  1. Jan 10, 2018 at 9:05 AM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    2025 SR5 4x4
    I’m getting close to 200k. What maintenance stuff did you guys do when you got to that mileage?
  2. Jan 10, 2018 at 9:07 AM
    tony2018
    tony2018 Well-Known Member
    Damn. you. Not to mention a specific discount.
  3. Jan 10, 2018 at 9:55 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Same as always keep up on regular maintenance. Things that may need changed that haven't are timing belts, ball joints, shocks if original may be toast and keep an eye on your valve cover gaskets
  4. Jan 10, 2018 at 10:06 AM
    mikeymike2189
    mikeymike2189 Well-Known Member
    haha yea its nice sometimes
  5. Jan 10, 2018 at 10:15 AM
    Tacotruck7
    SoCal
    2025 SR5 4x4
    I bought the truck with 180k so I’m trying to get back to a “base” so I can know where I am coming from. I’ve done the suspension all myself. Timing chain cover (2.7) gasket was replaced before I bought it. LBJ’s were deemed good last check up. So maybe just valve cover and spark plugs? I just did my rear diff oil too.
  6. Jan 10, 2018 at 10:21 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Since it is a 2.7 and you're near 200k I would have Toyota make sure the valve clearance is set right, they tend to tighten up on the exhaust side and if left for too long will crack the head. Had it happen to mine, ended up having to replace the head all because the previous owner didn't check and adjust every 50-75k like they recommend.
    CowboyCaddy and Reh5108 like this.
  7. Jan 10, 2018 at 10:28 AM
    Tacotruck7
    SoCal
    2025 SR5 4x4
    Awesome. I’ll have them do that! Anything else that’s major that I should have them do?
  8. Jan 10, 2018 at 11:06 AM
    Speedytech7
    It's a pretty low maintenance engine and transmission really other than the valves, if it is running nicely then just keep up on the usual oil and such. Denso OEM spark plugs or NGK v-Power plugs when you do those.
    drock3 likes this.
  9. Jan 10, 2018 at 11:48 AM
    BerndtTaco
    BerndtTaco Active Member
    95.5 Tacoma 2.7 4x4
    3 inch Rancho lift, custom front and rear bumpers
    This is the first I've heard of getting this done. What's the average price? Are there any signs that you could tell that they are becoming out of spec before hand or just have to take it in and find out?
    CowboyCaddy likes this.
  10. Jan 10, 2018 at 11:49 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Anyone have a write up on how to remove u joints?
  11. Jan 10, 2018 at 12:13 PM
    Speedytech7
    Couldn't tell you the price, I had the whole head replaced and reassembled so my clearances were set when that was done and that whole process would cost much more than an adjustment. Unfortunately these engines are kind of quiet to begin with and they only get quieter as the issue gets worse (unlike old Chevies and such where you could hear the valve train making new noises and know it was time for an adjustment). Have to measure the clearance with feeler gauges record all of them, then cams have to come out and then a special tool is used to press down the bucket to remove the shim which can then be measured with a micrometer to determine what new size shim is needed after comparing all the clearances and their differences to the expected spec from the factory.
  12. Jan 10, 2018 at 12:15 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I changed my valve cover gasket over the summer decided to check the valves while in there. The exhaust valves were almost all out of spec. I didn't know it was a common issue until I started researching it. Motor has 230k on it.
  13. Jan 10, 2018 at 1:04 PM
    BerndtTaco
    95.5 Tacoma 2.7 4x4
    Is this something that should always be done by the dealer? Or just highly recommnded?
  14. Jan 10, 2018 at 1:06 PM
    Speedytech7
    I'd recommend it but you can certainly have someone else do it, hell you could do it yourself but the special tool and the assortment of shims isn't cheap and most Toyota shops don't have a full set to sell rather just have some to replace themselves.
  15. Jan 10, 2018 at 1:07 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What joint?
  16. Jan 10, 2018 at 1:07 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    U-Joint
  17. Jan 10, 2018 at 1:08 PM
    Speedytech7
    Someone say joint? :rasta:
    jjsul, Silver02Taco and Fernando like this.
  18. Jan 10, 2018 at 1:08 PM
    JKO1998
    Utah
    What one on the drive shaft though.
  19. Jan 10, 2018 at 1:08 PM
    RedManRocket
    Red
    2002 Double Cab LT
    My man!! :D
  20. Jan 10, 2018 at 1:08 PM
    JKO1998
    Utah
    Not in Utah....
