  1. Jan 10, 2018 at 4:29 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    No shit really? No idea the 4x4 ECU's did that. Can't you just unplug the transfer case position sensors so the ECU can't tell if you're in 4Lo?
  2. Jan 10, 2018 at 4:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I don't know I have never had an ADD or auto 4x4 truck to test it on. The ADD truck have a separate 4x4 "computer", really a relay pack to make sure the ADD engages. The manual hub auto trucks probably just went off the position sensor on the case so yeah that would likely work.
  3. Jan 10, 2018 at 4:38 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    No, it’s a 97. Came stock with manual hubs 4x4
    Tacotruck7[QUOTED] likes this.
  4. Jan 10, 2018 at 4:46 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Can’t say I’ve ever needed overdrive in 4lo...it’ll do like 35 in 3rd gear in low range
  5. Jan 10, 2018 at 4:47 PM
    Speedytech7
    50 with 3.58s and a five speed haha
    drr[QUOTED] likes this.
  6. Jan 10, 2018 at 4:53 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    That low range gear must have been howling.
  7. Jan 10, 2018 at 5:05 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Can anyone with a 2.7l 4Cyl 4x4 help me out? I have no idea where the hell this dipstick is supposed to mount to. Both the supports are just floating there nowhere to bolt to.
    This is the only way I could physically get the tube in so I'm not sure if it's right.
    @ToxicTwin
  8. Jan 10, 2018 at 5:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Okay. I tried starting the truck, it started up fine no issues there. Then I put the truck into drive, no issues. I put it into 4HI, I hear this terrible grinding noise. I started the truck again in 2HI but put it into reverse. No problem I can see the output shaft spinning.
    I put it into park from reverse... terrible grinding noise.
    Shit. Any idea what it could be? I'm at a loss for words.
  9. Jan 10, 2018 at 5:51 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Your truck refuses to 4 wheel drive.
    Give it to me.
  10. Jan 10, 2018 at 5:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It really refuses to do anything right now. God dammit.
  11. Jan 10, 2018 at 5:53 PM
    JKO1998
    Utah
    Shoulda got a Prius
    03 NIGHT TACO likes this.
  12. Jan 10, 2018 at 5:55 PM
    JKO1998
    Utah
    Sorry, back to your truck. I’m sure someone will have something helpful, that someone isn’t me.
  13. Jan 10, 2018 at 6:03 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah but i can do 50mph with the stick. Go fast man :burnrubber:
    I find it a pain that i have to constantly stop to put it back in high range.
    so did you know for sure if the tranny was 100% good before you got it?
  14. Jan 10, 2018 at 6:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I bought it from a junkyard, they told me it was tested but who really goddamn knows. The fluid that came out of it was black like motor oil but there were no metal shavings or anything. Fluid wasn't burnt just black. I had a whole thread about it months ago general concensus was that the tranny was fine, but not well maintained.
  15. Jan 10, 2018 at 6:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well it sounds like a syncro is fucked.
    However..
    Where is the grinding coming from? Tcase or the tranny?
  16. Jan 10, 2018 at 6:07 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I can't tell. It's coming from the front maybe?
    It could be that I didn't fill it full of fluid. I poured about 6 liters in before starting the engine and running the tranny to circulate fluid, that's when I heard the grinding. I poured the full 2 gallons or 7.5 liters in there from the bottles that I had.
  17. Jan 10, 2018 at 6:11 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    can't hurt to check again the fluid level.
    Also if you have a spare hand to shift you could get under the truck to see if its the tranny or the tcase.
  18. Jan 10, 2018 at 6:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Kind of scared to shift it again. Guess I'll never find out what it is if I don't though.
    Blackdawg[QUOTED] likes this.
  19. Jan 10, 2018 at 6:21 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    http://www.ruffstuffspecialties.com
    Even bought all the DOM tubing through them, cheaper than anything local. Get on the mail list and they'll send 20% off coupons once in a while.
  20. Jan 10, 2018 at 6:28 PM
    Speedytech7
    You should only shift the t case if the trans is in neutral, if the tcase was in neutral you'd get brutal grinding if the trans was in park. I think your trans is fine but start everything in 4hi for now since you have no rear shaft.
