  1. Dec 27, 2017 at 12:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Did you unstake the nut first?
  2. Dec 27, 2017 at 12:48 PM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    Fiberglass and Custom bumper :rolleyes:
  3. Dec 27, 2017 at 12:50 PM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Looks like the hood somehow survived though, that’s a small victory!
  4. Dec 27, 2017 at 12:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is definitely no longer the case. These are sexy AF.
  5. Dec 27, 2017 at 12:58 PM
    Speedytech7
    It's a little funny that the Tesla has wider tires and a wider stance, and weighs more....
  6. Dec 27, 2017 at 1:00 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    @foxrcing07 When I did my upper ball joints, the spindles were off the truck. The ball joint press takes a 7/8 socket. I used a 2 1/2 foot breaker bar. There's a way you can lay them over and use the "c" of the ball joint press for leverage.
    It takes a good amount of force to pop them loose, but it's do-able. The threads on the tool are probably going to be really dirty, I cleaned the ones I had and lubed them well, before starting.
    The upper ball joints were a breeze compared to doing the lower control arm bushings... but now that I know the RIGHT way to do those, they wouldn't even be that difficult if I had to do them again.
  7. Dec 27, 2017 at 1:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It does not weigh more, but its close. All the rest is true..
  8. Dec 27, 2017 at 1:01 PM
    Speedytech7
    No shell or OSK put them about the same?
  9. Dec 27, 2017 at 1:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    see dirty pools post above.
    Ha! That is awesome. look at him now..
    yeah no. has crossed my mind though.
    so true! Will be an easy rebuild.
  10. Dec 27, 2017 at 1:05 PM
    Madjik_Man
    Colorado Front Range
    I'm literally like this: o_O trying to look at this picture.
  11. Dec 27, 2017 at 1:06 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My iPhone is full so I'm bypassing the 'memory full' message by saving from Snapchat, I have like 12,000 photos lol
  12. Dec 27, 2017 at 1:07 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Unstake?
  13. Dec 27, 2017 at 1:07 PM
    Madjik_Man
    'tis just a flesh wound.
    Pretty sure I have clear corner and fog lights for 01-04. If I can find them I'll send them to you.
    Unfortunately I do not have any of the three 01-04 bumpers I had at one point.
  14. Dec 27, 2017 at 1:08 PM
    Speedytech7
    Yeah, the driveline bolts like that are staked (dented) to prevent them walking off from vibration or sudden jarring.
  15. Dec 27, 2017 at 1:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks! But I have my stock corners and grill still. No way to mount the blinker anymore, sucker is shredded.
    can live without the blinker for now.
  16. Dec 27, 2017 at 1:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think that is enough but I've never weighed it with the canopy on. Its always been with the RTT and rack. :)
    The Tesla is ~4800 lbs.
  17. Dec 27, 2017 at 1:12 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Well.. looks like it's time for some rerouting of vacuum tubes
    Blackdawg likes this.
  18. Dec 27, 2017 at 1:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Touche lol
  19. Dec 27, 2017 at 1:23 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Very cool! Best of luck to you.
    I did the 9 year thing as well. Then went into credentialing program through La Verne University (I'm originally from CA.). I've been teaching elementary school for 18 years now. There are tough days/weeks/months/years, but I still love it.
    Dalandser[QUOTED] likes this.
  20. Dec 27, 2017 at 1:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Thank you! Drums come in handy for those stressful days lol.
    JPinFL[QUOTED] likes this.
