  1. Feb 1, 2018 at 9:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    In 4/2WD he wouldn't have the vibes at least. But yeah caution is wise, I don't have a great track record with that judgement call... At least on dirt.
    Adude[QUOTED] likes this.
  2. Feb 1, 2018 at 9:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah no doubt. Not a lot of yards with toyotas around here.
    I knew about the chalk..but idk if there are bolts. Maybe I'll find out. Up top it looks
    Hmm well. Idk.
    I had a buddy drive from Lake Tahoe to Santa Barbra or some place in FWD after nuking the rear diff.
  3. Feb 1, 2018 at 9:56 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    i take some pics of the driver side body mount bushings and we can see if there smashed my pancakes lol
  4. Feb 1, 2018 at 10:43 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    On the bumper subject, I knew they had heavier material and used a press brake on main components vs welding flat parts together. All though never saw the impact buffers before. Still a cool vid and you can see the pride in there production.
    https://www.youtube.com/embed/3yqHL7Uo4_s
  5. Feb 1, 2018 at 11:20 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    arb does make amazing products but i wish that there bumper flowed with the lines on the truck better. unless you drive a humvee i just dont like the looks of it
  6. Feb 2, 2018 at 5:09 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    For real, I’ll buy that SC if you part it :spy:
    Hoping that doesn’t happen but still
    rngr likes this.
  7. Feb 2, 2018 at 5:42 AM
    1997tacomav6
    Denver
    Sorry man, what a bummer, This is something (a crash) I always worry about every time someone
    cuts me off or just pulls infront of me with less than a cars length space between us in Denver.
    Hope u can fix it even if you have to pay a little more, keep her going!
  8. Feb 2, 2018 at 6:07 AM
    tony2018
    tony2018 Well-Known Member
    As long as they aren't leaking, new o-rings and fresh lube, I'd re-use em too if I had to.
  9. Feb 2, 2018 at 6:08 AM
    tony2018
    I was like 'hm, king ranch edition. Never heard of one'.
  10. Feb 2, 2018 at 7:23 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
    I may be mistaken, I think ads LT and non LT coils were same price. Could one run LT for now in case of future LT mods or will the shock not perform too great? Just figure spending that kind of money might as well get LT for future possibilities just not sure if it’ll work, need limiting straps before LT kit? Fill me in here with some insight....
  11. Feb 2, 2018 at 7:28 AM
    nw_chris
    nw_chris Outside Everyday
    Albany, OR
    2022 DCSB TRD-OR
    Long travel shocks will not work/ fit in a stock or mid suspension. Long travel only works with long travel..
  12. Feb 2, 2018 at 7:33 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    It's not that bad to replace the fender aprons, I took them off my 01 cab and installed my 02 Dcab. The Fenders line up decent and the hood closes better than it has in years!
    The worst part about the Job is/was paying $500ish PER side for the inner fender aprons. Camelback may be cheaper. I didn't and just swapped the parts over.
  13. Feb 2, 2018 at 8:13 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I wouldnt mind trying some cat.
  14. Feb 2, 2018 at 8:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No.
    the shocks are not interchange able for those applications.
    Long travel uses a 2.5x8'' shock usually.
    Mid travel is around a 2.5x6'' shock.
    Long travel shocks are way too long for stock length control arms, you'd bottom out the shock all the time. Mid travel shocks are too short for LT you'd over extend them and wouldn't be getting full travel from the kit if you strapped it thus making it pointless.
    There are no money saving trick for Long travel. Why a lot of people don't have it.
    oooff...that does not look fun. Really hope i don't have to do that.
    Camelback had them at 380ish a side. But go knows what shipping would be.
    you have to cut the whole thing off and then weld the full thing? shit..
  15. Feb 2, 2018 at 8:39 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Figured I would try this one out. Just ordered today, will be here in a week or so.
  16. Feb 2, 2018 at 8:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that a 3.0 radiator?
  17. Feb 2, 2018 at 8:52 AM
    sd_N
    sd_N Well-Known Member
    Ozark Mountains
    03 Tacoma Double Cab SR5 TRD 4x4
    Starting new...
    Today? Installing new clutch kit. And my WIP of swapping auto to manual continues. Lol. Hoping to finish by Monday or Tues.
    ManInTheMaze likes this.
  18. Feb 2, 2018 at 8:53 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Well that sucks i didn't think it would be likely to work but it would been nice
  19. Feb 2, 2018 at 8:54 AM
    Speedytech7
    That's a fun project haha, what clutch you go with?
  20. Feb 2, 2018 at 8:55 AM
    sd_N
    Ozark Mountains
    Starting new...
    XTR Stage 2... came with a new flywheel too! Lol. That's always a bonus.
