  1. Jan 14, 2018 at 9:13 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Did a little exploring today and tested out the new Billies.
    jubei, Navelfunk, BYJOSHCOOK and 4 others like this.
  2. Jan 14, 2018 at 9:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    It was pricey. But quality!
    Dicks!!! Lol
    nagorb[QUOTED] likes this.
  3. Jan 14, 2018 at 9:25 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I did mine. They look okay but i didn't really prep them
  4. Jan 14, 2018 at 9:26 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Compared to real life, I'm a saint on here!
    Fernando[QUOTED] likes this.
  5. Jan 14, 2018 at 9:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I can help if you need it. Pretty easy really, just need a compressor, some sort of air manifold, pressure switch, relay to control power to the compressor with the input from the pressure switch, and some sort of switch to control it all from in the cab.
    I'll list the parts that I used...
    https://smile.amazon.com/gp/product/B00NAHIUBQ
    https://smile.amazon.com/gp/product/B00RMC4J2Y
    https://smile.amazon.com/gp/product/B00DE7KMTK
    https://smile.amazon.com/gp/product/B016QT1UIO
    https://smile.amazon.com/gp/product/B00C0SATHE
    https://smile.amazon.com/Brand-Carling-Rocker-Switch-Compressor/dp/B00SM4Q5YQ
    BYJOSHCOOK, SwampYota, HCFab and 5 others like this.
  6. Jan 14, 2018 at 10:22 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Check Wedge Engineering for aftermarket seat mounts.
    Speedytech7[QUOTED] likes this.
  7. Jan 14, 2018 at 10:27 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Never disappeared. It’s just more entertaining to sit back and watch chaos.
    jubei, turbodb, 04doublecab and 13 others like this.
  8. Jan 14, 2018 at 10:46 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The "techs" at Firestone have dropped mine on there heads a few times. Nor sure how one doesn't see a piece of 3/16 steel as being heavy before unbolting it.
    jubei likes this.
  9. Jan 14, 2018 at 11:01 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  10. Jan 14, 2018 at 11:08 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    You didnt put a tank in? I did on mine and it seems to be nice to those compressors they got pretty warm. 4:30 to fill all 4 32x11s from 15psi to 33psi.
  11. Jan 14, 2018 at 11:09 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Well, I just got home from a gigantic pain in the ass maintenance: Replacement of Main Leaf bushings.
    Let's start with the hard side - driver's side.
    Breaker bar was laughed at by the bushing.
    Gathered the sawzall and after 4 blades, 4 battery packs and at least an hour or more, the bolt was cut off at both ends (only on the drivers side only).
    Committed now.
    Then hammered the cut bolt shaft, not noticing the bolt sleeve was fused to bolt AND the bushing.
    Turns out the bolt, bolt sleeve, bushing AND the leaf sleeve were all fused together with rust and bushing material.
    "F"!!!!
    Grabbed drill and drilled out the bushing material and after 20 minutes of material removal, the bolt/bolt sleeve were out.
    The remaining bushing material was removed by the combination of:
    Razor blade, knife, 1 1/4" hole saw, chisel, wire brushes, rasp/file, mini wire wheel.
    @Wheeler's Off-Road Inc
    And now the fun part...
    Bought the Daystar's greaseable bolts and bushings from Wheelers and clearing informing several times that I have Dakars for 03 Tacoma. I also bought rear shackle bushings at the same time.
    Test fit the bushings and they are 1/8 in diameter too big -> they don't fit in the leaf loop hole.
    My bud had extra OME main bushings = same size = so its not the Daystar's NOR the OME bushings.
    We ended up trimming the OMEs down about 1/8" all around with multiple test fits and finally they fit.
    Torqued down to 116lb.
    4+ hours...
    I didn't buy these leafs but I did peal of the Dakar sticker off the passenger side leaf.
    Any thoughts on the leaf? I have to do the Passenger side next week...
    Speedytech7 likes this.
  12. Jan 14, 2018 at 11:09 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Getting the call tomorrow morning telling me what the the extent of damage is on my transmission and drivetrain.
    Hope I didn't snap the crankshaft or some shit like that.
    SilverGhost likes this.
  13. Jan 14, 2018 at 11:10 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    :fingerscrossed:
  14. Jan 14, 2018 at 11:13 PM
    Speedytech7
    Nope, no tank here. I thought about putting one in but really the only thing that would aid in would be use of high consumption things like air tools and I don't have much plan for that. I've never timed how long the compressors take to air up but it is pretty quick, usually finished before friends. Heat hasn't been an issue yet, I have the hood open when I use them but they're both 100% duty cycle at 150psi or so.
  15. Jan 14, 2018 at 11:14 PM
    Speedytech7
    I really doubt that would happen, bet it is just the flexplate. You did everything else that should have been done by the looks of it.
  16. Jan 14, 2018 at 11:16 PM
    Speedytech7
    My Dakar's came without any bushings so I never had to endure removing stock style pressed bushings. Hopefully the other comes out easily for you!
  17. Jan 14, 2018 at 11:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I sure hope so. That grinding I heard makes me think I blew out some of the planetary gears or something, who knows maybe even the torque converter broke itself.
  18. Jan 14, 2018 at 11:22 PM
    Speedytech7
    Be pretty hard to do with any Toyota engine's power unless that tranny was already on its way out or you decided to test it with front wheel brakestands haha.
  19. Jan 14, 2018 at 11:33 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :wave:
    Sup Adam!
    Box Rocket[QUOTED] likes this.
  20. Jan 15, 2018 at 2:40 AM
    nagorb
    Alabama
    2001 dbl cab 4x4
    The beast speaks!
    Now fuck off, @Blackdawg and @m3bassman have taken the torch of condescension.
    Said with care and affection.
    fiziks, Digiratus, Fernando and 3 others like this.
