  1. Feb 12, 2018 at 10:00 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Does the cable have 12volts to the cut end? could be the factory engine ground.
  2. Feb 12, 2018 at 10:00 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    I'll rock the OME for now and then in the future I'll think about upgrading :headbang:
    JKO1998 and Speedytech7 like this.
  3. Feb 12, 2018 at 10:00 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I doubt it has power since the main 80A fuse is blown. It is really corroded so it's been a while since it's been connected.
  4. Feb 12, 2018 at 10:02 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'll have to check tomorrow when (and if) I can find an 80A Japanese-style Type C slow-blow fuse. That's a mouthful.
    Thing is I can't find the other end of it. The frayed wire in my picture is the only side of the wire I could find.
  5. Feb 12, 2018 at 10:03 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    You didn't put a fuse in it yet?
  6. Feb 12, 2018 at 10:03 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
  7. Feb 12, 2018 at 10:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    New fuse might help, just thinking out loud
  8. Feb 12, 2018 at 10:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'll have to go find one at a parts store, might have to drop by the stealership if I can't find one. This is some weird specific Japanese style fuse.
  9. Feb 12, 2018 at 10:06 PM
    Speedytech7
    I've seen them at AutoZone and Orielly before, made by Bussmann. I completely forgot to pull all those fuses for extras when I scrapped the other truck.
  10. Feb 12, 2018 at 10:07 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I saw those Bussman ones too on Amazon, but those are the flat bolt on ones while this one is the insertion type. Let me keep looking into it.
  11. Feb 12, 2018 at 10:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah actually now that it's mentioned it's likely a ground cable. There is only one power cable that goes down to the starter. And one that comes up from the alternator to the fuse box.
    BartMaster1234 likes this.
  12. Feb 12, 2018 at 10:11 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'll have to find where it goes. My 3RZ has a different harness configuration so I couldn't trace that one.
    It's just weird because I can't find the other end of it or where it is supposed to go to.
  13. Feb 12, 2018 at 10:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Found this thread after I googled '80A Toyota Fuse' and it's about a guy who messed up the grounding on his Alternator when removing it... so I guess that frayed wire very well could be a ground.
    Now the question is, where does it go to?
  14. Feb 12, 2018 at 10:21 PM
    Speedytech7
    I'd look to the stock ground location on the block for the V6, usually only one block ground. I wouldn't bother repairing that, I'd make a new one. Not good to run high amperage loads like the starter without having the block ground, because much smaller wires end up being the new ground and you fuck up electronics and burn low gauge wires.
  15. Feb 12, 2018 at 10:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Let's pretend that frayed wire is the Alt. ground wire, where does it ground in the engine bay - the block I'm assuming?
  16. Feb 12, 2018 at 10:25 PM
    Speedytech7
    It wouldn't be the alt ground, just the main block ground, the big negative cable from the battery to some boss on the block that is threaded. I don't have a V6 but on the 4cyl that ground is right above the transition to the oil pan, a bolt hole that only holds the ground cable.
  17. Feb 12, 2018 at 10:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There is no ground wire on the alt anywhere.
    It'll be on the block
  18. Feb 12, 2018 at 10:28 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Makes about sense. I assumed it was a power wire since it's on the harness leading to the positive terminal but I didn't check the engine block for broken ground connections.
  19. Feb 12, 2018 at 11:14 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    just got the dreaded info about my ARB bumper lol weight 210 idk if thats in pounds or kilograms lol im hoping kilograms cause damn that's going to be heavy.
    m3bassman likes this.
  20. Feb 12, 2018 at 11:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You want "210" to be in Kilograms? Because 210 Kg is about 463 pounds. LOL!
    I'm pretty sure it's 210 Pounds.
    2BeersPlease and Speedytech7 like this.
