  1. Dec 27, 2017 at 3:33 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yes, and go to bed
  2. Dec 27, 2017 at 4:52 AM
    Speedytech7
    Do you know what cells it uses, some can be brought back pretty easily with low voltage and constant current and once the voltage comes up you can switch to constant voltage and sometimes they come right back to life. The battery as a system is designed to load balance when charging but if a cell discharges too far for whatever reason it may drop that cell from the array for safety because it's charge controller can't individually address it without affecting others. The controller may end up being an enemy though if it doesn't relearn.
  3. Dec 27, 2017 at 5:36 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    What kind of paint are you using on these parts?
  4. Dec 27, 2017 at 7:24 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's cheap. Been over 2.50 here in mt all winter.
    Gas crisis my ass.
    Was 4.50 in high school for me.
    Yeah..
    You need every port either capped or run to a hose.
    Or it'll never run right.
    If everything on the motor that needs vacuum has vacuum go buy some caps and just cap them off. I know on the later year trucks there are less vacuum lines on the motor.
    On my 96 I had problems not having enough vacuum ports.
  5. Dec 27, 2017 at 7:55 AM
    Madjik_Man
    Colorado Front Range
    Thank you for the appropriate use of air quotes :)
    Glad you are okay though.
    Blackdawg[QUOTED] likes this.
  6. Dec 27, 2017 at 7:59 AM
    MadbumsBum
    MadbumsBum Well-Known Member
    NW WA
    1999 Tacoma TRD 4x4
    I'll be following this closely. My wife and I have a 2007 Accord Hybrid and I dread the day the batteries give out.
  7. Dec 27, 2017 at 8:17 AM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Alright. I'll see if I can find some spare tubing, or I'll buy some. I can't remember where the fuel regulator line goes off the top of my head but I think that may be a culprit.
  8. Dec 27, 2017 at 8:36 AM
    BigSam1991
    BigSam1991 Well-Known Member
    Sam
    Got some snow in CT this past weekend.
    jjsul, UncleShrek, FLBAdrian and 3 others like this.
  9. Dec 27, 2017 at 9:17 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Rustoleum Self Etching Primer followed by POR15 too-coat. Comes out with a semi gloss finish.
    I had the Manual Hubs professionally powder coated.
    SwampYota[QUOTED] likes this.
  10. Dec 27, 2017 at 9:30 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Nice looking rig
  11. Dec 27, 2017 at 9:32 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I got the car for free, I can see why. Batteries are too damn expensive. The car does have almost 300,000 miles on it so I'm not surprised the Hybrid battery gave out. The gas engine is perfectly fine and it runs fine as a gasoline car but I can't get it SMOG'd due to the fact that the hybrid system is broken and throws a CEL.
    Hell I'm going to go pull the battery right now and load test it.
    FLBAdrian and foxrcing07 like this.
  12. Dec 27, 2017 at 9:34 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Apparently they are 'D' batteries in series. I'm going to go pull the battery and inspect it more.
    FLBAdrian likes this.
  13. Dec 27, 2017 at 9:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Just needs to see vacuum. So anywhere really.
  14. Dec 27, 2017 at 9:41 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    So just.. plug holes till it works?
  15. Dec 27, 2017 at 10:07 AM
    MadbumsBum
    NW WA
    1999 Tacoma TRD 4x4
    Bummer about the SMOG. I've seen people do an engine swap and add an alternator to get them going again as a gas only rig. Maybe you can find a swap on the cheap? We got ours for free too, only has 100k on it though and I think the batteries were already once replaced. It's a fun little V6 but doesn't really get much better gas mileage. My wife has enjoyed harassing me for having more power than my 2.7L. :(
    taco71742 likes this.
  16. Dec 27, 2017 at 10:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no the fuel regulator needs to see vacuum. Plumb that to one of the open ports.
    The bigger one is good for the brake booster. There should be 2. If you don't use the second one, cap it.
    Cap all the other ports on the supercharger that you aren't using.
    If you find something on the motor that needs vacuum, don't cap it, you need to plumb line to it and to the blower.
  17. Dec 27, 2017 at 10:17 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I think the fuel regualtor has some vacuum it's just not enough because of the other port that's open next to it. Brake booster is already good. It should only be a couple of things that actually need the vacuum to work right?
  18. Dec 27, 2017 at 10:25 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    No shit these came with a v6? Mine is only a 4 cyl.
  19. Dec 27, 2017 at 10:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah and there is the EVAP stuff. Your PS shouldn't need it. And there is the cams and PVC. If you look on the hood there will be a vacuum diagram, at least there should be, just make sure everything on it that needs vacuum has it. Then cap any extra ports.
  20. Dec 27, 2017 at 10:51 AM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Wait PVC or PCV? Either way, I think that one routs to the open port on the back. That just leaves a tube on the intake which I don't think even matters
    Edit: I don't have a diagram either which didn't help lol
