  1. Jan 29, 2018 at 9:53 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah, that would be my only concern - not trying to snap an output shaft in the middle of nowhere.
    I wonder if the tundra outers have the same spline count? Never messed with one before.
  2. Jan 29, 2018 at 9:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yes they do. Tundra CVs are what all LT 4x4 tacomas run.
    Tundras have a 6 ball bearing true constant velocity joints. So they are stronger.
    be cheaper than RCVs..but probably would break still with 35s with chains buried in snow up to the doors haha
    Prayn4surf and drr[QUOTED] like this.
  3. Jan 29, 2018 at 10:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek: Was that an OEM axle?
    drr[QUOTED] likes this.
  4. Jan 29, 2018 at 10:04 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Didn't have to break the chains out, managed to drive out in 2wd even. Amazing what 35s at 4psi will do.
    Yes sir, original axles with 160k on them. Haha probably should have seen that coming.
  5. Jan 29, 2018 at 10:09 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah, everything you can imagine related to electricity is in the Toyota wiring catalog. What are you trying to do?
    Trust me you don't want to pay $5 per pin.
  6. Jan 29, 2018 at 10:09 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
  7. Jan 29, 2018 at 10:12 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah I've read a couple reports like that, I remember them being ridiculously expensive too.
    That's up at Tonga Ridge, pretty nasty conditions now with the snow level rising. I'd wait till the next storm to head back up there.
  8. Jan 29, 2018 at 10:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ha! Nice.
  9. Jan 29, 2018 at 10:18 PM
    Adude
    Pnw
    04 Double cab
    East side, still intersted? Im not going anywhere for a few paydays. Truck Bed to grab and swap, suspension to install, tires. Now my heater core was cutting out today.
    And props on cutting throw good pow!
  10. Jan 29, 2018 at 10:25 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Thanks, that was straight Cascade concrete though, no pow to be seen lol
    Heater core was acting up, or fan was cutting out?
    I'm always down to go wheeling, let me know if you're heading out somewhere and I'll see if I can swing it.
  11. Jan 29, 2018 at 10:32 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I've got quite a few big ideas with my truck once its back up and running. I'm just wanting to find bare pins without wire so i can have nice clean harnesses. I Don.t like having to Heatshrink pigtails onto larger runs of wire. Anything I add aftermarket I plan on making factory looking harnesses too. (I'm just weird like that)
  12. Jan 29, 2018 at 10:39 PM
    Adude
    Pnw
    04 Double cab
    Thought i passed you out by Preston/Fall City after work the other month. If a weekday/or weekend works im down. At work if wind or rain is to brutal we leave.
    I apprecate the offer and not going solo would be nice.
    Sounds like a heater core, 15min into the commute on 1st ave temp gauge spikes after the fan goes cold. Tapped it a few times, and the fan blew super hot air.
  13. Jan 29, 2018 at 11:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I feel ya, it's just way too expensive to buy the Toyota pins. If you re-pinned a 24 pin connector you're looking at about $240 only in PINS.
    Some of the connectors are generic, some are proprietary. You're really at the mercy of Toyota.
  14. Jan 29, 2018 at 11:16 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    No prob. Both do well charging, though the 1045 definitely charges faster (I think it's a 2.4+2.4A vs 1.0+2.0 or some such). Post pics once you get it all installed!
  15. Jan 29, 2018 at 11:18 PM
    Empty_Lord
    Dan
    I've been in talks with our Field rep about finding out the manufacturer of our pins and connectors. hes trying for me, I've found one style and they're $0.18 a pin.. cheaper if you buy bulk.. that i can stomach. The pin ive found is the one thats in quite a few of the connectors in these trucks under the hood. notably the Coil pack connectors. The brand is Yazaki series 090II Sealed series.
  16. Jan 29, 2018 at 11:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Okay, which one of you is this? o_O
    I can count at LEAST eight different cars frankenstein'd onto what is left of this poor poor Tacoma.
    03 NIGHT TACO and BYJOSHCOOK like this.
  17. Jan 29, 2018 at 11:20 PM
    Empty_Lord
    Dan
    Is that franks hillbilly cousin?
  18. Jan 29, 2018 at 11:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That's the OES - Yazaki. They do sell the pins at a much much cheaper price than Toyota does, but a lot of the first gen connector housing are discontinued. You also have to buy them in bulk - like I would need to order 60 power mirror connector housings to qualify.
  19. Jan 29, 2018 at 11:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    More like mentally retarded cousin...
  20. Jan 29, 2018 at 11:23 PM
    Empty_Lord
    Dan
    Housings shouldnt be too hard to source out of the junkyard for me in decent shape if they're in the interior. Its just the pins that I'm worried about. Alot of the old Camrys and corollas in the local LKQ and pick an pull here... prime for the picking. Plus i have a big collection at work..
