  1. Jan 21, 2018 at 5:58 PM
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    A couple of weeks ago I took on the task to bed line my truck. At frist I used the spray on stuff and after I used the roll on stuff. Little did I know that it had some reaction to the spray stuff that it turn into what looks like tar. I must of not let the spray stuff not dry long enough but I really screwed the pooch on this one. Well anyway took me a couple of days to scrape off the crapy side I had done and started all over again but this time only spray on bedliner. Not perfect but much better than it originally looked. Oh did I mention that drop in bedliners suck? Well they do imo.
    jubei, Jckdnls, redrazr and 2 others like this.
  2. Jan 21, 2018 at 5:59 PM
    MadbumsBum
    MadbumsBum Well-Known Member
    NW WA
    1999 Tacoma TRD 4x4
    On my old Tacoma I did a roll-on bedliner but did my rails with the spray on and found the spray on to be much nicer. Maybe I'm just a bad painter. :rolleyes:
  3. Jan 21, 2018 at 6:44 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Got some wheeling in with @Lux and @Rockbaron1 this weekend.
    Jim showed me parts of NJ and NY I never knew existed and it was a blast.
    rngr, BYJOSHCOOK, jubei and 8 others like this.
  4. Jan 21, 2018 at 7:03 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Get some 6x6 to use under the Jacks. Works great. Only way I can even jack my truck up is with those on the jack stands and one on the jack.
    Reh5108 likes this.
  5. Jan 21, 2018 at 7:13 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Story Time!!!!!!!
    After I posted these pictures I started my way up a canyon that was supposed to take me home. Ended up having to chain up, and lock the rear winch still wasn’t enough. By the time I got turned around I was basically out of fuel and well over 80 miles from Home.
    On my way out if the canyon I ran into a Jeep that was coming up behind me. But guess what, they ran out of fuel. So I loaded up the youngest and took him with me. While the rest waited for help that was on the way.
    When I got down out of the canyon I was in I started getting phone service so I called for back up just in case I didn’t make it to a station.
    With help on the way I started making my way back to the highway and somehow made it to a gas station at the same time my help met up with me.
    I ended up putting 17.2 gallons of fuel in my tank.
    At the end of the day every got down the mountain, including the Jeep.
    This is a long story very condensed. Always bring extra fuel.
    I realize this probably isn’t the place for this, but I hope you enjoyed my story.
    Cid, jubei, Deathbysnusnu and 5 others like this.
  6. Jan 21, 2018 at 7:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    With as much as you go out figured you had a jerry can all the time. You better get one now. Glad all worked out
    Did good though! 17.2 haha my "best" is 17.9. Pushed it there..
  7. Jan 21, 2018 at 7:18 PM
    tony2018
    tony2018 Well-Known Member
    thats crazy but glad you made it to a gas station. Def will have to look for some way to get an 2nd gas tank if something like this occurs.
    JKO1998[QUOTED] likes this.
  8. Jan 21, 2018 at 7:20 PM
    JKO1998
    Utah
    I usually do have one, but I wasn’t really planning on going the I tried and I wasn’t expecting there to be as much snow as there was.
    2 days ago the canyon I was in was bare. Now it’s basically impossible to get through. For my rig anyway.
  9. Jan 21, 2018 at 7:32 PM
    JKO1998
    Utah
    It was definilty an eye opener, closest I’ve ever been to being stranded with no fuel.
  10. Jan 21, 2018 at 7:37 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Why diesel?
  11. Jan 21, 2018 at 7:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Jan 21, 2018 at 7:41 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Slack should not matter, May want to check the switch behind you clutch or brake peddle. If it is out of adjustment it want work. While your driving take your foot and pull up on your clutch or brake peddle and turn on the cruse control, if it comes on probably the switch. It happened to me. :notsure:
    MadbumsBum[QUOTED] likes this.
  13. Jan 21, 2018 at 7:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Weenie roasts
  14. Jan 21, 2018 at 7:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Because the knly way Ben knows how to work a fire is throwing diesel on it
    Silver02Taco likes this.
  15. Jan 21, 2018 at 7:45 PM
    JKO1998
    Utah
    It’s effiecent.
  16. Jan 21, 2018 at 8:03 PM
    redrazr
    redrazr Psalm 118:5-6
    Baker, FL
    2001 Xtracab TRD PreRunner
    Bilstein 5100 front/rear, Method NV Diamond wheels, Mickey Thompson Deegan 38 265/75-16's
    I pulled my corner lights to paint the trim recently and when I plugged them back in they do not work. If I tap the passenger one it will come on but the driver side will not. Any ideas? Should I replace the plugs, or corners? Thanks for any help in advance.
  17. Jan 21, 2018 at 8:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So I did a thing..
    I picked my 3rd 1st gen taco this week....i may have a problem..:anonymous:
    [​IMG]Minitaco.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Minitaco-2.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Minitaco-3.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Minitaco-4.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Minitaco-5.jpg by Monte Nickles Photos, on Flickr
    For those of you not up on your Tacoma lore, this is a rare 1995 1st gen single cab with the 3.4L 5vzfe V6 in it and a 5 speed manual. Only made for 2 years in this SX configuration. Truck has high miles but well cared for and drives great. Sucker moves with the bigger motor and weighing nothing!
    I now have a single cab..an extended cab..and a double cab tacoma...
    :burnrubber:
    SnowroxKT, Prayn4surf, Cid and 29 others like this.
  18. Jan 21, 2018 at 8:53 PM
    Speedytech7
    Noice, I was hoping you'd snatch that up!
    Blackdawg[QUOTED] likes this.
  19. Jan 21, 2018 at 8:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    truck is fun as hell. Has a few quirks that need delt with but all super easy and also cheap. Thing seems brand new otherwise. Guy took stellar care of it. Hauls ASS too haha I didn't once have to down shift coming home from Co to MT on the interstate on any hill. Pulls in 5th haha
  20. Jan 21, 2018 at 9:07 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Hey I have three too, will have four if a good deal comes around. You can never have too many of them.
