  1. May 9, 2012 at 7:49 PM
    Madjik_Man
    Colorado Front Range
    Are you talking about his vids?
    They're embedded photobucket videos
  2. May 9, 2012 at 7:50 PM
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    Haha I agree this is ridiculous. I'm not too worked up about the stock horn. Just thought I could maybe find a replacement that had a different and better sound. Obviously this one failed :p Good thing the kind sir denied I pay for it and gave it fo FREEEEEEEEEEE
  3. May 9, 2012 at 7:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  4. May 9, 2012 at 7:54 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    They must have used different horns on 01-04s, because my horn sounds nothing like those haha.
  5. May 9, 2012 at 7:55 PM
    Madjik_Man
    Mine sounds exactly like it.
    Wonder if they changed it after 2000?
  6. May 9, 2012 at 7:55 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    ya fortunately for you 01-04 owners :( haha damn i'm jealous
  7. May 9, 2012 at 7:56 PM
    Madjik_Man
    Gives me another cheap mod to do.
  8. May 9, 2012 at 7:58 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Oh yes, yes it does! Same here too. And again, if you get to it before I do, fill me in ;) Just looking for a simple swap kinda deal. We'll see.
  9. May 9, 2012 at 7:59 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Changed the oil with Mobil1 and a Toyota filter, changed the tranny fluid with Mobil1, changed the t-case oil with Lucas 75w-90 and replaced all washers on fill/drain plugs. Remounted my liscense plate to the lower left corner of my tailgate. Finally extended the speedo sensor wire so it could reach the sensor on the t-case. Been with out a working speeometer for about 3 months now... lol :p Sure is nice to have my cruise control working again. Also, got a lot of progress done on my ARB install and regear. It is taking a long time to get the preloads and back lash set though... Currently working on the carrier bearing preload and backlash right so I can get the first contact pattern.
  10. May 9, 2012 at 7:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    weird, well now I see what all the complaining about stock horns is about.
  11. May 9, 2012 at 8:02 PM
    Slodgetto
    Silas
    Yeah, my horn SUCKED.
  12. May 9, 2012 at 8:05 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Took it to my mechanic and changed my fuel filter.
  13. May 9, 2012 at 8:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    my cruise control goes in and out :mad:
    anyone know why?? Ill want it bad for the 12 hour trek to Moab :p
  14. May 9, 2012 at 8:44 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    have you gone through the wiring? check for bad connections, also check fuses.
    I wish my truck had cruise control.
  15. May 9, 2012 at 8:50 PM
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    2023 Double Cab Trail Edition; 03 Double Cab 4x4 TRD SOLD
    2023 Bone stock... 2003 - Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    replace it with a horn from an 01-04 and it will sound normal. I remember my 97's sounding like that. Kind of defeats the purpose of honking at someone when your pissed! lmao they just laugh even more
  16. May 9, 2012 at 8:57 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Do you have auto or stick? Only reason i ask is on my 94 if my foot was resting on the clutch pedal, it was just enough pressure on the switch to not allow cruise. Thought i had an issue, turns out it was just driver error.
  17. May 9, 2012 at 9:02 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I think our cruise control is set up by a vacuum?
  18. May 9, 2012 at 9:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i will do that
    Yes the clutch and brake both turn off the cruise control. I found that if i use the clutch to switch it off it usually will come back on when i get back up to speek..not so with the brake :notsure:
    yes and no. Electical to engage it, but it uses vaccum from the motor to tell how fast your going(rpms) then holds the throttle cable in the same position to keep that same vaccum going..in a nut shell anyways.
  19. May 10, 2012 at 5:22 AM
    Madjik_Man
    It's more than likely your clutch pedal not going all the way back up and depressing the cruise control switch.
    I had the same problem.
    If you can put your foot behind the clutch pedal and "pull" it slightly towards you, does the cruise control engage?
    Here's the thread I made asking about my cc problem: http://www.tacomaworld.com/forum/1st-gen-tacomas/213113-cruise-control-problem.html
    Post #6 was most helpful
  20. May 10, 2012 at 5:59 AM
    HammerHead
    HammerHead Well-Known Member
    Jake
    Georgia
    04 TRD OffRoad PreRunner SR5 DC
    I will definitely drop pics once completed. If it looks like its going in the right direction, I may even video a portion as that would be easier to see and follow versus pics. Looking at either doing a double whip pattern, or a long turkish weave (?).
    We shall see
