  1. Feb 8, 2018 at 6:15 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    is $100 for a disassembled 2jz long block fair? provided that the block and head are good? :anonymous:
  2. Feb 8, 2018 at 6:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah. But you'll spend a fortune on the rest.
  3. Feb 8, 2018 at 7:14 PM
    wat0023
    wat0023 Well-Known Member
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    Velcro was sticky backed, but I put a couple strips of mounting tape underneath, one on each side, to secure it in place better. It was just a little stronger than the sticky backed velcro
  4. Feb 8, 2018 at 7:15 PM
    wat0023
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    She*** :D:rofl:
    RedManRocket likes this.
  5. Feb 8, 2018 at 7:16 PM
    wat0023
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    Yeah, I put a small piece on the knife. The aux is going good, but I'm going to need stronger velcro sticky on the knife. I just put a small piece on it, so it's not really in the way of anything, it's not my good knife haha
  6. Feb 8, 2018 at 7:20 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Here ya go here’s one for ya!
    I saw this to most likely a scam. I would buy this in a heartbeat for this price.
  7. Feb 8, 2018 at 7:32 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Where in Utah are you? SLC?
  8. Feb 8, 2018 at 7:34 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Yeah if that second one is legit I got totally screwed.
  9. Feb 8, 2018 at 7:45 PM
    vonellis
    Some and some more
    Yes sir I think I sold you my air box and cv’s!
    Hope you didn’t send a cashiers check
  10. Feb 8, 2018 at 7:47 PM
    JKO1998
    Utah
    I don’t think you did :rofl:. I wish I had a stock air box
  11. Feb 8, 2018 at 7:49 PM
    Dgrptr
    Dgrptr Member
    Jared
    Northern California
    2000 Toyota Tacoma SR5, 3.4L V6, 4X4
    Off road tires, plasti-dip trim pieces, wrap around bars rear bumper.
    Did a little front end stuff. Removed the bug shield and blacked some stuff out. Pretty happy with it.
  12. Feb 8, 2018 at 8:17 PM
    vonellis
    Some and some more
    My bad must have been someone else up on for some reason I thought it was you.
    JKO1998[QUOTED] likes this.
  13. Feb 8, 2018 at 8:37 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Well, I think the back end is now adequately protected.
    synergy10, jjsul, Cid and 6 others like this.
  14. Feb 8, 2018 at 8:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Zane, who sells these u-bolt top plates? Theyhave the two threaded holes for either Timbrens or superbumps. Is it Trail Gear?
    @Speedytech7
  15. Feb 8, 2018 at 9:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No its sky offroad
  16. Feb 8, 2018 at 9:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Those are the Wheeler's brand set, I'll be making my own strike plate risers that bolt to that after I get everything all bolted and welded in.
    You did a ubolt flip? Also yeah you're right, technically a kit for the 2nd gens but I can't find a reason it wouldn't fit mine... @Blackdawg should be the same right?
  17. Feb 8, 2018 at 9:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Was gonna say. Not for 1st gens..swore I saw the same plates on sky offroad site. But not them.
    They should fit fine. Idk why they wouldn't.
  18. Feb 8, 2018 at 9:19 PM
    Speedytech7
    Figured the axle would be the same diameter and I confirmed the physically cover the width of the leafs adequately.
  19. Feb 8, 2018 at 9:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wheelers may be selling themm but I'm fairly certain they don't make them. I think its trail gear that makes them. There are also some without the threaded holes that look the same otherwise.
    Do yours have the threaded holes for mounting bumps?
  20. Feb 8, 2018 at 9:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah its the same axle just a touch wider.
