  1. Dec 27, 2017 at 4:59 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sweet, you're in the PHX area right? We should go wheeling sometime!
  2. Dec 27, 2017 at 5:20 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    It has been 90k miles since I last paid the dealership to clean the throttle body. I figure it's a bit overdue, and noticed it's looking gnarly in there when I did the spark plug change last month. Here is how it looked before I started:
    Here it is after. Now that TW forum has helped me become a do-it-myself mechanic, I won't let it go so long next time.
    Now, I'm not experienced, so I'm hoping someone could tell me if it's normal to have such a wide gap between the bore and the choke. I can easily see daylight through there in places. I'm also seeing quite a bit of wear on the left side as circled in the next picture. 320k miles on this TB assembly.IMG_20171227_112821310_LI.jpg
    I also cleaned inside the IAC (not pictured). Replaced the philips screws with hex socket head screws to make it easier to get it apart next time.
    Krazyoakes likes this.
  3. Dec 27, 2017 at 5:31 PM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    AD4D4092-F5A0-4477-82FC-8DB6B02E3260.jpg a second gen shortbed net fits perfectly in my bobbed first gen bed.
  4. Dec 27, 2017 at 5:53 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    With all that BTTF stuff I think you made the right call with a black (soon to be) 4WD Toyota truck. Surprised no bedlight rack w/ 4 KC lights up top and tube bumpers?
    “Check out that 4X4!”
  5. Dec 27, 2017 at 5:54 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have one, it's in my backyard waiting to be modified and welded. :D
  6. Dec 27, 2017 at 6:00 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    (Fire in the hole)
    Ti-Ci-kne-sium (special metal blend of one herb four spices) Moog parts only come with zerk fittings because they need all the help they can get. I don't think they sell soy sauce in a grease tube
    Speedytech7 and Silver02Taco like this.
  7. Dec 27, 2017 at 6:14 PM
    1997tacomav6
    Denver
    1)Make sure you installed the check valve and in the correct direction
    2) the tube on the left side goes to the power brake booster
    3) 1st tube in back goes to evap canister
    4) 2nd tube in back goes to the PCV valve
    5) fast idle hose from vacuum diagram has to T into the supercharger by
    throttle body and continue to the other side into the one way check valve
  8. Dec 27, 2017 at 6:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Fuck it. I'm doing this 4x4 conversion tonight. I have everything ready to go, I can't wait anymore.
  9. Dec 27, 2017 at 6:24 PM
    Speedytech7
    Better fire up your Mr. Fusion coffee maker first
  10. Dec 27, 2017 at 6:24 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    lol thats the spirit!
    It'll take 2-3 days anyways
  11. Dec 27, 2017 at 6:29 PM
    1997tacomav6
    Denver
    Some photos, I have a fuel regulator connected that uses a vacuum from supercharger too,
    Make sure check valve hose starts at high idle vacuum diaphragm and "T" s into supercharger
    and goes to the other side of engine to the check valve.
  12. Dec 27, 2017 at 6:29 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Hey fucker... I'm supposed to help. I need to see what I'm getting myself in to!
  13. Dec 27, 2017 at 6:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Ah shit I forgot, I gotta get this done though I can't go without my truck for more than a day or two. I really don't want to drive the Civic unregistered and insured. I plan on doing a full write-up and I'll take lots of pictures.
  14. Dec 27, 2017 at 6:36 PM
    Itchyfeet
    Needs to pick up some Bud Light
  15. Dec 27, 2017 at 6:50 PM
    1997tacomav6
    Denver
    SwampYota likes this.
  16. Dec 27, 2017 at 6:53 PM
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    Can’t wait!
  17. Dec 27, 2017 at 6:59 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I love my pneumatic, used hand op for 40+ years, until about 5 years ago. Wouldn't want to go back. Big advantage is that you can hold the tip and maneuver it for stubborn ones, while pumping the grease with one hand.
    Teke likes this.
  18. Dec 27, 2017 at 7:01 PM
    Speedytech7
    Mine still has it's first tube of grease cause I always end up somewhere out of range if the hose and I'm too lazy to plug it into the OBA on the truck haha. It is convenient when air is nearby though. I always use my one handed trigger style gun still have a free hand in case I need to hold the driveshaft or something.
  19. Dec 27, 2017 at 7:07 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol... totally get it dude. Good luck!
    You know what this means though... you gotta come help me with mine when I get in way over my head and all fucked up.
  20. Dec 27, 2017 at 7:21 PM
    MadbumsBum
    MadbumsBum Well-Known Member
    NW WA
    1999 Tacoma TRD 4x4
    Heck ya send it!
