  1. Jan 9, 2018 at 10:02 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    thinking about bumping up to the 700lb coil. I have icon 2.5s. Kings sells theres for 85 each and icon sells theres for 120 a piece, anyone use the kings?
  2. Jan 9, 2018 at 10:04 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Glad that turned out to be easy & hope that fixes the oil leaks.
    Teke[QUOTED] likes this.
  3. Jan 9, 2018 at 10:27 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    @Digiratus runs 700lb kings.
  4. Jan 9, 2018 at 10:40 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Why do you feel you need a 700# coil?
  5. Jan 9, 2018 at 10:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    x2.
    How much weight are you running?
  6. Jan 9, 2018 at 11:01 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    So it's light...
    m3bassman[QUOTED] likes this.
  7. Jan 9, 2018 at 11:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah, shouldn't need 700s for that.
  8. Jan 9, 2018 at 11:05 AM
    Dan8906
    Daniel
    Concord, California
    All-Pro Apex bumper, winch, skids and sliders. Im thinking about going up because I have the pre load pretty much maxed out. Also with 700lb coils i could ditch my swaybar
  9. Jan 9, 2018 at 11:06 AM
    Speedytech7
    What winch and are you using synth cable?
  10. Jan 9, 2018 at 11:07 AM
    Dan8906
    Daniel
    Concord, California
    Smittybilt x2o 10k with sythn rope. Runs about 70ish lbs
  11. Jan 9, 2018 at 11:07 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Cool thanks. Yeah I learned that the hard way when I went from a 02-03 motor swap. Just wanted to make sure there wasn’t any changes from 03 to 04
  12. Jan 9, 2018 at 11:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah. Well with a winch then you could. What are you running now? Id probably go with 650s. 700s won't be bad but would not want to preload them much.
    Also. you can ditch the sway bar now. Im sure.
  13. Jan 9, 2018 at 11:10 AM
    Speedytech7
    650s can hold quite a bit on the Icons, besides skids he was pretty similar to my old setup. I'd see about getting new 650s, I didn't hardly need any preload to maintain ~2.25" of lift.
  14. Jan 9, 2018 at 11:10 AM
    Dan8906
    Daniel
    Concord, California
    Im at 650 currently, I took it off and put it back on because I didnt care for the ride. But since then I have switched my all pro standard leafs with expos so that might make a difference.
  15. Jan 9, 2018 at 11:11 AM
    Dan8906
    Daniel
    Concord, California
    They coils are less than a year old.
  16. Jan 9, 2018 at 11:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes that will.
    Either way. 650s should be okay unless your trying for more lift. Then 700s would be better.
    No matter what, 700s will last longer.
  17. Jan 9, 2018 at 11:13 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Keep in mid that Icon coils are only 13" tall so they alway will have more threads showing that a 14" coil like King and Eibach (Fox) use.
    BYJOSHCOOK likes this.
  18. Jan 9, 2018 at 11:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    damn i always forget that..
    @Dan8906 a 14'' coil alone will help a LOT vs a 13''.
    Even a 14'' 650 will make a big difference. Id do that first.
    Silver02Taco likes this.
  19. Jan 9, 2018 at 11:16 AM
    Dan8906
    Daniel
    Concord, California
    I thought about doing that, but I was concerned it wouldnt make much difference. didn't want to waste money trying it out.
  20. Jan 9, 2018 at 11:19 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Turns out i have 650s.
    Blackdawg[QUOTED] likes this.
