  1. Jan 16, 2018 at 10:52 AM
    gunny1005
    gunny1005 Well-Known Member
    Phoenix
    You can order a complete kit, that has matching keys, what year truck again?
  2. Jan 16, 2018 at 10:56 AM
    tony2018
    tony2018 Well-Known Member
    2002 crew cab, or double cab, tacoma 5vzfe.
  3. Jan 16, 2018 at 10:58 AM
    gunny1005
    Phoenix
    Wow, they are expensive, complete kit 69005-35840 $412.07
  4. Jan 16, 2018 at 10:59 AM
    tony2018
    locksmith!!! But I'll keep that in mind Thanks gunny. Stay warm.
  5. Jan 16, 2018 at 11:04 AM
    gunny1005
    Phoenix
    Yes, lock smith is going to be way cheaper.
  6. Jan 16, 2018 at 11:26 AM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Have you tried just getting a code cut key
    that's what I did works way better than the old worn out key, and a whole lot cheaper than any other option
  7. Jan 16, 2018 at 11:38 AM
    YotaTank
    YotaTank Well-Known Member
    Road Salt Hell
    1995 Tacoma SX 4x4
    Replaced the rear diff breather, was stuck shut and original to the truck.
    m3bassman, SwampYota and Itchyfeet like this.
  8. Jan 16, 2018 at 11:41 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    This is something everyone should check every oil change. Just make sure the cap moves take two seconds. If these stick/rust shut they will blow your rear axle and pinion seals.
  9. Jan 16, 2018 at 11:42 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Worth moving up higher too, always think it is weird that only that one sits so low.
    Keep on Truckin', YotaTank and Teke like this.
  10. Jan 16, 2018 at 11:46 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Ive never checked that! Ill check today. Ive been wanting to relocate it, its on my list, maybe ill do that this weekend. Its a cheap mod right? lol truck gets nothing to expensive for a while.
    YotaTank likes this.
  11. Jan 16, 2018 at 11:48 AM
    YotaTank
    Road Salt Hell
    1995 Tacoma SX 4x4
    I did have a seal go a while back, replaced with fresh fluid. Never really read about this as a maintenance item until recently. Took me under a minute, bolt came off with zero issues.
    Maybe a total relocation is the next step?
  12. Jan 16, 2018 at 11:53 AM
    Speedytech7
    It is a super easy job to relocate it, takes maybe 30mins. Just need a BSP union (yeah for some reason Toyota used British threads) and some hose as well as a cheapo small engine fuel filter. I relocated my breather to the fuel door area.
    YotaTank[QUOTED] likes this.
  13. Jan 16, 2018 at 11:55 AM
    YotaTank
    Road Salt Hell
    1995 Tacoma SX 4x4
    I like that a lot, will help keep a lot of stuff out.
    What size union and tubing did you use?
  14. Jan 16, 2018 at 11:57 AM
    Speedytech7
  15. Jan 16, 2018 at 11:59 AM
    YotaTank
    Road Salt Hell
    1995 Tacoma SX 4x4
    Looks like my next project, just so I am clear, the union replaces the breather piece itself, connect the hose, place a small fuel filter somehwere along the line, then mount it near the gas cap?
  16. Jan 16, 2018 at 12:01 PM
    Speedytech7
    That's what I did, the filter is actually right behind the plastic shroud in the fuel door compartment, I wanted it to be way out of the way.
  17. Jan 16, 2018 at 12:05 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Krazyoakes, YotaTank and Speedytech7 like this.
  18. Jan 16, 2018 at 12:05 PM
    YotaTank
    Road Salt Hell
    1995 Tacoma SX 4x4
    Awesome! Thank you both for the info!
  19. Jan 16, 2018 at 12:09 PM
    Dan8906
    Daniel
    Concord, California
  20. Jan 16, 2018 at 12:11 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    The breather itself (90930-03136) has a filter in it, as I understand it - just like the one that's on the diff. A lot of folks don't put a breather (which has a check valve) when they relocate, they just put a filter.
