  1. Jan 9, 2018 at 7:56 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    OME Nitrochargers and 881's up front, stock UCAs. The 881's have sagged a bit so the lift is MAYBE 2" max. I'm probably gonna drop it off next week sometime and try to get them to get a little more caster, but I'm still happy with it as a starting point.
  2. Jan 9, 2018 at 7:57 PM
    wat0023
    wat0023 Well-Known Member
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    Picking up an 03 DC 4x4 in Black Sand Pearl tomorrow! Super pumped to back in a Tacoma and super pumped to start slowly making it own! Been skimming through this thread and I've seen a lot of awesome stuff!
  3. Jan 9, 2018 at 8:01 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    THEyre not going to be able to get the caster above a degree with stock uppers. You’ll need adjustable ones to get the caster within spec. And when I do alignments I try and make the caster .3 degrees lower on the drivers side vs. passengers side to compensate for the horrible road crown we have here in Phoenix...I was just curious.
    Captain Magma[QUOTED] likes this.
  4. Jan 9, 2018 at 8:13 PM
    Captain Magma
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    I had SPCs, but had to sell them before I ever installed them, need $ for a security deposit :pout:
    I figured caster was already pretty max'd with the stock UCAs, but may as well make use of the lifetime haha
  5. Jan 9, 2018 at 8:38 PM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    The one I drew up. It was two years ago, man, I can't tell you what I had for dinner last night. :) I want to say it started at the corners, torqued the opposite corners first, then torqued the bolts in the center next in a similar cross pattern. I think the real key is to make sure all of the bolts are torqued evenly and methodically rather than using one specific pattern. Going up in increments also, that keeps the gasket from tweaking out.
  6. Jan 9, 2018 at 9:21 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Ahhh no worries then thanks for the tips! I'm thinking I'll have to do this soon or replace them as they have started to ever so slightly weep
    TheSaint[QUOTED] likes this.
  7. Jan 9, 2018 at 9:22 PM
    Goran
    Goran Well-Known Member
    Jacob
    WA
    2023 Tundra Pro
    I don’t, I work at a place called greenshield industrial supply. (We do rigging, hydraulic hoses, brake lines etc..)
    But I’ve been to West coast and I know they are one of the bigger shops in Seattle.
  8. Jan 9, 2018 at 11:57 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    First tracks early this morning
  9. Jan 10, 2018 at 3:48 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Drove on sheer ice this morning on my way to work. I don't think there was a moment where the truck wasn't going sideways.
    Keep on Truckin' and taco71742 like this.
  10. Jan 10, 2018 at 5:20 AM
    NCforMe
    NCforMe Active Member
    Ben
    Crystal Coast, NC
    Taco SR5 4x4, 2.7l
    [​IMG] Rebuilt my grill cover a bit differently this time.
  11. Jan 10, 2018 at 6:04 AM
    mikeymike2189
    mikeymike2189 Well-Known Member
    Didn't do anything to the Tacoma today other than pay my loan off on it. Now its time for me to buy a supercharger and have fun:bananadance::bananadance:
  12. Jan 10, 2018 at 6:07 AM
    NCforMe
    Ben
    Crystal Coast, NC
    Taco SR5 4x4, 2.7l
    a supercharger for your 1st gen?
  13. Jan 10, 2018 at 6:21 AM
    mikeymike2189
    yessir, I have a 01 prerunner and i just happen to work at toyota so install will be pretty cheap and quick lol
    lucky13don likes this.
  14. Jan 10, 2018 at 6:35 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Lucky guy lol all of those oem parts in arms reach lol
    mikeymike2189[QUOTED] likes this.
  15. Jan 10, 2018 at 7:01 AM
    mikeymike2189
    haha yeah I'm actually the parts manager so i get to look up all the things i want, wiring diagrams pretty much anything.
  16. Jan 10, 2018 at 7:05 AM
    JKO1998
    Utah
    Wanna sneak a couple lower ball joints out for me????
  17. Jan 10, 2018 at 7:26 AM
    mikeymike2189
    LOL i can do the best deal i can.
  18. Jan 10, 2018 at 7:34 AM
    JKO1998
    Utah
    And what’s that?
  19. Jan 10, 2018 at 7:34 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    That looks pretty cool, is it perforated so air can flow through it? Hard to tell from the pic, almost looks solid.
  20. Jan 10, 2018 at 7:43 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    That may apply to the general properties of a "spring" but the potential of 12" or 13" does not matter to a constant rate spring, every inch of travel is exactly 500lbs or whatever the rate is. If your ride height stays exactly the same all you are doing is moving the collar up 1" from where it was before. The block heights are not proportional because they have to change the winding and/or coil thickness to achieve exactly 500lbs for each inch of travel for every different length spring, its not as easy as just making the spring longer because then potential energy does change like you mention
