  1. Dec 30, 2017 at 3:40 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    This is something I need to do. I have all the parts here, just need to get some time and motivation.
  2. Dec 30, 2017 at 3:45 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    yea, time is something i dont have.........or the tools someone stole my tool box but its ok since the box and tools were from walmart and most of the sockets were rounded and wrenches bent :) so i guess im pleased so i can buy proper tools. but i plan on doing the timing belt, waterpump job this spring as well as a coolant flush. which toyota coolant do we need?
  3. Dec 30, 2017 at 3:45 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I could probably get you the special service tool I made if you were looking to do it yourself
    stumbles[QUOTED] likes this.
  4. Dec 30, 2017 at 3:47 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I used this
  5. Dec 30, 2017 at 3:49 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    i like how it says "ASIAN formulated" just so you know that asain's mixed it for there vehicles :p
    Delta00[QUOTED] likes this.
  6. Dec 30, 2017 at 3:52 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
  7. Dec 30, 2017 at 3:58 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    About 12 hours North of Scottsdale...
  8. Dec 30, 2017 at 4:01 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    This is, absolutely, the next major project I'm doing on my truck.
    260,000+ miles on the original... I know I have gone well past pushing my luck.
  9. Dec 30, 2017 at 5:07 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    My water pump was leaking pretty good at 104000
  10. Dec 30, 2017 at 5:11 PM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    Replaced the K02's with these:
  11. Dec 30, 2017 at 5:13 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    how did your ko2's hold you up?
  12. Dec 30, 2017 at 5:25 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I’m really enjoying watching you work through this thing. I’m rooting for you. :cheers:
  13. Dec 30, 2017 at 5:26 PM
    synergy10
    San Diego
    I only put around 3-4k miles on them (bought them used with the wheels and they had around 3k miles on them already). Really liked them on road (smooth and quiet) but planned to replace them as soon as I got them (I never really liked the tread pattern on K02's, I know, not the best reason to not run a tire...haha).
    They do seem to be a good tire but I didn't really get to push them as much as I did with my previous Duratracs. I only took them off road once and they felt fine but it was nothing outrageous.
  14. Dec 30, 2017 at 5:30 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    i've had ko2's for about 2 years and i was disappointed with them. good tire for mall crawling but offroad was pretty blah to me.
    synergy10[QUOTED] likes this.
  15. Dec 30, 2017 at 5:32 PM
    Jaysjammin
    Jaysjammin Well-Known Member
    Jay
    Upstate SC
    '98 SR5 5-speed 4x4 3.4L, 07 FJ Auto 4x4, 97 Locked 80
    Didn't realize Volk made off road wheels. Look great, do they fit the 13WL?
  16. Dec 30, 2017 at 5:34 PM
    synergy10
    San Diego
    Good to know. My Duratracs were the first set of tires I used off road and they held up fine and worked great too. Then I wanted to run the newer Falken M/T's but they were out of stock when I was ready to buy. These STT Pro's were always on my list but the Falken's were cheaper. Discount tire had a sale so I ended up picking up a set of 5.
    Silver02Taco likes this.
  17. Dec 30, 2017 at 5:37 PM
    synergy10
    San Diego
    Jaysjammin[QUOTED] likes this.
  18. Dec 30, 2017 at 5:40 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I finally got around to putting in the new rear wiring harness on the truck today. Pretty easy really just a lot of up and down to pull the harness through. I had to drop the fuel tank just a bit to get to those two plugs there. There where a few plugs extra that my truck isn’t set up for so I just taped them up (the ones in the cab for the trailer). There where two others right over the axle so I asked @thefatkid what should I do and followed his advice. I stole the boy’s car and picked up some dielectric grease, heat shrink and some tape. Wrapped the plugs up. Pretty sure they are sealed good. The passenger side running light (I think that’s what’s it’s called) and the passenger side license plate light still doesn’t work but all brake lights work now. I do still have that loose wire in the tail light so hopefully once I get the new tail lights everything will work right.
    SwampYota and synergy10 like this.
  19. Dec 30, 2017 at 5:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Thanks! Front end is going in next.
    synergy10 likes this.
  20. Dec 30, 2017 at 5:54 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Looking great!
    I mounted mine with two bolts, 4 sealing washers, 2 nuts, 4 washers, 2 wing nuts, and some trimmed rectangular tubing (as a "mounting plate"). Order is:
    bolt from inside of rack, through sealing washer -> rack -> sealing washer -> nut -> washer -> trimmed rect tubing -> hi-lift -> washer -> wing nut.​
    Happy to make you up a set if you're interested; PM me.
    This'll work too!
    Another idea that'll work. I was just a bit worried about the security of a quick fist when on the trail.
    Teke[QUOTED] likes this.
