  1. Jan 5, 2018 at 9:40 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    So... I'm collecting parts for my next Taco Project. I'm looking to see if there is anything I am missing, or if there are things that may be beneficial to think about while I have this part of the truck dismantled. I'm going to have the coolant system flushed prior to avoid crap dislodging into the new water pump. Asking here because it looks like I'll get the best response, there's the most knowledge in this thread... and there really isn't a good place to ask the question without making a new thread.
    I'm ordering the following:
    (15 Pc Timing belt/Water pump Kit)
    Timing Belt
    Idler and Tensioner Roller
    Front Crank and Cam Seals
    Water Pump and Gasket
    Hydraulic Tensioner
    Thermostat and Gasket
    A/C Belt, Alternator Belt, PS Belt
    And:
    OEM Radiator cap
    Cooling Fan Pulley Bracket
    Silicone upper and lower radiator hose
    Anything I'm missing here?
  2. Jan 5, 2018 at 9:43 AM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
    To those who are running allpro expedition leaf packs, what shocks are y’all running? I’m starting to hear a loud ass thump from my RC shocks fully extending.
    I have the stock shock mounts btw.
  3. Jan 5, 2018 at 9:53 AM
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
    Did this last night! Couldn't finish everything up though and I still need to connect it to the airbox.
  4. Jan 5, 2018 at 10:04 AM
    GreenMachine8
    GreenMachine8 Well-Known Member
    Elko, NV
    1996 Olive Drab Tacoma DLX 2.7L 4X4
    Off road fiber glass, rhino lined olive drab, retrofit headlights, kings/total chaos mid travel suspension.
    Does anyone have a part number for a 96 2.7L 4wd transmission mount?
  5. Jan 5, 2018 at 10:10 AM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Handles great- gvw is 6560lbs. A bit of body roll without the sway bar, but dakars + aal & firestone airbags handle the weight easy. It's 700lbs dry, but well over 1k with a year's worth of gear in it and sh*t bolted on to it. Handles great offroad, just take it slow going up and down steep hwy areas like dropping into Jackson Hole, WY on the 22 from Victor, ID. That was a rough descent with the weight.
    So glad I removed the sway bar, we hit a semi tire+wheel assembly the other day at 70mph heading across western TX. Bucked the front end up, flipped the tire up like a knuckle puck, & the rear part of the sliders & frame hit it and bucked the rear end up too. We thought we were going to roll and die, but with the suspension & armor we made it out unscathed. Another car that hit it was a Honda, they hit it right before us by about a minute. Destroyed their front bumper, they lost a headlight & the entire side of their car got jacked up. Adventuremobile FTW!
    A Mo Cat and m3bassman like this.
  6. Jan 5, 2018 at 10:18 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have a feeling it's the whole not being and park thing and maybe the shift interlock. When the truck is past the START position you can't move the shifter out of park - I feel like the shift interlock is bad. I'm using the black shifter out of a 4Runner.
    I'll go unhook the linkage and move it physically to park
  7. Jan 5, 2018 at 10:27 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can just try the release button on the top of the shifter as well.
    And i still think you need the ECT switch in as it talks to the tranny ecu.
  8. Jan 5, 2018 at 10:35 AM
    taco71742
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    Here’s this if it helps any. I believe the lever for park should be pushed all the way to the back toward the rear end of the the truck
  9. Jan 5, 2018 at 10:49 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I'm using billies 5125 12" I but there not at the stock locations. I do here a knock as well though but that's only when it's really cold outside
    taco71742[QUOTED] likes this.
  10. Jan 5, 2018 at 10:52 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    5 new Cooper STT pro's just balnced/mounted.
    I've been running the discontinued BFG AT for many yrs. They have been great, reliable tires. Thought I would give these a try.
    Jebediah, Navelfunk, Reh5108 and 15 others like this.
  11. Jan 5, 2018 at 10:55 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Damn fine looking truck.
    UncleShrek and Matic[QUOTED] like this.
  12. Jan 5, 2018 at 10:58 AM
    Matic
    Tricky Dick
    Easley, SC
    Thx. 2nd new vehicle I ever purchased.
  13. Jan 5, 2018 at 10:58 AM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Got my LBJ today :woot: also went with OEM steering rack bushing cause I don't have time to wait for Energy Suspension to come In The mail... What lube is best for OEM and what lube is best for the Whiteline?
    SwampYota and Matic like this.
  14. Jan 5, 2018 at 10:58 AM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    x2 that looks great @Matic !
    Matic likes this.
  15. Jan 5, 2018 at 11:06 AM
    kmcmahon5
    kmcmahon5 Well-Known Member
    B.C.
    1996 Tacoma, 1989 pickup
    [​IMG]Untitled by kyle mcmahon, on Flickr
    What is the proper way to access the nuts for the bed bolts? Just cutting a hole in the bed and patch it up? In the meantime, still waiting on my SCS wheels to arrive then wrap them with some Stt Pros
    Matic likes this.
  16. Jan 5, 2018 at 11:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you stripped out the catches, yes sadly. Had to do that to one of mine.
  17. Jan 5, 2018 at 11:11 AM
    kmcmahon5
    B.C.
    Ya I recently put a new bed on and the nut is actually missing. Had to do it on my old one too. Hopefully do a cleaner job cutting this time around haha
  18. Jan 5, 2018 at 11:15 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Getting a new knee? I got 2. You are gonna love being pain free.
  19. Jan 5, 2018 at 11:20 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Has anyone ordered from streetaco before?
  20. Jan 5, 2018 at 11:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I used a holesaw. Worked great.
