  1. Jan 2, 2018 at 8:48 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    None. I couldn't even align it with the dowel pins.
  2. Jan 2, 2018 at 8:49 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I love the 63s, but I'm not into the go-fast as much as you. They outperform the Dakars by leaps and bounds in my opinion.
    I probably wouldn't bother going with the Chevy's if the eventual plan is to LT the rear as well, you'd have to weld the stock hangers back on for SUA.
    Speedytech7[QUOTED] likes this.
  3. Jan 2, 2018 at 8:49 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Wouldn't go high enough? Should be able to lower it down.
  4. Jan 2, 2018 at 8:51 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Tight as can be. The front of jack slanted up so only two wheels are on the ground.
  5. Jan 2, 2018 at 8:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ha nice.
  6. Jan 2, 2018 at 8:53 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The bellhousing is hooked on the power steering rack. I can't lower the jack or make it higher.
  7. Jan 2, 2018 at 8:54 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    can you lift the back of trans by hand to gedt the wheels on the ground. Then lower it.
  8. Jan 2, 2018 at 8:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    lower the front of the truck.
  9. Jan 2, 2018 at 8:58 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    When you say lost pressure. It wont even hold the trans up at all?
  10. Jan 2, 2018 at 9:03 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    I have used decent quality ratcheting straps. Run both hooks up and over the frame one in front one in rear. Lifted a turbo 350 2ft off the ground, and was able to pivot and tilt due to not being strapped down to a trans jack.
  11. Jan 2, 2018 at 9:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    This trick works well haha, we did this with a Mopar 727, it was tippy but damn does it work.
  12. Jan 2, 2018 at 9:12 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I got it out with cribbing and a hi-lift jack - it lost pressure because the two front wheels were off the ground. It's working again now let's see what happens.
  13. Jan 2, 2018 at 9:13 PM
    Speedytech7
    Might need fluid if that's crippling it, you can use ATF as ghetto jack fluid
    Keep on Truckin' likes this.
  14. Jan 2, 2018 at 9:17 PM
    Adude
    Pnw
    04 Double cab
    Haha same 78 chevy had the trans jack shit out on me with the 208..? Gear drive tcase from full 2ish ft up. It smashed onto the top of my hand on concrete, threw the trans jack in the dumpster. Couldnt jack off for 3 months:anonymous::boom:
  15. Jan 2, 2018 at 9:18 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    This jack is dead. After I got it on the ground, it managed to work again but it won't go past a certain height while pumping the handle does nothing.
    I bought it Used off CL, maybe I got a bad one. I'll see if I can bleed it maybe? I have no idea at this point I'm just going to buy a new one.
  16. Jan 2, 2018 at 9:18 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I guess you only have one hand and no girlfriend.
  17. Jan 2, 2018 at 9:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Maybe I worded that bad, yes it held up the transmission still but pumping the handle does nothing.
  18. Jan 2, 2018 at 9:20 PM
    Adude
    Pnw
    04 Double cab
    2 a week for 3 years. It was highschool times.
    JKO1998[QUOTED] likes this.
  19. Jan 2, 2018 at 9:23 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Its low on fluid. Pour some atf in the little plug.
  20. Jan 2, 2018 at 9:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'll try that, do I have to bleed it?
