  1. Dec 20, 2017 at 9:43 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    If I was going to be getting a grade on my writing, I wouldn't be typing on my phone... or on a Truck Forum on the internet.
  2. Dec 20, 2017 at 9:45 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    It was only started recently. I've had P0120 off and on for 2 months and then the other popped up and off and on for like 3 weeks if that. May be I'm not tighten my cap down enough :notsure: Haven't seen the CEL in a few days
  3. Dec 20, 2017 at 9:54 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I wouldn't expect any sympathy.
    And I also am not going to put myself in a position where I am out in the woods with a neglectfully maintained rig, where I am going to have a catastrophic failure of a lower ball joint.
    Ball joints are a wear item. They should be inspected at regular intervals (manufacture recomendation is every 10,000 miles and/or every 3000 miles if regularly used in dusty or adverse conditions), and serviced when they show wear. If you do even half that... you can avoid a catastrophic failure of just about ANY lower ball joint.
    Will some LBJs fail sooner than others? Absolutely... but LBJs don't just snap with no sign of wear that would be noticed during routine maint by someone who knows what they are doing.
  4. Dec 20, 2017 at 10:00 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No doubt.
    Go for it.
    Everyone on here is simply pointing out the oem will last much longer. And unless you like checking LBJ play with a micrometer ever 3000 miles which you will definitely want to do with moog joints as you'll probably end up swapping them out ever 5-15k miles because your time is worthless. Be our guest. You'll be fine. Just spend a lot more time under the truck.
    I like wrenching on these rigs more than anyone. But I don't want to don't want to swap LBJ as often as I change oil.
    But you have ignored every person on here coming to you with evidence and experience on this subject.
    https://youtu.be/Jmrd1MbNkFs
  5. Dec 20, 2017 at 10:00 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Luckily I didn't get a code. I'll keep a close eye on it
  6. Dec 20, 2017 at 10:48 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    One reason I haven't done it. Need to soon tho :rolleyes:
  7. Dec 20, 2017 at 10:53 AM
    bayareayota
    bayareayota Well-Known Member
    Bay Area
    2004 Toyota Tacoma extra cab v6 Trd
    Prinsu 32" K02 OME
    Last night My truck doesn't turn over like it should (it was a cold start)
    It's a more of a slow sputter and not quick like it usually is.
    I replaced the spark plugs and Fuel Filter recently.
    Bad Fuel injectors?
    Bad starter ?
    Bad alternator ?
  8. Dec 20, 2017 at 11:51 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Anyone know a good service for resetting seatbelts after the airbags go off? I remember a good one on here. Just not the name. @1997tacomav6 was that you?
  9. Dec 20, 2017 at 11:57 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Is this a bad idea? I feel like it's a bad idea for my taco lean, shim on one side in the back doesn't seem right. I dunno though.
  10. Dec 20, 2017 at 12:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Get your battery load stested. Autozone will do it for free.
  11. Dec 20, 2017 at 12:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's a bandaid fix sure, but sometimes you need a bandaid right? Won't hurt anything longterm and a half inch is pretty harmless anyway.
    WildLand[QUOTED] likes this.
  12. Dec 20, 2017 at 12:19 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Cool cool thanks! Just seems like the OME spacer up front will not fix over an inch of lean in the back. Seems like this is more of a direct placement
  13. Dec 20, 2017 at 12:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you do this, get new leaf string ubolts too. You do not want to re-use ubolts.
    Speedytech7 likes this.
  14. Dec 20, 2017 at 12:21 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Even if I just put new heavy duty ones on with my lift a couple months ago?
  15. Dec 20, 2017 at 12:23 PM
    Speedytech7
    The front suspension is not 1:1 geometry, so the OME trim packer affects more than it seems it might but you're correct that it will help a lot more to have a little assistance front and rear.
    Also very true!
  16. Dec 20, 2017 at 12:23 PM
    Speedytech7
    yes
  17. Dec 20, 2017 at 12:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes. The threads on them are designed fro one-time use only.
  18. Dec 20, 2017 at 12:26 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Well, I guess the lean doesn't bother me too bad then :rofl:
    I'll probably do the front first and see how well that works for the rear. Thanks guys!
    jackn7 likes this.
  19. Dec 20, 2017 at 12:28 PM
    1997tacomav6
    Denver
    Nope not me, never had an accident in my truck
    GQ7227 and FLBAdrian like this.
  20. Dec 20, 2017 at 12:30 PM
    Speedytech7
    Just the seatbelts, thought the SRS computer needed some convincing as well. You trying to rob belts from a crashed truck?
