  1. Jan 4, 2018 at 10:31 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    All good glad the parts were under warrenty, the internet is hard to diagnose over. In the future being thorough with your discription, Ie just installed lights now...
    I worked on a ford for 4 days straight, It was brought over not running after a cap and rotor change. It was the loose ground wire on the back of the cap.
  2. Jan 4, 2018 at 10:54 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Anybody know the regular length of the standard king CO 2.0s springs?
    Having mine rebuilt and i wouldnt mind an extra 2 inches. (Yea, thats what she said) ;)
  3. Jan 4, 2018 at 11:03 PM
    tony2018
    tony2018 Well-Known Member
    Same, saving up for a lift plus leaf's.
  4. Jan 4, 2018 at 11:03 PM
    tony2018
    Makes sense.
  5. Jan 5, 2018 at 2:31 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    *sigh* I hope my steering rack is fine I don't want to have to go through that ordeal. But it could be worse.
    Dumbest thing I did was try to put diesel in the truck and realized the nozzle won't fit. Or try starting the engine without spark plugs
  6. Jan 5, 2018 at 3:19 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    So two weeks later and I finally tried to start the truck - nothing. When I turn the key to "start" and hold it you can hear a relay click from the integration module under the dashboard but the engine doesn't crank. No idea why.
    12v on the battery (11.8 according to scangauge) tried jumping it with another 12v battery no difference.
    Courtesy lights and buzzer operate as normal.
    The only dash related item plugged in is the instrument Cluster. The hazard light, airbag disconnect, radio, rheostat, and ECT button are not connected.
    No error codes on the scangauge.
    Starter is seated properly as far as I can tell? I spun the flexplate via the crankshaft pulley a couple times and I did not hear any binding. The positive and negative are attached to the starter firmly.
    The only sign of life is really that initial click when you turn the key.
    This sucks, lol.
  7. Jan 5, 2018 at 6:34 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don’t know anything about the 2.7 but I’d image you do the same thing Monte was telling me.
    Check connections and ground and all the good stuff.
  8. Jan 5, 2018 at 6:58 AM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
    You truck really doesn’t want to be 4wd..:facepalm:
    Make sure the truck is in park. Sometimes the link could be put on wrong.
  9. Jan 5, 2018 at 7:09 AM
    tony2018
    whole lot easier to remove, could be messy but its way easy to remove than a car.
  10. Jan 5, 2018 at 7:11 AM
    tony2018
    Check any connections you may have fiddled with, check battery voltage if you haven't used it in a while. Cold weather can do that to a battery.
  11. Jan 5, 2018 at 7:11 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This.
    Your tranny in park? Easy to leave the auto in the wrong gear.
    Why isn't the dash connected? Pretty sure the etc button needs to be plugged in at lease.
  12. Jan 5, 2018 at 7:39 AM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    You might want to check the area between the lower intake manifold and the head (right next to the injectors). I too am having some coolant disappear at roughly the rate you have. I noticed that the gasket between those two areas is leaking. I have a coolant residue pooling in that area. It was a little difficult for me to see because the upper intake manifold hides that area on the driver's side. To get a better view of it, you can try removing the upper timing cover.
    Speedytech7 likes this.
  13. Jan 5, 2018 at 7:43 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    At work and working on my truck. Driver coilover needs some adjustment. It sits lower than the passenger side
  14. Jan 5, 2018 at 8:40 AM
    2BeersPlease
    2BeersPlease Well-Known Member
    I feel your pain. I had a similar situation a few months ago. After a lot of input from members, and temporarily losing my mind, it ended up being a slightly loose positive terminal.
  15. Jan 5, 2018 at 8:59 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Check the neutral safety switch. Maybe step away and take a good nap. Restart fresh.
  16. Jan 5, 2018 at 9:06 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Waiting for doc to cut on my knee.
  17. Jan 5, 2018 at 9:10 AM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Got around to uploading some photos today!
    Freezing our asses off near Breckenridge, CO
    Unsuccessfully searching for hot springs near Crested Butte, CO
    Three from Black Canyon of the Gunnison, CO
    Jebediah, Reh5108, Jiveydude and 10 others like this.
  18. Jan 5, 2018 at 9:15 AM
    JKO1998
    Utah
    I did another Dumb yesterday after I got it all back together.
    When I started it up my dash didn’t light up and I got depressed really fast.
    I didn’t remember to put the fuse next to the starter relay. That fixed it real fast...
  19. Jan 5, 2018 at 9:21 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I hate that. I did that when I was lifting my truck. Just finished doing the rear suspension was like "yes she looks..... (sees the fronts not done) you moron"
    taco71742 likes this.
  20. Jan 5, 2018 at 9:29 AM
    TacoS805
    TacoS805 Well-Known Member
    So Cal
    2004 White 2.7L 4x4 5 speed Xtra Cab
    Dude, this is perfect! I've been looking at FWC for so long and drooling! Beautiful!
    How does the truck handle everything?
    Trowbocop[QUOTED] likes this.
