone know what these connectors under the fuse box are? I have a feeling they're related to the ADD system on a 4WD truck, but I have a PreRunner. Looks like the transfer case position sensor connectors.
    FLBAdrian likes this.
  4. Dec 17, 2017 at 4:28 PM
    UncleShrek
    UncleShrek Well-Known Member
    Houston, Texas
    2016 SR5 V6 Auto
    TRD Pro mats, LED low beam bulbs OEM side steps, LED interior bulbs, Meso chrome delete, American tonneau cover, Replica TRD grill w/red letters, debadged, 30% Tint on door windows, 70% on windshield
    Did the gauges today! White face and leds.
    Not bad but need more l.e.d.s
    Also, do i have to remove the bed to change the spare wheel mechanism?? I really want the answer to be no.
    Navelfunk, SwampYota, 95 taco and 4 others like this.
  5. Dec 17, 2017 at 5:13 PM
    weenerdog
    weenerdog Member
    2023 Barcelona OffRoad DCLB
    This weekend: Valve cover gaskets and eBay fuel injectors (allegedly "flow matched"). One of the original injectors is leaking after I turn it off, making it hard to start when warm.
    Lots of brittle plastic; rubber gaskets / hoses as brittle as plastic. Had to carefully chisel out the spark plug o-ring seals out of the valve covers; I thought they were hard plastic. Replaced PCV and grommet. Dressed all the electrical, replaced bad hoses, put it back together -- one of the injectors was pissing all over itself.
    Pulled it apart, the o-ring was torn. Swapped in a new o-ring. Put it back together. Ran like crap -- like 5 cylinders or less.
    Pulled it apart, put the original injectors back in . Put it back together. Runs smooth.
    Returning injectors. I can swap injectors in 40 minutes, now! Yay.
    u wish u could ride and jjsul like this.
  6. Dec 17, 2017 at 5:16 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Damn, how did you get the gear gauge in the cluster? I always thought about looking into doing something like that. It even has a spot already in the cluster for it.
  7. Dec 17, 2017 at 5:36 PM
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    Flexing stock on snow pile
  8. Dec 17, 2017 at 5:42 PM
    UncleShrek
    Houston, Texas
    2016 SR5 V6 Auto
    Came that way, i do have column shifter gear tho. Not sure if you noticed. Floor mounted shifters have them on the shifter mechanism
  9. Dec 17, 2017 at 5:42 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    eyyy I did that last year.
    0321170737.jpg 0321170736.jpg 0321170720a.jpg 0321170720.jpg 0321170721.jpg 0321170737b.jpg 0321170737a.jpg
    BYJOSHCOOK and Mrogers33[QUOTED] like this.
  10. Dec 17, 2017 at 5:43 PM
    Mrogers33
    Columbus, OH
    Hehe yes it was fun to see the limits
  11. Dec 17, 2017 at 5:58 PM
    sente3
    sente3 -
    North Jersey
    For sure. Mall crawling is good for doing truck stuff when you're not on a trail :anonymous:
  12. Dec 17, 2017 at 6:04 PM
    Shortman5
    Supercharged TRD
    Yeah, noticed that bit...but thanks buddy. My dads avalon has a floor shifter and the light in the dash. Our guage clusters are very similar. My cluster even has the cutout like the Avalon. The reason I asked.
  13. Dec 17, 2017 at 6:07 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    its the perfect testing ground when you finish working on the truck lol
  14. Dec 17, 2017 at 6:09 PM
    sente3
    sente3 -
    North Jersey
    Makes me wish that snow pile were still at work so I can see what the new leafs can do!
  15. Dec 17, 2017 at 6:49 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    they went to the vacuum solenoid valves for the 4x4 system.
  16. Dec 17, 2017 at 6:50 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah I thought early ADD used VSV's, I know later years used an electronic actuator. I would guess it's for the position sensor for the front differential maybe?
  17. Dec 17, 2017 at 6:53 PM
    devinzz1
    devin
    2023 aclb trd or mt
    nope the sensor "switch" connectors run down around the transmission. believe theyre coloured gray
  18. Dec 17, 2017 at 7:02 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Correct gap is 0.043". Did you use NGK or Denso plugs? Usually they come pretty close to the correct gap out of the box, I don't think I've ever had to adjust the gap.
    jubei likes this.
  19. Dec 17, 2017 at 7:02 PM
    1stgenyota2014
    1stgenyota2014 Well-Known Member
    Garrett
    2004 ext cab Black Tacoma
    Flatbed, OME springs, 5100 billies
    Took mine hunting today
    ClevSix, jubei, AZ4x4Taco and 14 others like this.
  20. Dec 17, 2017 at 7:05 PM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    Like that bed.
    ClevSix likes this.
