  1. Jan 14, 2018 at 2:20 PM
    tony2018
    tony2018 Well-Known Member
    If I did go with fx-r's I'd still find a way to use the stock rubber boots. You'll not anything that big to cover that big hole.
  2. Jan 14, 2018 at 2:28 PM
    RedSki7
    RedSki7 CRF | TRD | PBR | 802
    Hollis
    Vermont
    06 AC V6 TRD OR 6sp | 02 RC 2.7L SR5 4x4 5sp
    Duck Tape, Zip Ties, & Spray Paint
    Do you have a thread on how to install a compressor? Would really like to add one to mine!
  3. Jan 14, 2018 at 2:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just get the d2s v4. Supposed to be just as good if not better than fxr and require no mods to the head light to fit.
  4. Jan 14, 2018 at 2:30 PM
    tony2018
    Thats what I have, still stretched the rubber boot cover to fit the d2s bulb opening.
  5. Jan 14, 2018 at 2:44 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Bailey and I cleaned up the garage. (Nice to have it back to where it should be after the Christmas decor etc is put away)
    Decided to clean up the engine compartment too. Wanted to have it clean before doing the water pump, timing belt etc.
    jubei, Navelfunk, BYJOSHCOOK and 5 others like this.
  6. Jan 14, 2018 at 2:44 PM
    lsaami
    lsaami Redneck Toyota boi with a rice-burner Honda
    Minnesota
    2000 Tundra Limited 4.7L v8 4x4
    2" lift, Grille Guard, Cab Visor
    Topped off the coolant, power steering fluid, and washer fluid.
    vonellis and FLBAdrian like this.
  7. Jan 14, 2018 at 2:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I just bent it back. I bent it the other when I was rocking my truck back and forth out of snow drift, sagebrush sealed the deal.
    I reallly have no need for real skids, don’t ever remember feeling When I’ve came down on a rock or something. Mainly because, you know, ima poser that just drives mountain roads.
    But something that isn’t rusting apart is definitely on the list.
    03 NIGHT TACO likes this.
  8. Jan 14, 2018 at 2:57 PM
    tony2018
    Time to put on that skid plate i got. Darn thing looks powder coated.
  9. Jan 14, 2018 at 3:00 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So... been thinking about what you said. Definately going to change the radiator when I do the water pump etc. (some of the parts already on order, more parts being ordered now).
    I'm looking in to ordering the radiator and I'm seeing two different sizes. (approx) 18 in, and (approx) 22 in, measured from tank to tank. I believe I'm the larger of the two, but it's impossible to measure without having it out of the truck.
    I am a 3.4L, Auto, Prerunner, TRD... BUT... I am going to be swapping to 4x4. I'm pretty sure the Prerunner has the same radiator as the 4x4, but would like to know for sure.
    Anyone have input on which size radiator I should order?
  10. Jan 14, 2018 at 3:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The auto radiators are bigger as they have a built in tranny cooler at the bottom. That's the one you want.
    koditten likes this.
  11. Jan 14, 2018 at 3:08 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Beautiful... that's what I thought, but wasn't 100% sure. Thanks for clearing it up :thumbsup:
  12. Jan 14, 2018 at 3:14 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    If I could do it over I'd go with ds2, fxrs are a fucking pain. But it's too late for that now...
  13. Jan 14, 2018 at 3:30 PM
    1997tacomav6
    Denver
    Reasons why???
  14. Jan 14, 2018 at 3:32 PM
    tony2018
    Just stretch it.
  15. Jan 14, 2018 at 3:32 PM
    JKO1998
    Utah
    They’re wore out, can’t really have down time. It’s a ways off probably just gonna but some blocks for my stock shocks while they’re being rebuilt.
  16. Jan 14, 2018 at 3:36 PM
    1997tacomav6
    Denver
    Ok, just thinking of this route for me, how long did they last? And cost for rebuilding
  17. Jan 14, 2018 at 3:47 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Not with fxrs, there's nothing to attach it to, you have to cut it off. But what I'm wanting is something to cover the bulb itself.
  18. Jan 14, 2018 at 3:52 PM
    JKO1998
    Utah
    Well.... I’ve had them for 1.5 years and got them used, so who knows how long the PO had them. 40k is probably what I put on them (I’m not a role model for maintenance, obviously).
    From what I’ve found it’s aboht 120$ish per shock plus shipping and whatever. I’m almost positive it’s possible to do yourself, I just don’t trust myself.
  19. Jan 14, 2018 at 3:53 PM
    tony2018
    doesn't have to be 'attached', just stretch it over the opening, put some lube on it if you think its gonna be tight up in there. all men should know this by now
  20. Jan 14, 2018 at 3:55 PM
    tony2018
    120 per shock ain't so bad, the extra dough you have to spend though for no downtime... did you look into renting a truck/suv?
