  1. Feb 18, 2018 at 7:46 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Yesterday loaded it with a cut down yucca tree. 5 dump trips, 2463lbs total. Probably got the same today..ugh
  2. Feb 18, 2018 at 7:47 AM
    Cid
    Cid ╭∩╮(◣ _ ◢)╭∩╮
    Keith
    Waterbury CT
    2004 Taco 5spd SR5 TRD / 2018 HD FXBB
    ADS Coilover Front, OME Dakars with Nitro's Rear, Relentless Skids, BAMF Sliders, FN Five Star rims, 285/75r16 Falken Wildpeak, Aero Turbine 2525
    Yea can't wait to do my lift. Looks like nothing has been touched since it left the factory. ADS has a 4 week lead time so I'll start pretreating soon.
  3. Feb 18, 2018 at 8:01 AM
    Madjik_Man
    Colorado Front Range
    lol
    If it's the whole body and it's in good shape I'm road tripping tomorrow.
    SilverGhost[QUOTED] likes this.
  4. Feb 18, 2018 at 8:29 AM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Any interest in these from anyone? 15 shipped or 12 bucks local pick up in torrance ca.FB_IMG_1518931103568.jpg FB_IMG_1518931407044.jpg
    HCFab and vonellis like this.
  5. Feb 18, 2018 at 8:47 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you going to do a cab swap? haha not the funnest thing..but shouldn't be too hard.
    SilverGhost likes this.
  6. Feb 18, 2018 at 9:08 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    What I'd like to do is put in a switch that simulates 4L to the ABS ECU, since that's the only thing that disables ABS. Just never gotten around to it. I don't actually mind ABS on-road.
    I do have it raised up, always have since I lifted the back. Mostly I'm wondering if I'm using the back brakes at all, not if I'm using only the rear. :)
    Probably worth noting that I don't feel like there's any problem with the brakes, but I figure I've got four of them, so I should make sure they are all braking - esp. with all the weight we carry around.
  7. Feb 18, 2018 at 9:15 AM
    Madjik_Man
    I'd like to but it's probably a pipe dream. But you have to start collecting parts sometime.
  8. Feb 18, 2018 at 10:06 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It's interesting that this came up. After doing the brake upgrade, I had expected a little more so wondered if I was getting enough from the rears. So I raised the arm one notch on Jerry's large bracket thing and it definitely added braking power so I suspect prior my rears weren't doing much. Definitely feels a lot better. Especially noticeable on slow speed application.
    I agree with Zane's comment, I need to find some dirt/gravel to verify that the rears aren't locking up before the fronts.
  9. Feb 18, 2018 at 10:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well can always add the manual valve. But can kiss your ABS good bye if you do that.
    Otherwise not much you can do besides cut the connection to the axle and zip tie the rod all the way up. Even so i think it only does like a 30% max bias? can't remember.
    You'll need a bigger shop first..
  10. Feb 18, 2018 at 10:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have mine raised all the way on Frank. No reason not to have it up all the way with the stock valve really.
  11. Feb 18, 2018 at 10:08 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Why in the hell am I thinking about buying a turd gen? I wake up every sunday morning and start looking at them
    m3bassman likes this.
  12. Feb 18, 2018 at 10:10 AM
    Madjik_Man
    Working on that. Well a bigger garage, not "shop"
    BYJOSHCOOK and Blackdawg[QUOTED] like this.
  13. Feb 18, 2018 at 10:34 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    It’s 12:00 somewhere.
  14. Feb 18, 2018 at 10:39 AM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    FSM says its 6 o'clock somewhere.
    SwampYota[QUOTED] likes this.
  15. Feb 18, 2018 at 10:50 AM
    SwampYota
    Jon
    Floor mats
    I guess Hendrick Toyota didn’t have the FSM last year. I just replaced and put at six.
  16. Feb 18, 2018 at 10:51 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    The dealer couldn't even get it right? Lol
    EDIT: Well, when do they ever
  17. Feb 18, 2018 at 10:52 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    A lot of the people doing work at the dealers don’t know how to read a manual. Out of all 17 tech we have me and 2 others actually look stuff like this up when doing work
  18. Feb 18, 2018 at 11:10 AM
    Malek
    Malek Well-Known Member
    Malek
    Denver
    02 DC TRD
    1UZFE VVTi 5spd Swap
    Long overdue
  19. Feb 18, 2018 at 11:53 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    D...do you have a write up or link on this? If this is the case I probably haven’t touched my back brakes for a year and a half :eek:.
  20. Feb 18, 2018 at 12:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just look up some threads about the LSPV and the relocation brackets. The basic idea is with lift you're raising the body and frame off the axle, since the valve is mounted to the frame it thinks you're riding around with a very light load and turns down rear braking power to avoid tail happy behavior that can occur if the rears are too strong for a given weight. But since you're lifted you may be carrying a load but still above stock height so you need to raise the arm accordingly with your lift to avoid that issue.
